Question about Pride Mobility Products Casual CL30KD Lift Chair Chestnut
Chair will not go up or down
I hear a clicking sound in the control box when the paddle switch is pushed up or down but the motor does not try to operate.  The up or down operation was sluggish or weak for a while and then operated okay for a while. This sluggish operation repeated a couple of more times but now the chair will not move at all.  I checked the 9 volt batteries and they are okay.
  • 118 Answers
The clicking is the mechanical part of the switch, but the electrical part may still be bad. In all the chairs I have serviced, it has always been the switch. The switch itself goes for about $25 plus labor to change it, and the whole control unit retails for about $100. the best test is to take the controller apart and short out the center wire to either side and check the chair for movement.
Posted on Jan 26, 2009
  • mary l beddow Aug 31, 2013
    my chair wont go up
The solution that was posted, that the hand switch probably was bad, was correct.  I tested the chair by shorting across the switch leads as suggested and the chair worked.  In took the switch apart and cleaned the contacts and the chair now works as intended.  I really appreciate the help.
Posted on Jan 30, 2009
Lights flashing when turned on, replaced batteries,fuse, in drive position
the amount of flashing lights will give you a Flash code. If the the lights are going up and down, you may have a locked joystick. one method is to turn on and (within 10 sec.) push the horn button twice. Push the power button then push the joystick forward until there is a beep sound then back until you hear a beep sound to unlock.
Mar 30, 2016 | Pride Go Chair Power Chair
I have a American Standard Corner Whirlpool Year 10-10-03 Model 752857-300 When I push down The air switch button down The whirlpool come on But when Push again it will not cut off I check hose going to...
t sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Sep 27, 2013 | American Standard Home
Issues with Streamer Sport Model 888WA power chair
please can you tell me how ofter the light's flash ? does there appear to be some kind of sequence ?
Dec 09, 2012 | Shoprider Streamer Sport Power Wheelchair...
My power chair runs but wont move.
re-engage the motors look for two levers one on each motor and move them to locked position
Oct 21, 2012 | Golden Technologies Alante' Power Chair
Hi, Just replaced two batteries. Chair powers on but I just hear a click sound when I push the button to move chair. please help. thanks.
The fact that you just replaced the batteries indicates a battery problem that has been solved. Please make sure the new batteries are fully charged. The fact that the power wheelchair powers on is an indicator that the VSI controller (joystick) is working. When you move the joystick forward you will hear a click sound from the motors and electromagnetic brakes. The click is the brake being released by the electromagnetic solenoid. If you have a flash code on the controller and the chair does not move you can look up the flash code using the following link:
This motor/brake problem is typical for the Aspire and can usually be traced to the large connector at the back of the power chair. Pull out to disconnect the 8 pin connector and disconnect the 3 pin molex plug. Inspect and clean with electronic contact cleaner the silver pins until they are shiny. Spray clean the plugs. Work the plug in and out to clean the inner contacts. If the chair now runs you have traced the problem to the main harness receptacle and the VSI controller plug. The only cost effective repair of the the main harness receptacle is to replace it. The VSI plug is can be cleaned several times before it needs to replaced or the controller rebuilt.
If you need to replace a motor/brake assembly you need to contact a qualified technician who can troubleshoot further with a PP1 programmer to read the fault code history log. The technician will also have a digital voltmeter to verify your motor/brake problem. In my experience, the motor/brakes can last up to 3 years depending on use. The wiring harnesses at the rear location are easily hit and are usually more problematic because of their location, collecting dirt, moisture, and corrosion. Hope this helps,
Nov 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
I have a fairly old 1121 but cannot find any levers to go into freewheel. I have seen a modern one and can see them in that. Can you help?
Jackie I looked on the Pride Website and threy showed them behind each drive wheel above the motor facing the rear of the chair. Lift to place in freewheel and push down to engage. I hope this helps you
Oct 12, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Bought brand new batteries. have power, but chair will not move. Chair been out of use for approx 5 years.
Zim When you turn the power on and all the lights on the battery level are lit and you move the joystick forward Do you hear a clicking sound coming from the motors? You are not getting any flashes on the lights? If you don't hear the electric brakes energize or click when you move the joystick then they are probably stuck to the motor housing. Try putting the chair in freewheel and trying to push it like a manual chair. It should roll freely. If it doesn't then the brakes are stuck and you won't get any sort of error code. I don't know what brand of chair you have so I can't tell you what steps to take to free up the brakes. Try rocking the chair back and forth to freeup the brake pads when you have it in freewheel If you are mechanically inclined you can take the brakes off the back of the motors and try to unstick the pads but be careful not to break the wiring from the motor harness to the brakes. Let me know if this helps
Sep 11, 2010 | Health & Beauty
Re: Pride Jazzy 1103 Ultra. Chair is acting like the seat is still elevated and the speed is set to slow (with indicator light flashing). Please let me know what should I be checking?
When the power seat lift lowers down, there is usually a bracket that pushes a button under the seat that tells the motor the seat is lowered and the power chair is safe to operate. Sometimes the bracket can get bent and the button does not get pressed when the seat goes down. Check under the seat around the seat post for the button and make sure the bracket is connecting to it. Carefully bend it back into place if it is not hitting the button properly. If the bracket came off, it will need to be replaced.
Aug 25, 2010 | Pride Jazzy 1103 Ultra Standard Power...
How to push the jazzy wheel chair when power fails''
There are two levers located on the base of the chair on the left and right sides. Depending on the model, they will be located on top of the base on the front section of the chair base, or on the rear or on the lower sides. Most rotate 90 degrees to disengage the gears so you can manually push the chair. Others are moved up and down, or in and out. Return them to the locked position when done.
Jul 01, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Pride Mobility Products Casual CL30KD Lift Chair Chestnut  Logo
2,617 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
