Question about JVC FS-7000 CD Shelf System
No Sound on JVC FS-7000
My JVC FS-7000 will not provide sound for either CD or Radio. I have checked the speakers by playing on another stereo and they do not seem to be problem. Is there a reset or circuit breaker inside stereo? I suspect my daughter may have been blasting the volume.
3 Suggested Answers
SOURCE: No sound coming from JVC FS-SD7
You burn out the audio amplifier IC you need to replace him
Posted on Mar 28, 2009
jerryg50
  • 1667 Answers
SOURCE: Connect to TV
Check the user manual for the TV to make sure that the TV has the option to allow an external audio system to be connected. If applicable, then check that any necessary mode setting have been done in the TV set to allow an external audio system. Make sure that you are using compatible connectors between the TV and the sound system. Also, the sound system has to be compatible to the TV.
Jerry G.
Posted on Apr 26, 2009
New Alpine radio, went through setup, plays fine on radio/tuner on all four speakers, but ipod (USB port) or internal CD only plays on front speakers.
Just a thought - the usb provides a digital signal which carries information about how the signal is to be processed; mono, stereo, surround sound stereo, etc.
If the mp3 music file was only recorded in 2 speaker stereo perhaps that is how it plays back.
Admittedly the radio signal is stereo and yet it plays on four speakers but unless it is a DAB radio it is analogue and maybe that makes a difference.
Perhaps there is an internal electronic fault with the digital processing part of the unit. I suggest reading the handbook again and then perhaps contacting the seller.
Mar 28, 2016 | Alpine Car Audio & Video
Hi, I have installed my JVC radio and when it is on FM radio, there is sound through the speakers, but when I play a cd there is no sound.
are you using an amplifier? if so, it sounds like you are using the blue wire (power antenna remote) instead of the blue/white wire (amplifier remote turn on) to turn the amp on. when leaving tuner mode the power antenna wire is turned off.
Feb 24, 2011 | JVC AM FM CD DET FACE CAR STEREO
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
Connect to TV
Jerry G.
Apr 26, 2009 | JVC FS-SD1000 CD Shelf System
Sound/Ground problem
bad connection in one of the speaker wire.
Apr 02, 2009 | JVC AM FM CD DET FACE CAR STEREO
Mar 28, 2009 | JVC FS-SD7 CD Shelf System
KD-LX100 working fine, then CD sound stopped working.
That particular cd might have been damaged .
Have you tried with any other cd .
Nov 27, 2008 | JVC KD-LX100 CD Player
No sound while playing dvd/cd
sound muting circuitery prblem or sound swiching section problem can occure this type fault.sometimes it can be cd /dvd printed board problem.give it to qulifid technician .
nuwan.
Dec 12, 2007 | JVC FS-S77S DVD Micro Component Stereo...
JVC FS-7000 CD Shelf System Logo
49 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
