Question about Tissot T-Touch T33159851 Wrist Watch
I am looking for the stainless steel band L975.110N tissot
4 Suggested Answers
SOURCE: tissot stainles steel bracelet
you should take it to a qualified jeweler
Posted on Oct 14, 2007
escapement
  • 2334 Answers
SOURCE: Shortening stainless band for 1st generation Tissot Le Locle
Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 04, 2009
disap1
  • 98 Answers
SOURCE: Tissot Seastar 1000 Does anyone know of a source
Tissot is Swatch. They do not sell parts! You need to contact the company OR where you purchased the watch.
http://www.tissot.ch/?mod=stores&action=search&search=&regions=2&countries=195&countryregions=&option=cs
Posted on Jan 15, 2010
Looking for band for invicta sea spider 1261..i want to replace it with a stainless steel band..
Sea Spider 1261 INVICTA Sea Spider Men 50mm Stainless Steel Gold Black dial 3600K Mechanical watch located attached link offers multiple compatible straps
Nov 11, 2017 | Invicta Watches
Where to get a new. Watch strap
You can get Watch strap and everything of watch from The Prime Luxury Boutique. It is an authorized luxury watch retailer. http://theprimewatches.com/
Aug 09, 2014 | Rado Diastar Anatom Jubile watch
Can i get an extra link for my tissot 1853 (prs 200) bi metal,the strap is to tight, and will not adjust anymore.
I need one link for my watch that was given by my daugther its tissot diamond t shape stainless steel case,mop dial
Oct 26, 2012 | Tissot T Touch T33158851 Watch
I would like to change the leather ******** my tissot t91142851 to a metal bracelet like the model t91148851. where can i purchase such item and how much would it cost?
mcdevito75 here, Best Bet, Look for a small watch repair shop in your area for the replacement band. Cost would depend on the band itself, you"d most likely want a band that Tissot makes with their watches to maintain authenticity, I would figure such a band could cost $30.00--- $75.00 Of course you can also contact Tissot if you have the paper work that came with the watch when new, or online at Tissot watches.com
Jul 07, 2010 | Tissot T91148851 Watch for Men
I am trying to locate a watchband (stainless steel)for my tissot PR516GL. As soon as I can find a wrist band for it I will send it to get a tune up... I have had the watch since 1984...
mcdevito75 here, You can check out the repair service directory right here at fixya, bottom of the page click om repair service directoty then watches for both the band anf tune up.
Jun 23, 2010 | Watches
Jan 14, 2010 | Tissot Diver Seastar 1000 Auto Steel Large...
Digital and analog display show different time
Paste this link into your browser:
http://www.t-touch.com/flash.html
1)Close available countries window,
2)Click on T-Touch, then choose Stainless Steel,
3)On the right side of the window click on film tab,
4)In the left box in the window find SYNCRO and click on it,
5)Watch and listen to instructions
6)Smile
Do not forget to rate, please.
Jan 19, 2009 | Tissot T-Touch T33159851 Wrist Watch
How to open Baume & Mercier Hampton Milleis ladies stainless band
Looking at your watch it looks like the clasp on the SS model is just a double deployant preasure fit. If it is brand new sometimes these style of deployants are vary tight.
It is Stainless Steel it is vary difficult to break it looking at the construction of the bracelet.
Basically you just Pull, there is no button it is just pressure fit.
mike -- consumerwatchguide.com
Jan 01, 2009 | Baume Et Mercier Hampton Milleis MOAO8242...
Stainless steel band won't snap into my watch
Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
Another way is to use curved spring lugs (pins).
Dec 12, 2008 | Philip Stein Teslar Large Gunmetal Watch
Tissot T-Touch T33159851 Wrist Watch Logo
160 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Mohamed Ismail
Mohamed Ismail
Are you a Tissot Watch Expert? Answer questions, earn points and help others
