Question about Refrigerators
Frigidaire refrigerator model FRCO5L5DWO I defrosted it and it will not come back on
22yooper
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
VtToolMan
  • 704 Answers
SOURCE: where is defrost timer located on frigidaire
I couldn't pull up a line drawing for this model, but I recall that on these, (and other fridges of this age and era) had the defrost timer mounted under the front edge of the fridge, just behing the toe kick panel.
Some manufacturers mounted them at the rear behind the thin paperboard "cover", but I'd look for it at the front first.
In either location, it should be mounted behind a metal plate with a small hole in it that has a plastic or metal adjustment shaft that a flat bladed screwdriver slips into to manually advance the cycles.
Just remember to unplug the fridge before you disconnect the timer or attempt to replace it. Once you're done, you can advance the timer to initiate the defrost or cooling cycle, to gets things going.
Hope you find this Very Helpful and best regards!
Posted on Aug 21, 2009
milten1
  • 1304 Answers
SOURCE: my frigidaire refrigerator keeps defrosting on the freezer side
sounds like a bad defrost timer
or depending on the model a bad
electronic or adaptive defrost board
Posted on Oct 08, 2009
heatman101
  • 43501 Answers
SOURCE: Frigidaire Gallery Model FRS26ZSHB3 The
There are two things that could be happning....
1. The control is bad and when you manually turn it it will close and start the unit, but it will not close after it opens to stop the unit on it's own....
In other words... you touching it and moving it will get it to work, but it will not turn the unit on if there is no outside influence on it....
The possibility is that the compressor will not restart when warm...but once it cools down it will restart....
I don't think this is what is happening though... my bet is with the thermostat/control...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Mar 12, 2011
  • 1891 Answers
SOURCE: My frigidaire refrigerator model number
ck the heater / and the defrost terminator . . I would change both . . mm
Posted on Sep 19, 2011
Our Frigidaire refrigerator freezer is not working properly--The freezer is working fine,but the refrigerator is not coolig--I can unplug the refrigerator and let it defrost for a few hours and it wil
Sounds like clutch one or more of your defrost components have failed. Defrost heater, defrost thermostat, and defrost timer or board depending on model are the 3 components
Nov 11, 2017 | Frigidaire Refrigerators
How do you put your refrigerator on defrost mode
Hey friend, thank you for the post!
From my understanding you are trying to set your Frigidaire refrigerator into defrost mode. In order to be able to provide you accurate information on how to do so could you provide me with your model number please? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side in a top mount. But on a side by side and a French door refrigerator it can be found on the right hand side. I look forward to hearing back from you. -Matt
Jul 22, 2014 | Frigidaire Refrigerators
Frigidaire refrigerator leaking
Good Afternoon Friend,
I understand that there is a frost build-up on the back wall of the freezer portion of your Frigidaire refrigerator. I also see that there is water leaking onto your floor from the front of your appliance. What you are describing is a possible frozen evaporator, and the freezer needs airflow to work properly. You need to completely defrost the freezer. If your appliance starts behaving normally after defrosting then you need to monitor it closely, as it will sometimes start frosting up again. If it does fail again then it's possible you have a defrost problem. Possibly the defrost heater, but can also possibly be the defrost timer or defrost sensor. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave me your model number. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire Refrigerators
Model #FRS26R4CBB
Hi Friend, this is Z. I am happy to assist you!
I show that the defrost timer for the above-listed model number of your Frigidaire refrigerator has a defrost control board (ADC - Automatic Defrost Control). This can be found in front of the damper. I hope this information proves useful.
Jun 04, 2014 | Frigidaire Refrigerators
Location of defrost timer on frigidaire model lfus2613f3
Hello Friend, thank you for allowing me to assist you!
It appears that the defrost timer of your Frigidaire refrigerator (LFUS2613F3) uses the main control board to energize defrost. The defrost timer is located at the front of the control console in the fresh food compartment (display that controls all functions). I do hope this information proves to be helpful! - Z
Jun 04, 2014 | Frigidaire FRS26KR4A Side by Side...
Where is the defrost relay button?
Frigidaire equips most of its refrigerator models with automatic defrosting capabilities. This means that owners don't have to set a calendar reminder to manually defrost. The internal automatic defrost control and timing mechanism is placed at the bottom of most Frigidaire refrigerators, next to the stationary panicon1.png that captures water - even the defrosted meltwater is automatically evaporated. You might be confused about how the defrost timer works, thinking it is broken. Frigidaire understood this might be an issue for some owners and suggests double-checking the defroster for normal operation because it may not be malfunctioning at all.
Read more: http://www.ehow.com/how_12165725_troubleshooting-frigidaire-defrost-timer.html#ixzz32x8RyDGe
May 27, 2014 | Frigidaire Ffhs2622mh 26 Cu. Ft....
Where is defrost timer location on fridgedaire mod # ED25DQXVN00
Your mechanical defrost clock timer is located in the control panel where the rotary knobs are for the ED25 model given which is a Whirlpool SxS, For the Frigidaire Mod FRS, your defrost control will most likely be located in the long housing running down the center wall (front to back) of the fridge near the outlet vent, this is an electronic adaptive defrost control. Pleazer Appliance...
Apr 18, 2014 | Frigidaire FRS26KR4A Side by Side...
My frigidaire refrigerator keeps defrosting on the freezer side
Oct 08, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Electrolux side by side refrigerator
this uses a adaptive defrost board its located in the fridge compartment in the back left side remove the cover and you'll see the adaptive defrost board if you have any questions don't hesitate to e-mail me @ hvac.tech7872pr@gmail.com
here's an URL of the diagram (copy paste link to your browser)
http://www.partselect.com/Schematics/Frigidaire/XFXTKOQX.gif
Aug 02, 2008 | Frigidaire FRS26R4A Side by Side...
Freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
May 22, 2008 | Frigidaire Refrigerators
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
