Question about First Tech HONDA-SL3 Fortin Data Bypass Kit with Data Port - Self Lea
I just hooked up a remote start in my 2002 acura el (civic) and all was working fine so i unhooked the Honda SL3 bypass so i could hide the wires and now it does not not work. The car will crank when the key fob is pressed, all other functions work. I tried to program the bypass again but it still won't start. It will start with a key in the ignition in the off position when the fob is pressed. Is there any way to get the bypass to work again???
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 105 Answers
You have to flash the module with a flash link updater
Posted on Jul 16, 2015
3 Suggested Answers
MECP Guy
  • 344 Answers
SOURCE: I installed a Bulldog remote starter RS28B. I can
The wire you are looking for is blue and it is under the driver side dash plugged into the security module
Posted on Jan 08, 2010
krishna pokh
  • 4 Answers
SOURCE: 2004 honda civic will not
hello frnd
adapt key with immobilizer and ecu.if not solved check wiring of ecu immobilizer and ignition starter switch.
thanks
Posted on May 11, 2011
1996 honda 160i luxline remote imobilzer programing
reset immobiliser I HAVE A HONDA CIVIC 1.6 LUXLINE ...
www.fixya.com/cars/t23058317-reset_immobiliser
Jan 22, 2014 - reset immobiliser I HAVE A HONDA CIVIC 1.6 LUXLINE 1998. I NEED TO BYPASS THE IMMOBILSER TO START THE CAR WITHOUT IT ... Press any button on remote one time within 20 seconds. .... How can i fix my honda 160i luxline92 model starting difficulty? Jul 20 ... Jun 09, 2012 ' 1996 Honda Civic.
Sep 27, 2015 | Honda Cars & Trucks
Tip
How to install a subwoofer and amplifier
When installing any electrical components always remember to unhook the battery. First thing you want to do is run your ground cable from a volt meter to a body or frame nut or bolt near by in the trunk or hatch area a shorter thicker ground is best then connect the other end of your volt meter to your battery cable that will need to be run through the firewall and connect to the positive battery terminal. Also VERY important make sure you have installed a fuse on the wire in between the amp and the battery. after you have connected the battery cable and ground to your meter it will light up or give you the correct reading for your ground, if not run the ground somewhere else until you have found the right spot. pull out your stereo, for stereos that are made to be compatible with an amp there will be multiple rca jacks in the back of the stereo. For a sub woofer you want to hook the rca cable to the rear or sub labeled rca jacks. Then run your amplifier remote wire to the remote wire protruding from the back of your car stereo. After that you can run the ground and battery cable to the correct slots. Now connect your sub via rca and your done. making it fit correctly is up to you. If you do not have an amp with a subwoofer out then you can take the wires from your sub and bridge the connection to your amp and get enough power, take the positive wire to your sub and hook it up to the positive terminal of channel one on the amp then take the negative wire from your sub and hook it into the negative terminal on channel two and your done.
keywords: subwoofer, fuse, wiring, car audio, car , car audio install, speakers, dvd player, in dash, acura integra gsr del sol honda civic itr ls b16 hatch coupe jdmkey words: honda acura integra gsr itr jdm del sol coupe hatch ls si boosthonda, acura, civic, crx, si, hx, two door, integra, DA, EF, EG, EK, DC, DC2, DC4, hatchback, four door, GSR, LS, GS, RS, EX, DX, VX, engine, transmission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15,key words:VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, integra civic, b18, turbo spoon,JDM,EK9,da6,eg,civic,HB,honda,acura,turbo, acura Honda Civic Integra EG6 EK9 EK4 DB8 DC4 ITR CTR civic honda jdm integra ls gsr b16 b18 civic si crx k20 swap hatch coupe lx eg ek ef b20 accord prelude sedan trade sir type-r lsd b18c5 b18c1 turbo supercharger b-series integra da dc eg ek ex gs rs ls gsr lsr rs si sir sirg wanted prelude accord transmission eg ef ek em ep civic integra del sol s2000 s2k rsx accord gsr type r itr ctr vtec v tec honda acura blades ls mesh rota volk 4 lug 5 lug b16 b18 h22 h23 b20 k20 d16 d15 b series h series d series turbo all motor eg ek da ef crx dc2 dc5 dc em ej ap1 f20 prelude jdm edm ukdm doch b18a b18 b18c1 b18c5 rota rsx integra DA ef eg ek hx rims si rims gsr blades ls distributer distributor rota rotor aem injen akimoto parts works obx hatchback honda acura integra ls rs gs gsr type r civic dx cx ex hx lx si crx hf del sol oem jdm da da9 da6 db dc dc2 ef ef8 ef9 eg eg6 motor integra da dc eg ission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, suspension, break, brake, greddy, tanabe, cusco, zex, nos, turbo, drag, hks, aem,subwoofer powered subwoofer subwoofers svs subwoofer
home subwoofer car subwoofers best subwoofer subwoofer cable
subwoofer reviews car subwoofer klipsch subwoofer subwoofer wiring
home theater subwoofer yamaha subwoofer subwoofer amplifier
jbl subwoofer subwoofers for sale jackhammer subwoofer subwoofer boxes
hsu subwoofer sunfire subwoofer kicker subwoofers pioneer subwoofers
subwoofer car audio car audio subwoofers powered subwoofers
cheap subwoofers home subwoofers 15 subwoofer
subwoofer placement computer subwoofer active subwoofer
velodyne subwoofer mtx subwoofer kicker subwoofer subwoofer box
infinity subwoofer home audio subwoofers
car speakers and subwoofers
cheap subwoofer
home theater subwoofers
rel subwoofer
wireless subwoofer
jbl subwoofers
10 subwoofer
subwoofer speakers
8 subwoofer
bazooka subwoofer
subwoofer enclosures
custom subwoofer boxes
on Jan 28, 2011 | Honda Civic Cars & Trucks
Any problems with acura 2004 ?
According to repairpal: "Honda and Acura Recall Multiple Vehicles Due to Excessive Air Bag Inflator Pressure RepairPal Expert Overview: Honda has recalled 2001-2003 Civic, 2002-2003 Civic SI, 2001-2002 Accord, 2002 CR-V, 2002 Odyssey, 2003 Pilot, 2002-2003 Acura TL, and 2003 Acura CL vehicles because the driver's side air bag inflator may produce excessive internal pressure. This could cause the inflator to rupture if the air bag deploys. Metal fragments may pass through the air bag material and cause injury to vehicle occupants. Dealers will replace the driver's side air bag inflator.
Models: Acura CL, Acura TL, Honda Accord, Honda CR-V, Honda Civic, Honda Civic Si, Honda Odyssey, Honda Pilot Body, Interior & Misc., February 26, 2010 Honda Recalls 2001-2003 Vehicles Due to Excessive Air Bag Pressure RepairPal Expert Overview: Honda has recalled 2001-2002 Civic, Civic SI, and Accord vehicles and 2002-2003 Acura TL vehicles because the driver's side air bag inflator could produce excessive internal pressure. This may cause the inflator to rupture if the air bag deploys. Metal fragments may pass through the air bag material and cause injury to vehicle occupants. Dealers will replace the driver's side air bag inflator.
Models: Acura TL, Honda Accord, Honda Civic, Honda Civic Si Body, Interior & Misc., August 31, 2009 Acura Recalls 2004-2007 TL Models Due to Power Steering Hose Leaks RepairPal Expert Overview: Acura has recalled certain 2004-2007 TL models because the power steering hose may leak onto the extremely hot catalytic converter, which may cause a fire hazard. Dealers will replace the power steering hose with a new heat-resistant design.
Models: Acura TL Suspension & Steering, April 28, 2008 Acura Recalls 2004-2005 TL Vehicles Due to Corrosion in the Wiper Motor Housing RepairPal Expert Overview: Acura has recalled 2004-2005 TL vehicles because the wiper motor may stop working. Water may enter the wiper motor breather port and cause corrosion, which may cause the electrical circuit in the wiper motor to fail. Dealers will replace corroded wiper motors and modifications will be made to prevent water from entering the existing or new wiper motor.
Models: Acura TL Body, Interior & Misc., April 28, 2008 Honda Recalls 2005-2006 Models Due to Faulty Fuel Pump Relay RepairPal Expert Overview: Honda has recalled 2005 Accord, Odyssey, Acura RL, TL, TSX, and 2006 Ridgeline models because the fuel pump relay may fail. This can prevent the fuel pump from operating, which may cause the engine to stall or not start. Dealers will replace the fuel pump relay.
Models: Acura RL, Acura TL, Acura TSX, Honda Accord, Honda Accord Hybrid, Honda Odyssey, Honda Ridgeline Engine, April 2, 2007 Honda Recalls 2006-2007 Models Due to Incorrect NHTSA Contact Information in Owner's Manual RepairPal Expert Overview: Honda has recalled 2006 Accord, Civic, CR-V, Element, Insight, Odyssey, Pilot, Ridgeline, Acura MDX, RL, RSX, TL, TSX, and 2007 Honda Fit vehicles because the contact information for the National Highway Traffic Safety Administration (NHTSA) is listed incorrectly in the owner's manual. Honda is contacting dealers and customers to provide them with a postcard containing the correct information.
Models: Acura MDX, Acura RL, Acura RSX, Acura TL, Acura TSX, Honda Accord, Honda CR-V, Honda Civic, Honda Element, Honda Fit, Honda Insight, Honda Odyssey, Honda Pilot, Honda Ridgeline Body, Interior & Misc., August 2, 2006 Acura Recalls 2006 TL Vehicles Due to Loose Front Air Bag External I"mpact Sensor Bolts RepairPal Expert Overview: Acura has recalled 2006 TL vehicles because the bolts that mount the front air bag external impact sensors may be loose. If the sensor bolts fall out, the sensor may not function properly, which may prevent air bag deployment in the event of an accident. Dealers will inspect and re-torque the front air bag external impact sensor bolts.
May 07, 2015 | Health & Beauty
Honda civic 1995 gapping
Spark plug gap is .044" of an inch. Hope this is what you were talking about.
Feb 22, 2015 | Honda Cars & Trucks
When installing my remote start, car die when I press unlock button on the remote
the problem is you. (sorry, but it sure is)
you cut up your cars primary wiring and wonder why it wont start?
worse yet, no plan, no factory drawing of stock wiring with your
cuts, and jumps and mods. so , how on earth can any one help here.
no way.
does your car have an Immobiizer option? and you want to fool it
you do know it can tell you are stealing the car, that is
you mimic the theft with remote start hacks.
first learn how the car works, then hack it, if must.
see?
most immo's monitor doors, and illegal starter hot wiring.
i bet the IMMO lamp glowed and told you its, Immobliziing.
did it? (called theft LED in dash gauge)
the systems are complex there , IMMO, ECU, keysystem. etc.
if serious on making this work , join a real real honda civic forum
and post how to put in remote start on your 02,
it can be done i bet,but it may kill the IMMO feature. whole or in part.
Dec 12, 2013 | 2002 Honda Civic
Honda civic 2001 shakes only at start up
Tune up. sounds like a cylinder is not firing up upon ignition. try new plugs and wires
Nov 11, 2013 | 2002 Honda Civic
Why my drl light is blinking and stop and few second start again for acura el 2004
DLR can be tricky,did you know many cars cut it out for other bad conditions.
1: charge lamp glowing. (it cuts DLR to keep the battery from discharging fast and stalling engine.
2: some even monitor oil pressure. and overheat.
im not looking yours up, lazy today.
but it's in the FSM. all this. see DRL lighting, (canada common)
http://hondatech.info/downloads/Auto/Manuals/Civic/
Sep 04, 2013 | 2002 Honda Civic
My car alarm is preventing my car from starting w/ a dead battery
check remote batt..if that dont work unhook car batt for 24 hrs. should reset
Nov 29, 2009 | 2001 Honda Civic
97 honda civic remote broke key sets off alarm and car will not start,cant start car to bring to dealer to program a new remote
try to unhook the battery cabels and do the process over again and if that dont work then turn key all the way to the forward possition and have some one jup the starter by arking metel on the positive termenal on to metel
Nov 17, 2009 | 1997 Honda Civic
Main computer problem...starts briefly but will not run
Sounds like a bad install and the wiring might be crossed. But as they stated, without schematics, it's hard to know which wire is which. Acura should cooperated if the Honda dealer is authorized. Mention "small claims court" and see how fast they cooperate. BTW, the MDX and Pilot share alot of the schematics. i don't know why Honda can't play with it. I believe they don't want the liability.
Mar 06, 2009 | 2002 Acura MDX
First Tech HONDA-SL3 Fortin  Data Bypass Kit with Data Port - Self Lea Logo
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Spud Howell
Charles T Nevin
Charles T Nevin
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
