Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE PSS26PSS, freezer not staying cold
Temperature in freezer rises, when you turn the freezer off and on a few times, the fan motor turns and starts working for a few days.
  • 50 Answers
I would replace the evaporater fan motor if it shuts down but you shouldn't turn freezer on and off because you can build a high gas pressure and damage the compressor a better way is to push the door switch in and listen for fan operation. it's possible that you are causing some of the problem by checking operation too often. if you are losing food in freezer you should call factory service and have them look at it because there are too many things that could cause the problem you are having
Posted on Jan 24, 2009
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
Sep 05, 2012 | GE Refrigerators
GE fridge not cooling. freezer working ok. compressor fan not working
This is an odd thing to hear. Normally when the condensor fan (}compressor fan) Isn't running the freezer is the one who's temperature rises and the fridge stays about the same. I would strongly suggest looking at the main control board, just for the simple fact that 9 out of 10 times thats the root of the problem
Jun 06, 2012 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
My GE Profile (PFS22SISBS) freezer not getting cold enough
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Jun 18, 2010 | GE Energy Star PDS22SIS Stainless Steel...
Check to see if the freezer fan is turning. If this fan doesn't work properly, adequate cold air is not moved from the freezer to the refrigerator.
If the fan is turning, you likely can hear it. It should be behind an access plate at the top of the freezer. If you can't hear the fan, remove this plate, and look at it. If it's not turning, you need to replace the fan motor.
Oct 14, 2009 | GE PFS22SISSS Stainless Steel French Door...
My cooling fan does not come on when car is started.both the ac and cooling fan comes on when ac is started
The cooling fan is required to operate when the engine temperature rises above the maximum operating temperature threshold.
After the car is started, it will usually take some time for this temperature to be reached.
Ensure fan runs when fan control temperature sensor switch demands.
Oct 10, 2009 | 1997 Nissan Sentra
GE Refrigerator-Freezer side works fine/Refrigerator side not ok
You most likely have a defrost problem. Check the inside back panel of the freezer. See if there is ice built up. If so, you have a problem with the defrost. 85% of the time, it's caused by a bad heater. It could be the termination thermostat, timer or fan. If the ice is built up. Take the panel out and defrost with hair dryer. If you want, you can now check the heater and termination thermostat. It's a closed switch that opens on the rise. If you fix it your self or not, To save your food. You can replace the panel and turn the fridge back on, it will operate correctly for 3 or 4 days. This will give you time to either get the part and fix it or for someone to get out and repair.
Please rate solution and make it worth the while to summit solutions. Thanks
Aug 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Electrolux frost free fridge freezer
i have the same fridge freezer and the same problem and have no manual can any 1 explain thank you
Mar 31, 2009 | Electrolux Refrigerators
Freezer coils and water in drain tube frozen
check to see if the fan running first, if yes than you may be losing freon. if not , try a new fan motor
Jul 29, 2008 | GE GTH18KBM Top Freezer Refrigerator
Ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
Aug 03, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
98 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
