Question about RELIANCE ELECTRIC WATER HEATER
Leaking water heater around relief valve - RELIANCE ELECTRIC WATER HEATER
    Problem Solver:
  • 19 Answers
You can change out relief valve to stop leaking. Sometimes they get debris stuck inside and will not close properly.
Posted on Feb 10, 2013
Rheem water heater leaking water from relief valve pipe
the relief valve is replaceable . if it isn't leaking I would not worry about it
Feb 19, 2016 | Rheem Water Heaters
Water heater leaking from top
Presumably you are referring to a water leak - not gas. The pooled water could be condensate from a "sweating" pipe but, depending upon the age of the heater, it may be time to replace it
Apr 24, 2013 | Water Heaters
I have a 21v407 Rheem water heater that is leaking from the top relief valve. The leak i believe, is from under the valve. what is this problem. and how do u drain this thing?
Shut off the water supply valve over the heater. Shut off the electric or gas to the heater.
If you have any house or basement water valves below the level of the heater, open them and open a valve that is higher to vent it.
If necessary, open the drain at the bottom of the heater and using hose or buckets, lower the level below the relief/thermostatic valve. Be careful, the water is hot and softens even heavy hoses.
Once the water level is down, unthread the downtube (if there is one) from the discharge of the relief valve, unthread the relief valve from the heater and either dope/tape the threads or replace the relief valve.
Write back with any questions.
Sep 09, 2011 | Rheem Water Heaters
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    Just purchaced a 99 jamboree with an atwood G6a-8e water heater. while on a trip I lit the water heater, and after 30 minutes someone told me water was leaking from the side. I noticed the pressure relief...
    It's gas operation only, but has electronic ignition for propane. ( just to confirm, if you look at back of water heater, it would have a metal or black plastic cover and hydro cable going in side or top of it.)
    There are usually 3 things that may cause pressure relief to leak. 1) Faulty,corroded pressure relief valve, which usually needs to be replaced if it goes faulty. 2) water temperature is getting too hot, which could indicate a faulty thermostat. 3) If your hooked up to city water, the pressure may be too high, causing excess pressure build up in hot water tank, thus pressure relief opens. If your running off your on board pump, this is probably not the cause, as they are usually set at 40 psi.
    Ist, - try pulling lever on relief valve slightly open ( careful it's hot !!) to clean out any calcium that may be logged on seal thus causing leak. If that doesn't do it, and the hot water isn't running out steady and appear to be under extreme pressure while leaking, then I'd change the pressure relief valve. Remember when you do, shut off water to system, and relieve pressure by opening a tap, and pressure relief as well after that. New one shouldn't be too expensive, just make sure you get same thread, 1/2"NPT or 3/4"NPT. Use a little teflon tape, or pipe dope whatever you prefer when re-installing as well as clean threads a little before.
    If it really starts gushing out pressure relief when heating or heated, and water seems hotter than normal, it's more than likely a faulty thermostat. I'll wait for your reply on what condition your experiencing before I go in to how to change the thermostat.
    Nov 17, 2010 | RTO Atwood Water Heater - 6 Gal LP
    Pop off valve on gas water heater making racket. Can just the pop off valve be replaced?
    Yes it can be replaced. This is a temperature/pressure relief valve and is the second most important safety device on your heater. They rarely make racket. Is it leaking? if so yes replace it. Water heaters should have a portion of water drained annually along with operating the relief valve. IF you raise the handle a few times, and it continues to leak, then it should be replaced. If you replace it be sure to replace it with EXACTLY the same temperature and pressure rating that is on it now. Allow the water heater to cool, and drain pressure before removing. If it is rumbling inside, you might have calcium deposits bouncing around in the bottom. Drain some water and see how it looks. (Often if you operate drain, and haven't in a long time it won't reseal)
    Aug 11, 2010 | American Standard 40 G Natural Gas Water...
    Leaking pressure relief valve
    what is the water pressure on the cold side? You may need to install a pressure reducing valve at the water heater inlet to reduce inlet pressure and keep pop off valve from opening when not needed.
    Feb 27, 2010 | Emerson Part UWL Chrome Ultrasystem water...
    Relief blowing out hot water every hour or so. Controller? Set at about 125.
    try replacing the pressure relief valve to do so turn off water to heater and turn off power or gas which ever you have drain water from heater. then using pipe wrench remove old relief valve. when installing new valve use teflon tape on threads to prevent leaks then thread by hand back into water heater and use pipe wrench to snug dont over tighten turn water back on after full and no leaks turn power back on or relite piolit
    Nov 24, 2009 | Water Heaters
    Burner lights but will not shut off. then pressure
    CHECK TO MAKE SURE THE WATER TEMP IS AT THE NORMAL OPERATING RANGE. USUALLY AROUND 120-130 DEGREES. IF IT IS, CHANGE OUT THE PRESSURE RELIEF VALVE. IF THE TEMP IS OUT OF SCALE, CHANGE OUT THE ECO AND TSTAT.
    Jun 28, 2009 | RTO Atwood Water Heater - 6 Gal LP
    Relief valve constantly releasing water.
    lower your thermostats a bit. If your temperature is set to the hottest setting, then chances are no relief valve will do
    Jan 08, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
    RELIANCE ELECTRIC WATER HEATER Logo
    Top Reliance Water Heaters Experts
    Mack Baxter
    Gil Shultz
    rickb63
    Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
