Question about Sportcraft 90 in. X-treme Turbo Air Hockey Table
Lights and scoreboard not working
Moved from another home, when reassembled table, lights worked until someone unplugged the table instead of using the switch. We tried to turn it on a few minutes later, and the lights, sound, score won't work. Air works fine.
Hotpoint fzfm151p. Bought a year ago. Worked fine up until I moved this month. My dad placed freezer in garage by mistake. Lights flashed (all) ever since it was in there. I've just moved it into the house...
Freezers have an electric motor within to pump the freezer gas around. Its possible the movement has caused a problem. Get ban appliance shop or tech to check it out.
Dec 29, 2014 | Freezers
The Accessory Scoreboard is malfunctioning. How can I fix this?
Check the relevant supplies are OK. A low supply to the processor will cause all sorts of issues like your description.
Oct 10, 2014 | Educational Insights Classroom Jeopardy!
FRIGIDAIRE FRS20ZRG STOPPED WORKING AFTER MOVING IT, LIGHTS STOPPED THE NEXT DAY
It may have been defrosting on a timed cycle when the compressor stopped. If any water was present at the time, it may have seeped into the electrics. Check the fuse and you have power to the on/off switch and thermostat.. If fuse blown, check all is dried out before plugging back in.
Apr 21, 2012 | Frigidaire Refrigerators
I have a Harvard Model G03614F Air hockey table. Everything on the table is working except for the scoreboard. All of the wire and clips and molex plugs are where they should be except for 1 3 prong...
I would say the best bet it to call the Escalade Sports Customer Service number and see if they can help you get replacement parts. I am going to put a call in myself to get a new junction box (I have no power to the fans, but the scoreboard works) and some new strikers and a puck. I got my table from a friend who had been using it and then when I set it up it would not turn on...guess that explains why it was being stored in his garage when I picked it up!
The Escalade Sports Customer Service number is:
1-800-426-1421
Jan 01, 2011 | Video Game Consoles & Games
CDX keeps ejecting CDs some seconds after insertion
Replace the drive!!! I have six and this is the ONLY problem I see with these units!
Oct 08, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
I purchased a used GE Profile side by side refridgerator; it was used for model homes... Well I got it home and the lights are on but it doesnt seem to be working??? The buttons seem to be non...
if the unit was working before......unplug the unit, place it where it will be used, let it stand with no power for 24 hours.......then plug the unit in and check its operation after 24 hours....I know, sounds nuts, but this has saved many from buying a new unit......not all refrigerators like to be moved.
clarkco
May 09, 2009 | Refrigerators
F61 is my problem
This fixed my unit;
remove the top cover and power it up (keep hands and other body parts clear)
check the cooling fans at the right and rear of the unit, are they turning as fast as they should be?
If not remove the fan and peel away the sticker from the center anput a drop or two of WD-40 down the hole and spin the fan until it loosens up then reassemble.
This fixed mine. Hope it fixes yours.
May 27, 2008 | Panasonic SC-HT67 System
Sportcraft 90 in. X-treme Turbo Air Hockey Table Logo
98 people viewed this question
Top Sportcraft Sport & Outdoor - Others Experts
Are you a Sportcraft Sport and Outdoor - Other Expert? Answer questions, earn points and help others
