Question about Mtd Products Yard Machines 158CC Tiller
Replace spark plug boot and wire on model 2m1 snow thrower
3 Suggested Answers
2strokeguy
  • 183 Answers
SOURCE: I have an MTD Snow Thrower Model 2M1 with a broken
When you have the starter top removed, you must wind the spring BEFORE installing the rope. Wind the pulley until it is at maximum tension, then unwind it until the hole in the pulley lines up with the eyelet on the starter top. Now, put the rope thru the eyelet and into the pulley hole. It is helpful to have somebody holding the tension on the pulley, or you can insert a small tool thru the vent holes to hold the pulley in place. Use a figure 8 knot on the rope. Go ahead and tie the handle onto the other end of the rope, and release the pulley tension. It should now recoil into the starter housing. Test pull the rope several times to make sure it is moving freely. Reinstall the starter housing onto the engine and retest.
Posted on Dec 01, 2010
  • 277 Answers
SOURCE: The recoil starter rope snapped on my MTD single
you have to wind up the pully before you install the rope.
then when you put the rope on it will wind itself back in the case
Posted on Feb 20, 2011
Spark plug location
My 8 horse Craftsman blower has the spark plug right on top of the engine.
Jan 21, 2014 | Craftsman Sears Snow Thrower Manual Model...
Carb adjustment and what is the correct spark plug
If the snow thrower worked last year I would suspect old fuel in the tank. Dump out the old fuel in the tank and put in fresh. Put a squirt of starting fluid in the carb and try to start it. If it fires the ignition is good. Do this a few times to pull the old fuel through the carb and fuel line. When the new fuel gets through the fuel system to the engine it will stay running. The spark plug in the engine will have number on it. Get one with the same number if you want to replace it.
Dec 10, 2013 | Craftsman Sears Snow Thrower Manual Model...
I need to know what spark plug to use for my snow thrower. My son lost the one I had taken out to be replaced.
If snow thrower uses ordinary gasoline, then go to hardware store and get spark plug for lawn mower.
If snow blower uses 2-cycle engine oil mixed with gas, then get spark plug for weed eater.
Or buy both and try them out.
Hardware store is more likely to have someone familiar with which spark plug you need than box-size home center.
http://www.toro.com/home/customercare/interactivemanuals.html
Dec 26, 2010 | Garden
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
I have a craftman snow thrower, model#536.886122, serial#632722946 and I'm in need of a manuel.
Manuals of Sears products are available through their 'Parts Direct' system and have been resonable in price. The last one for a riding mower cost ~$7.00
Sep 21, 2009 | Tools & Hardware - Others
My snow thrower wont start
Change the spark plug being sure to set the spark plug gap as recommended in the owner's manual. Then clean or change the air filter. Finally use new high test gasoline. good luck.
Jan 12, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
Jan 11, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Mtd Products  Yard Machines  158CC Tiller Logo
88 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
