Question about Panasonic PT-51HX41 51" Rear Projection Television
Panasonic TV Shuts off by itself
I have a 51" projection Panasonic tv (model PT51HX41 about 5 years old) that shut off itself. The only way to reset the tv is to unpluged it and repluged it. Sometimes it works for an hour other times it works for 30 secondes.
This started after I replaced the convergence ICs (STK392-110). Checked all resistors OK. Any ideas?
  • 2 more comments
  • Mick_AA Feb 02, 2009
    I also have a Panasonic
    (model PT51HX41) that shut off itself. Sometimes it works
    for an hour other times it works for 30 seconds. I also replaced the convergence ICs (STK392-110) and the set worked great for about 6 months.
    Now it shuts off anywhere from 30 seconds to several hours. I have notices that it is show how heat related. When the temp in the house is cold it shuts off more often. If it's a warm day and no air conditioner on the set plays for hours with no problem. Thinking may be a bad solder joint ?
  • Anonymous Feb 24, 2009
    Tv Shuts off but will reset after waiting a short period of time. It may work for several hour or a short time.
  • turbocrx321 Mar 07, 2009
    i also have a panasonic(Pt-51HX41E) that turns on then 8 seconds later it shuts off anyone help
  • lbwinstead Mar 20, 2009
    My Panasonic 51" projection TV is also shutting off by itself. If I unplug it and plug it back it, it will turn on for maybe 5 seconds before shutting off again. Will not turn on again without repeating process. Does anyone know why???
I had the same problem , Good sign of a cold solder or cracked trace.
On my PT51HX41 after a long check with a magnifying glass I found the problem on the main board just below the AC daughter board there is a Blue rectangular box (relay R801) and it had two cracked solder joints.
Posted on Feb 22, 2009
My 54" rear projection Panasonic TV is turning off and the TV repairman says that it's the transformer. Right now he is looking for a transformer and said that to keep my fingers crossed. Is getting a...
What is model number? If it shuts off does the power light on the front blink?
Without knowing model number and if power light is blinking or not it is hard to help.
SD TECH
Sep 21, 2010 | Panasonic Televison & Video
Bad color then no power on 51'' panasonic cinemavision
Check the power light for blink code--usually if this model shuts down the power light will blink in a sequence--3 blinks a pause and 3 blinks is short protection--usually means a convergence circuit problem.
Let me know what you find--I am here to help.
if this helped you rate this solution as I do this here for free.
SD TECH
Dec 17, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Power issue
No picture on my Magnavox Big TV RJ8530 S/N 61998120
Aug 06, 2008 | Panasonic PT-51HX42 51" Rear Projection...
TV will not turn back on
had the same problem, I am pretty sure it's the projector bulb is burned out. easy to replace yourself
Jun 04, 2008 | Panasonic PT-53X54 53" Rear Projection...
Panasonic projection tv
call panasonic, bulb blown under warranty for 18 months the bulb is 284.00 just had mine replaced. it's a little over a year old
Dec 27, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-51HX42F
Sometimes, in the Panasonic projection sets, one of the convergence IC's shorts out and draws so much current that one of the resistors next to it glows red hot. The computer senses the extra current and shuts the set back off. This is quite an easy problem to correct, but the set should be serviced by a qualified tech familiar with panasonic projection sets.
Aug 23, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
854 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
