Question about Boss ME25 Guitar MultiEffects Pedal with AC Power Supply Samson HP10 Headphones and (2) Sonic Sense Instrument Cables
Setting master volume of me 25 - Boss ME25 Guitar MultiEffects Pedal with AC Power Supply Samson HP10 Headphones and (2) Sonic Sense Instrument Cables
Which is the master volume to boss me 25 ?
Hi, I can help you with your question. On the face of the effects, towards the right side, there are three settings that can be adjusted: DRIVE, TONE and VOLUME. The VOLUME knob is your master volume. The expression pedal can adjust volume, but it's output volume is controlled by the master VOLUME knob we just identified. I hope this has helped you, and if it has, could you please click on the "helpful" button ? Thank you!
Feb 03, 2016 | Roland Boss ME-25 Guitar Multiple Effects...
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Mpc 1000 loud static
Maybe try adjusting the MASTER level?
Good Luck
Other settings
Adjusting the master level You can adjust the level of the headphone and the stereo out by turning the MAIN VOLUME knob. The MAIN
VOLUME changes the analog signal level. This will also adjust the entire level of the MPC1000 digitally.
01. Press the [MODE] key and then the [PAD 10] (OTHER).
It switches to the OTHER mode.
02. Press the [F1] (GLOBAL) key.
The GLOBAL page will be displayed.
03. In the Master level field, set the level.
You will set the digital signal level, which will be sent out to the DA converter. The MPC1000 can output up to
32 sounds simultaneously. There is the great difference in the level when you play single sample and play 32
sounds. If you increase the value in the Mater level field, you can increase the entire level of the MPC1000 to
create more powerful sound with less noise. However, if you playback many sounds at the same time, the
level may be overloaded, which may cause distortion. If you decrease the value in the Master level field, you
can prevent distortion when you play many sounds at the same time. However, you cannot have a good
result in respect to the noise or punch of the sound. Set the appropriate value in the Master level field
depending on the application.
Mar 31, 2014 | Akai Mpc1000 Music Production Center
Master volume is scratchy on MG100FX
All i can suggest is to use electrical contact cleaner on it from the inside. But you,ve already done that. And i would imagine that the master volumes will be the same to, Harry
Dec 28, 2013 | Marshall Music
Some keys on the left side are not giving sound when played and the master volume is loosing can it be fixed or should i have to buy a new master volume
It's about hardwares.
Wiring connection sockets is loose.
Inside the korg PA50,Wiring connection to the keyboard is separate to left and right.
Open/disassemble your korg.
Look for connection cable to the left keyboard.
One end is on the keyboard,the other end is at the mainboard.
Unplug both of it, then mounted again.
For master volume,better buy new one.
Jul 31, 2013 | Korg Pa50 Professional Arranger Keyboard...
Very low volume on all drums.
I don't think there is anything wrong, it has a very low line level output intentionally. This is to minimize distortion to an amp or mixer. Mine is the same and also a different brand. It is actually made so you could play it through a stereo without damaging it.
Mar 06, 2013 | Alesis DM6 Electronic Drum Set
My boss me 25 pedal's sound isn't as clear and good as the demos' sound. My amp is a randall RT100 which is a valve amp and my guitar is an LTD with the custom pickups. so the problem is the setting i'm...
I have the Boss ME 50. Here's things to try. Use wall outlet to power the 25 instead of batteries. Have volume on amp up, volume on pedal all the way up, volume pedal all the way up(depressed), no gain on amp(use clean channel or clean setting if only 1 channel)effects on amp off(reverb, chorus, delay, boost, etc.) mid range knob below 5. only 1 pickup on, guitar tone knob all the way towards treble. If this puts you in the ballpark you can then make slight tweaks to any of these settings. What we're trying to do is not run a dirty sound from the pedal board into an amp with dirty settings. That double dirt often causes a muddy sound. Aside from that you can back off on various effects in the patches. My 50 has a list of the patches and factory settings, so if the drive, for example is set on 8, I might back it off to 4, or the compressor, or the delay, etc. If you like the sound save it. If not continue on. Start with the amp 1st. Higher output tubes(such as JJ's produce a cleaner sound. Also the demo you heard was not coming from your guitar speaker which may not be on the clean side.
Sep 25, 2017 | Roland Boss ME-25 Guitar Multiple Effects...
High pitched squeal when the input jack is used.
Sounds like your master volume is turned up too much. The channel volume will make the squealing go away(caused by high gain and humbuckers). The best thing to do is dial in your favorite presets and change the channel volume to the correct level with the master volume where you usually keep it. I use my Spider Valve at master volume at about noon and the channel volume between nine o'clock and noon. Let me know if this does not solve the problem......
Aug 22, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Boss ME25 Guitar MultiEffects Pedal with AC Power Supply Samson HP10 Headphones and (2) Sonic Sense Instrument Cables Logo
65 people viewed this question
Top Boss Music Experts
Michial Gueffroy
Vito Vacirca Jr.
shaun taylor
Are you a Boss Music Expert? Answer questions, earn points and help others
