Question about Dryers
Replace a nutone 669l bathroom fan - Dryers
  • 95 Answers
SOURCE: Replacement Motor for the NuTone LS80SE Ceiling Fan
https://www.centralvacuumstores.com/nutone/fan-motor-ls-series.php
Posted on Mar 02, 2009
  • 95 Answers
SOURCE: The Fan in my Nutone bathroom light/fan is not working...
It is really easy to change the motor yourself. It is about a 15 minute job. You just need to find your model number and then you can buy the complete motor assembly. https://www.centralvacuumstores.com/model_number_help.php
Posted on Mar 29, 2009
Bat1956
  • 585 Answers
SOURCE: Bathroom exhaust fan 16 years old and noisy. How to fix?
One drop of 30 wt oil at each bearing will quiet the thing for a while, but you will eventually want to replace it. Also consider the whole fan is about the same cost as the motor, and easier to find.
Posted on May 16, 2009
SOURCE: Nutone 665RP fan/light/heater all not working
Hunt for a tripped GFCI and push reset. The ground fault protected receptacle may be in a nearby bedroom, hall, or basement.
Posted on Jan 18, 2010
Testimonial: "THANKS! I brought an electrician in after I smeleled burning and there was bad arcing going on. He rewired it properly and everything is good now. T"
heatman101
  • 43501 Answers
SOURCE: Problems with exhaust fan NuTone Model LS 100SE
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Posted on Feb 28, 2010
NuTone QT80 is not clearing moisture/condensation from the bathroom / 33 cubic square feet / no elbows / about 10 - 15 straight duct length
This should not be a problem. If you think you need a more powerful fan a there is a 110 CFM replacement fan that will fit in the same housing. The NuTone part# is 0696B000. There are some generic versions out there on ebay and amazon that have been causing people a lot of trouble. I would recommend buying from an Authorized NuTone dealer only.
http://bit.ly/8WYtJd
Nov 11, 2010 | Broan-NuTone Dryers
I need the glass for a QT100L Nu Tone bathroom fan
The replacement NuTone lens number is 84449000.
http://bit.ly/bfmiYu
Oct 31, 2010 | Broan-NuTone QT100L Fan
A Bryant 3 way independent rocker switch with red, black and white wires for 3 lights in bathroom one switch not working can i replace it with a Broan Nutone P66V three function control
397bfdd.jpgLeviton triple switch
fe442eb.jpgNutone P66V
Nutone looks like an ordinary three-switch combo being marketed as a bathroom 'fan switch.'
The screws on the device would tell the story.
Look at the Leviton screws:
The switch has dark-colored screw on one side >> the hot from breaker always connects to dark screws.
Other side of switch has 3 silver-colored screws, but these can be brass colored screws > the wires to fan light and heater connect to each of these screws.
Most likely the Nutone switch is identical to the Leviton
I say this because the descriptor on Amazon describes it as a 'fan' switch.
It's being marketed as a bathroom fan-light combo switch >>> so it looks like an ordinary three-combo switch
Oct 28, 2010 | Broan-NuTone P66V Fan Control Switch
How to replace a motor on a nutone model 8663P bathroom exhaust fan
The motor assembly is held in place with tabs and possibly one screw. Remove the light assembly and once you get to the fan itself, unplug it, and push the side of the unit outward to release the tabs. You push the fan assembly up while pushing out on the side. If you look closely you can see the slots where the tabs go. There may or may not be a screw holding it in place. After you release one side, then rotate the fan assembly down and out.
http://coastaltechsupply.com/Direct%20Order%20Pages/Nutone%20Direct%20Orders/Fans/8663P.htm
Jun 06, 2010 | Home
Heatman101
Feb 27, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
NuTone bathroom fan starts slowly after being off awhile
need to blow it out with a air hose and oil it real good! but keep a eye on it to make sure it does not get hot! if it feels hot to touch replace the motor!
Nov 03, 2009 | Broan-NuTone (668RP) Fan
May 16, 2009 | Broan-NuTone N-671R Exhaust Fan Exhaust...
Mar 28, 2009 | Broan-NuTone N-8663RP Combination Light...
Open Questions:
Dryers Logo
399 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
