Question about Logitech Laptop Speaker Z205 2 Speakers
Logitech speakers z205 won't work with laptop
The speakers are plugged in and I can hear static coming from them so I know that the problem must be with my laptop (I have windows 7). The speaker icon in the lower right corner has a red 'x' next to it and says "no audio output device is installed." I'm unable to open up volume controls, all that I can get is playback devices and sounds. Tried going through 'sounds' and 'device management' but still can't find anything that will fix it. Trouble shooting says the device is disabled, but every time I look at the properties of the speakers it says they are enabled. Any ideas?
IrishDruid
  • 2712 Answers
SOURCE: sound from 4 speakers cut off..
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Try these articles as well:
Manual
Setting up the Z5500 with PC, Mac, Xbox, Playstation, DVD Player, etc.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 24, 2008
jazzyboy11
  • 728 Answers
SOURCE: Speakers not working, but cables all plugged in...
You might have to reinstall the software that came with the speakers since you had to wipe your computer clean when the virus was on there. The speakers will not work until the software is installed back on your computer.
Posted on Oct 21, 2008
Arius
  • 446 Answers
the problem is your computer may not sense the presence of your audio device, chances are your driver is either corrupted nor not yet installed.
go to my computer then right click go to properties, hardware, device manager,
under the device manager go to sounds and see if ther is any exclamation icon or anything , expand this icon and see if there is anything you see that has a yellow exclamation or question mark right click that icon and select scan for hardware changes , then update driver , better yet go to sound properties and see if you can roll back the driver, if you have the cd utilities for your computer, you can reinstall the driver again and after all this restart once again your computer
cheers
Posted on Nov 08, 2008
trav1856
  • 57 Answers
SOURCE: x-540 speakers no sound rear speakers
rear speakers are not designed to put out the same output as fronts. They are for supplemental sound only, to make it seem like there's something happening behind you.
Posted on Dec 02, 2008
  • 253 Answers
SOURCE: Z-5300 speaker no sound
You need to install the sound drivers for your PC. go to the manufacturers website, (ex.www.hp.com) and go to the support section, sometimes called downloads also. It will prompt you for your model of PC and what Operating System ( XP,Vista,etc..) and then it will list the drivers that are available. you should update anything in "DeviceManager" that has anything except the "+" sign beside it.
Posted on Mar 30, 2009
I need the schematic for Logitech Z205
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Dec 20, 2012 | Logitech Laptop Speaker Z205
When I turned on the power for my 'Logitech X-240' speakers, there was a loud static noise coming from the speakers. I unplugged the speakers from the subwoofer, and as I began to plug them back...
clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Aug 31, 2011 | Logitech X-240 Computer Speakers
My Z205 worked when I first got it, but now it won't work. I have plugged it into another laptop and it's fine. I have tried all ports but no luck. The light comes on the speaker top so I know that...
If your using windows 7 go to the volume control in the taskbar right click it and select playback devices then make sure the speakers are set as default by clicking the speakers and then click set as default.
May 17, 2011 | Logitech Laptop Speaker Z205 2 Speakers
I recently had to reformat my computer back to factory standards. I had the Logitech Laptop Speakers Z205 b4 this & they worked.After i reformatted now i only get volume out of my laptop built in...
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 31, 2011 | Logitech Laptop Speaker Z205 2 Speakers
I have put the usb cord into the computer and turner the power on. The light is yellow on the side power knob but when I play a videoon my laptop the sound comes out of my computer not the speakers?
Right click the speaker in the lower left hand task bar select "open volume mixer" make sure the line out volume is not muted and turned up. Mute the PC speaker.
Hope this helps.
Zeppelinx12
Mar 08, 2011 | Logitech Laptop Speaker Z205 2 Speakers
My webcam works fine but the microphone crackles all the time
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Feb 01, 2009 | Logitech Webcam
No sound from computer speakers
Make sure that you have the speaker plugged into the GREEN jack on the back of the computer or sound card. If they are not color coded then make sure it is plugged into the speaker out. Pink is for the mike and Blue is or plain is for input. You probably already know this but sometimes it helps to know if your not sure. Hope this is of some help. Bud
Jan 02, 2009 | Logitech X-540 Computer Speakers
Static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Jan 01, 2009 | Dell A215 Computer Speakers
Logitech Laptop Speaker Z205 2 Speakers Logo
82 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
