Question about NEC DTU 8D-2 Corded Phone
Changing incoming calls to a different ext.
We no longer have a receptionist-all phones were routed to her ext. b4 going to auto-i want to change the incoming calls to my ext. how do i do this
Whos your phone system provider?
Posted on Jan 22, 2009
  • pathasse Jan 22, 2009
    If its a VOIP service then its easy otherwise you should call your technition that installed your lan line phone system.
When calls come into the office ext. 10 rings. It's the receptionist's desk. However ext. 29 rings too. How can I stop ext. 29 from ringing on all incoming calls?
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Central telephone Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Oct 26, 2010 | AT&T Lucent MLS-12D Phone
How do I set phone to ring at my extention?
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Dec 01, 2009 | AT&T Lucent MLS-12D Phone
Change Auto Attendant message to Rollover Calls to Ext. 10 and 15
**use with care ** if it is a "Partner System" here you go. if unsure do not do this. it is simple but one wrong keypress will cause ... mmm problems. so just hang up if unsure. dial intercom 777 , then * to get main greeting, if ok then * again then enter extesion should be prompted. press 0 # then password , default is 12345678 #. if it is good dial 9 (administration) then 3 (auto attendant) then 1 , 1, 6, * , # then 1 to record and follow prompts.
Oct 10, 2009 | Lucent PARTNER18 Corded Phone
Instruction on how to divert incoming calls to a mobile.
hey c'mon please let the receptionist go after you have finished , why you want her with you?
May 20, 2009 | Panasonic KX-T7630 Corded Phone
Kxta824 disa help
Your system has 3 modes of operation, day, night, and lunch. Lunch doesn't have to be a specific time, and you could manually switch between the 3 modes. Most small customers don't even use NIGHT mode, except to control the voice mail system.
Full programming instructions are beyond the scope of the free forum, but in section 3.1 of the programming tool, you set the mode of the trunks for day/night/lunch. No matter what the status of the auto switching to day/night mode, you can still manually switch to lunch by dialing 782 from any phone, and manually switch back to day/night mode (780/781) to turn DISA mode on or off.
Now, you still can have different OGM's for day and night that will automatically work, and manually use the lunch to control the applicaion of DISA. Even if the receptionist steps away from the desk, you can go into 3.2 and turn on some delayed ringing, or anyone can put the system back in day or night mode.
Carl
Jan 30, 2009 | Panasonic KX-TA824PK Phone
Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
Jan 09, 2009 | Lucent PARTNER18 Corded Phone
Inter-Tel Axxes phone outside calls don't go to voice mail
I had this same challenge with an InterTel 5000 system. Outside calls going right to the receptionist. My solution: You cannot fix this from a phone, you must open the DB Session Manager, move to Call Routing Tables (this is right above Voice Processor) and move all of your extensions above the "NO MATCH" and "EMPTY" lines on the bottom. Anything below those two lines will bypass the extension and go straight to the main attendant. At least in my configuration it does. See below...
bb752dc.jpg By just moving that last extension "5059" above the "NO MATCH" line, calls will now go to the extension from an outside caller. The trick is to hold your mouse on the pen icon and click several times to activate that line, then you can drag it to where you want. See below...
8e5e1dd.jpg Hope this helps someone?
vandata1
Sep 27, 2007 | Inter-Tel Axxess Corded Phone
NEC DTU 8D-2 Corded Phone Logo
99 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
