Question about Cameras
I have a Canon EOS Rebel Digital and it won't turn on. I've replaced the battery, cleaned the metal parts of the battery ad it won't turn on. When it first stopped turning, when I would click the the
    Novelist:
  • Cameras Expert
  • 357 Answers
Probable cause is a screw that has come loose and is floating around inside. It probably has blown the P fuse on front board. If you are unlucky, it has shorted out the flash board and taken down multiple boards in the camera. It all depends upon where you find the screw. Usual screw is the one at the bottom right of the rear board.
Posted on Jan 12, 2013
  • 164 Answers
SOURCE: Canon EOS Digital Rebel XT will not connect to computer.
Please discard that the USB port or the USB cable are defective. You can do it if you try to hook your camera in other personal computer using the same USB cable. If it works, then follow the next instructions.
Connect your camera to the PC thru the USB cable and turn it on.
If you are using Windows, go to the Control panel - System - Hardware - Devices - and check if there is any device that was not recognized by Windows. Such devices are marked with a yellow question mark.
If so, get into the device item and with right mouse click, select to update the device driver.
If there was not unrecognized device, then you can unistall your USB port driver and then run a change hardware status to recognize the USB port again, then run the update driver routine.
Regards,
Posted on Aug 25, 2009
SAFFOTO
  • 77 Answers
SOURCE: Canon EOS Digital Rebel XT will not turn on.
It could be a number of things. The first thing you shouild do is remove the back cover and check for loose screws. If you don't find any, the problem may be a damaged battery door switch, a damaged memory card slot door switch, or worse- it may be a defective power board.
Posted on Feb 03, 2010
Obertelli
  • 3006 Answers
SOURCE: Camer won't turn on.(Cannon EOS Digital Rebel XT)
A dead camera is impossible to tun diagnostic checks on without specialist tools, so yes, your camera will need to go to a Canon service centre for diagnosis and an estimate. If you decide not to go ahead with the work then you'll be charged for return shipping and a fee for the work carried out to make a diagnosis.
If the warranty expired fairly recently, then it may be worth contacting Canon before getting the estimate: it's not unknown for them to offer goodwill repairs for major faults which occur prematurely, but you need to be aware that your model was only designed with an approximate four year minimum lifespan.
Posted on Mar 10, 2010
Joshi_Z
  • 567 Answers
SOURCE: Camera launcher exe has stopped working my
I have two suggestions for this issue.
First, check the properties of the shortcut icon that you are using to launch the app.
It should be:
"C:\Program Files\Eagle Dynamics\Ka-50\bin\stable\Launcher.exe" --console
Start in:
"C:\Program Files\Eagle Dynamics\Ka-50"
In case this does not resolve the issue, un-install the program.
Then when you reinstall, please ensure that you install it in the non-default directory.
If you require any further assistance, please comment and let me know, and I will be happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Posted on Mar 07, 2011
  • 11967 Answers
SOURCE: Well, I'm plugging in my
Pros avoid this very common problem by using a separate card reader instead of the camera for downloads. typrice_208.jpg
Posted on Jul 05, 2011
Battery door latch broken
look for a Canon eos 300D battery door (they are the same camera just came out in different countries) or buy of ebay a cheap broken 300D and salvage the parts that way.
Mar 21, 2013 | Canon Eos Digital Rebel Ds6041 6.3 Mp...
My rebel t1i eos 500 built in flash won't pop up
Hi, I have to Canon Rebel t1i and I had the same problem (built in flash not working). I tried a number of remedies I found on forums etc but none worked. I then tried this. In the external flash housing is a metal sprung plate which surrounds the five circular pins (one big, four small at the rear). If you get a small straight headed screwdriver and lift the front of this plate and at the same time pull it back towards you it will come out altogether.
I then removed the four small screws being careful not to drop them and took off the mount for the external flash and then tried the flash it opened straight away. I then cleaned all the area of the mount and the two plates and replaced them all ensuring I fitted them exactly as before. I then checked the camera again and presto working fine. I hope this helps everyone with the problem.
Kevin (East riding of Yorkshire)
Aug 12, 2012 | Canon EOS 500D / Digital Rebel T1i Digital...
Canon rebel lcd screen will not turn on
If you need help to disassembly clean or repair errors or fix this camera you can download the official service manual from below link:
CANON EOS 350D / KISS DIGITAL N / REBEL XT SERVICE & REPAIR MANUAL
http://www.tradebit.com/filedetail.php/112818927-canon-eos-350d-kiss-digital-n
Jan 01, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Rebel XS was working fine... yesterday, all of a sudden, the LCD screen went blank and it displays 'busy' when trying to take a picture. Recharging the battery and replacing the sd card didn't change...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Nov 30, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
How can I solve an error 99 problem in my Canon Rebel xs
I hope that helps.
Aug 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Error 99 comes on after I have taken a few pictures. I have tried cleaning with eraser as people have done and it still comes up with message.
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
Jul 14, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
My canon rebel xti will not turn on. I have replaced all the batteries, and still nothing starts up.
There could be dust or other foreign objects in the battery slot, you might need to clean it out. If not, I would advise that you may need a replacement battery
Mar 01, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel focus
I would only suggest you might clean the metal contacts on the inside rim of the lens....just be very careful what you use....a pencil eraser is good but make sure you clean away any shavings that might get into the camera...
Sep 27, 2007 | Canon Digital Rebel / EOS-300D Digital...
Cameras Logo
132 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
