Question about Philco (R) Suitcase CD Shelf System
Turntable will not turn
The motor that moves belt will not operate. Power is on when switch is on phono and needle will "scratch" but turntable motor does not power up on any speed. CD works ok.
  • 104 Answers
Spin the motor between your fingers, sometimes they develope a 'dead spot' if it comes to life let it run for a few hours, this may fix it forever.
Posted on Feb 12, 2009
  • Tom Sherlock
    Tom Sherlock May 04, 2014
    Where is the motor?
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
How do i get it to work? sorry but this is my first time using a record player
most of today's receivers dont have the jacks for phonos...you will be able to plug left/right plugs into aux/cd (unless you are using a power amp) . is your phono equipped with the needle (cartridge) also? yes, then you are ready to play a LP/Album...turn volume down on amp or receiver place LP onto turntable needle on switch source selector to what you plugged into turn vol up slowly and enjoy
Aug 13, 2010 | Aiwa PX-E860 Turntable
Turntable will not rotate when in "Phono" mode
I recently was given my Father's CR78CD and, assuming your unit is in working order, you turn on the turntable motor by lifting the tonearm off the post and moving it away from the turntable about one and a half to two inches. You should hear a soft click as the switch for the motor activates.
Jun 20, 2010 | Crosley CR78CD-P CD Shelf System
Turntable not turning, no belt problems.
From your post, It seems that the motor is not working.
Could be a dead motor or related power supply.
Sep 12, 2009 | Crosley Audio Players & Recorders
My turntable does not work. Is there a lock ?
Try this - GENTLY move the phono arm to the RIGHT until you hear a click (of course, do this after you turn on the power via the volume dial and set the other dial to"phono"). Doing this turns on the turntable when you haven't used it in awhile. This worked for us, hope it works for you.
If it doesn't work, you can check the belt by removing the tiny clip at the center post and gently lift the turntable platform/tray to peek at the motor and belt underneath. The pulley is on the right at the 2 o'clock position, the belt should be in contact with it.
Aug 05, 2009 | Crosley CR248 Turntable
Turntable does NOT turn.Crosley CR66 vintage Radio and Turntable
Try this - GENTLY move the phono arm to the RIGHT until you hear a click Tof course, do this after you turn on the power via the volume dial and set the other dial to"phono"). Doing this turns on the turntable when you haven't used it in awhile. This worked for us, hope it works for you.
May 27, 2009 | Crosley Audio Players & Recorders
Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
Turntable wont spin
If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
Mar 10, 2009 | Technics SL-BD22 Turntable
Stopped turning
Try removing the cover and looking for a broken belt. Make sure that the motor is spinning too. If you find a broken belt, let me know and I'll help you find a replacement.
- Jim
Jan 28, 2008 | Teac SL-A100 Turntable
Philco (R) Suitcase CD Shelf System Logo
211 people viewed this question
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
jason
Steven Wander
Steven Wander
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
