Question about Mercury P4VM800M7 Motherboard
Sir i have mercury motherboard kvm 800m series sata hard disk or 1gb ram not supporting me
    President:
  • 1,179 Answers
Here is the link for your board specs: http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=644
Make sure your RAM is compatible to what the specs list. As for your SATA hdd make sure it is compatible to the board. A SATA II hdd is not compatible with a mb that only has SATA as they are not backwards compatible. Hope this helps.
Posted on Jan 22, 2009
I have 2 questions:- 1. I have a hard disk of 80GB capacity.I want to augment my storage capacity with an additional Hard Disk of 500GB in the second slot of my CPU.Will my motherboard support that.My...
The motherboard has 2 memory slots with each slot allowing up to 1GB modules of DDR PC2700, DDR PC3200, DDR2 PC2-5300 with a maximum of 1GB per slot. Do not mix RAM speeds.
As for hard drives, the board has the capacity of:
PATA (Parallel) - 2 x ATA100 4 Dev. Max
SATA 1.5 Gb/s - 2
I would assume that the 500GB drive you have is a SATA drive. and the 80GB as PATA. If that is the case, then the two drives would be on different controllers and would work in the system. Typically, it is recommended that the SATA drives is the main hard drive holding your OS.
As always, you would need an open bay in your computer case as well as adequate power to the PWS to complete the installation.
Nov 19, 2010 | ASUS P5VDC-X Motherboard
We need KVM 800M free mother board driver
Hello you can download the driver here:
http://www.mercury-pc.com/downloads_list.php?productid=515
Goodluck
Sep 09, 2010 | Mercury KVM800M Motherboard
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
How much Hard disk my motherboard D845GVSR will support.
There's not really a limit to how big a harddisk you can support. The only thing that can restrict you is the connection, because, for obvious reasons, you can't connect a SATA disk to an old IDE board, but it seems like you're aware of that.
You can just buy any SATA HDD you want!
May 13, 2009 | Intel D845GVSR Motherboard
Dear Sir I want to upgrade my hard disk to SATA 320 GB or SATA 250 GB. But my Motherboard is Intel Corporation D845GVSR and Bios Version is VA84510A.86A.0030.0402160229 System Bus Speed is 533 MHz Sys
No, don't use a convertor. Please buy a SATA PCI addon card.
like this http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=pci+sata&x=0&y=0
the above card will do alot better job than a converter, if you don't have sata and you don't have room for the card then its best that you buy IDE drive which 250GB or more.
thanks and good luck.
Ekse
HOW TO FIND RAM CAPACITY OF INTEL D102GGC2
Intel D102GGC2 Motherboard Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.*
Maximum Memory Capacity: 2048MB
* Currently Installed Memory: 512mb Number of Banks: 2
* Dual Channel Support: Yes
* CPU Manufacturer: GenuineIntel
* Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
Your MotherBoard Supports up to 2GB of memory.
You have 512mb, you can add 512mb to the empty slot.
, however,It's a good idea to keep them the same if you can.
You can install memory that is: DDR2 PC2-5300 (PC2-5300 is 667Mhz) you can use 1gb memory in each module for best performance and matching pairs since your motherborad supports dual channel.you can use sound card and SATA hard disk for higher disk support
Mar 15, 2009 | Intel D102GGC2 Motherboard
SATA Hard disk 500GB and Sata CDROM
Could be a problem with SATA drivers. Just try to disable sata support by entering bios setup if applicable.
OR
Find the drivers for sata device and install
Feb 20, 2009 | Mercury KVM800M Motherboard
Sata Hard disk and DDR 1Gb Ram not supporting to my motherboard how can i add and detects this both things please give me reply as soon as possible
Do you have a SATA Cable for your SATA hard disk?
What are the spec's for your RAM, it should be 2 x 184 pin DMMs, 400 MHz, 333 MHz,266 MHz memory. up to 2 GB Ram.
Jan 23, 2009 | Mercury KVM800M Motherboard
Max hard disk support
hello. the motherboard supprts this
Max Supported RAM - 3gig
Audio Output - Sound Card • 5.1 Channels • Line Out
Video Interface - AGP 8x
On Board Graphic Processor - Intel Extreme Graphic
Expansion Slots - AGP x8 x 1 • PCI x 3 • CNR x 1
don't forgett to rate. Ty
Jan 09, 2009 | Mercury P4VM800M7 Motherboard
Mercury P4VM800M7 Motherboard Logo
94 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Alun Cox
vsri9
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
