Question about Epson Workforce 610 All-In-One InkJet Printer
Epson 610 workforce will not print black ink - Epson Workforce 610 All-In-One InkJet Printer
4 Suggested Answers
rajdeepdutta
  • 2517 Answers
SOURCE: There is a red light on the inside of my Epson
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Jan 23, 2011
SOURCE: How do I set my
(1) i hope you fully installed the network/wireless device software on the host computer and then followed all the on screen instructions.
(2) during the installation program attempts to find the printer.in the mean time turn on your Bluetooth on your phone and attempt to search the printer.
(3) make sure the entered the correct network name and security passkey.
Posted on May 13, 2011
SOURCE: I have a Epson Workforce
Hello Jaasp,
Follow these steps to print the nozzle check:
  1. Load a few sheets of plain paper in the sheet feeder.
  2. Press the Home button.
  3. Press cp_button_41_er.gif or cp_button_42_er.gif to select Setup.
  5. Press OK.
  6. Press cp_button_41_er.gif or cp_button_42_er.gif to select Maintenance, then press OK. You see this screen:
  8. Select Nozzle Check, and press OK.
  10. Press cp_button_6.gif Start to print the nozzle check.
  11. Shown below are some examples of what the nozzle check may look like.
    Nozzle check pattern with no gaps
    Nozzle check pattern with gaps
  12. Press Finish Nozzle Check and press OK when you're done.
Posted on Jun 18, 2011
Epson workforce 325 printing blank with black ink
The print head is plugged up. Try the nozzle check function or the clean function on the control panel.
Oct 07, 2016 | Epson WorkForce 325 Inkjet Multifunction...
How do I remove the Headers on the Epson Workforce 610 so I can clear a blocked header?
Head cleaning solution here http://www.fixyourownprinter.com/kits/epson you need to figure which is the right one for your unlisted printer. maybe look at which other ones use the same ink
May 02, 2014 | Epson Workforce 610 All-In-One InkJet...
My Epson Workforce 1100 suddenly stopped printing black when printing in color. This happens when printing from Microsoft Word, Wordpad, Lightbox (photo manipulation) and Adobe Reader. It prints black...
normally most printers even like mine an epson NX110 will use color then black when using text but with grayscale only your forcing it to use black ink more and no color ink set in normal mode some color ink does get used ironically but it is normal for it to use color some as it reserves the black ink being used
Apr 22, 2017 | Epson WorkForce 1100 Wide-Format Color...
Black ink not printing
Take hot water until warm
Put about 1/2 inches of water in a cup
Put the print head portion (where the ink comes out) in for about a minute
Dry off the cartridge using a soft tissue.
Re-insert the cartridge into the printer.
Run the normal cleaning software routine a few times
***If you need any technical help on printer then you can reach at here
Feb 15, 2013 | Epson Workforce 610 All-In-One InkJet...
Why doesn't my black ink work in my Epson WorkForce 600 series after replacing the black ink cartridge?
The Epson printer may only use genuine ink cartridges which contain a chip so that you cannot fill the cartridge with ink or use non genuine ink cartridges.
OR
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 01, 2013 | Office Equipment & Supplies
Epson workforce 610 printing improperly
have the printer being discussed in this thread.... the Epson WorkForce 610. I just encountered the same issue, many lines were missing from the page that I wanted to print. Ink levels were fine, but every time I try to print the same thing, the same lines were missing. I read through the solutions mentioned above and I decided to see what the printer had in its maintenance toolbox on the printer itself.
Here's a solution that worked for me!
1. Go to "Setup"
2. Under Setup, select "Maintenance"
3. Select "Head Cleaning"
The printer does the head cleaning automatically. Print another page, all of the lines should show up!
Simple, no need to buy another printer or clean the ribbon...
May 01, 2012 | Epson WorkForce 600 All-In-One InkJet...
Keeps saying paper jamed when I try to print
On the Epson website it is confirmed that the Epson WorkForce 610 will not recognize transparency media. It is just the way the printer works; if it can see through the media, it doesn't think it's there.
However.....you can tape a sheet of white paper to the non-printable side of the transparency, and it prints just fine. I put two strips of scotch tape on either side, top and bottom. Works great. It's kind of a hassle, but better than not being able to print transparencies at all!
Jul 22, 2010 | Epson Workforce 610 All-In-One InkJet...
Epson Workforce 610 All-In-One InkJet Printer Logo
346 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
