Question about GE Wsxh208a1ww Front Load Washer Washing Machine Motor Control Unit Wh12x10154
How do you replace the bellow and spring - GE Wsxh208a1ww Front Load Washer Washing Machine Motor Control Unit Wh12x10154
Replace kenmore washing machine bellows
open door look at outer part u will find wire retainer with spring on it remove it remember where spring is located. now pull bellows louse on outer edge and fold back to inside of tub. the inter side should have a screw clamp on it lousen this and remove bellows becareful to notice the 12:00and or 6:00postion .reinstall.in reverse order . u may need a extra hand on the outer retainer. hope this helps haundi24
Nov 17, 2009 | Kenmore Washing Machines
Bellow came off during wash cycle
You may need to replace the bellow and the band that holds it on they don't usually just fall off.
 Here is a link to the repair manual.
  https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Changing the bellow on a duet
Tilt the machine back to create more space between the front on the door and the outer drum. Remove the screws for the kickplate and remove the kickplate for easier access. Open the door and remove the spring clamp holding the bellows to the door opening lip. Push the bellows into the drum to get access to the outside/ rear of the bellows (where it connects to the drum). There you will find another clamp which you loosen/ remove with a socket. Some models have an overfill tube on the top of the bellows (remove it from the bellows). At this point you should be able to completely remove the bellows.
Align the new bellows to the outer tub. Attach and tighten the inner clamp (be careful not to over tighten and periodically check the bellows and clamp placement as you're tightening to make sure it doesn't slip off). Attach the overfill tube (if equipped). Lay the machine back to level and install the front of the bellows to the door opening lip. Re-install the spring clamp by starting at the top and working your way down both sides (may be easier with 2 pairs of hands). Be careful not to overstretch the spring on the clamp.
Test with a quick fill and let it agitate for a few minutes to ensure there are no leaks (be ready to hit cancel and have a few towels just in case it leaks). Re-install the kickplate, make sure machine is still leveled correctly by trying to rock it diagonally from the top.
Let me know if you need more assistance.
Apr 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 plus 11047532601
If it's stackable, you'll want to start by removing the dryer.
Open the door and remove the outer bellow spring around the bellow to release it from the cabinet lip. At this point lean the machine back to give more space between the drum and the cabinet.
Remove the kickplate for easier access and to visually check for leaks later.
At the top/right of the bellows (close to the tub) loosen the bellow to tub clamp and pull out the bellow.
Install the new bellow starting at the top by aligning the marks. Work your way around until bellows is properly seated snug against the tub.
Replace the tub to bellow clamp and tighten it (make sure the bellow stays snug against the tub while tightening the clamp). Once in place, lay the machine back to level and reinstall the front of the bellows to the cabinet with the outer bellow spring clamp.
With towels handy (just in case), let the machine fill and agitate for a few minutes and check for water leaks. If all is well, re-install the kickplate and wash some laundry.
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washer need to put rubber gasket retaining spring back on. Any tricks, seems impossible. Peter
I assume that you're talking about the inner spring. It's very tight, so you have to get the rubber gasket (bellows) fitted on the its frame, then push the bellows inside out in toward the tub. Start with placing the spring in its groove at 12 o'clock. Wedge something between the bellows and the white colored weight ring of the tub. You'll need something approx 3/4" in diameter to wedge the top of the spring in place. (I've used a 1/2"X90 degree copper elbow I had laying around that had an approx outside diameter of 3/4"). This will hold the spring in place as you work it around. It is still very difficult and you may have to stretch the spring ever so slightly to get it back into the groove. Once the spring is back on, remove the wedge, fold the bellows back out and attach the fill hose and attach bellows back to front panel.
Jan 02, 2009 | Kenmore 44072 Front Load Washer
How to replace the door bellows seal ?
Unfortunately the service manual will not tell you how to replace the bellows.
Test with a quick fill and let it agitate for a few minutes to ensure there are no leaks (be ready to hit cancel and have a few towels just in case it leaks). Re-install the kickplate, make sure machine is still leveled correctly by trying to rock it diagonally from the top. Enjoy clean clothes!
Dec 19, 2008 | Whirlpool GHW9100L Front Load Washer
I ordered a new bellow for my whirpool duet front loader washer. where can i find out how to replace the part. when the part came from the internet, there weren't any instructions. i want to replace the...
ok karl remove front spring around front outside of bellows pull bellows away from inlet tube on upper right corner is a screw 7 mm i believe although 9/32 will work losen screw and remove band through front opening remove boot reinstall in reverse ..have fun getting bellows around drum opening takes a little patience and putting outside spring back on can break a nail
Jun 18, 2008 | Washing Machines
did hte rear clamp come off or just the front spring. assuming its just front spring.carefully reinstall the boot over the front lip assy . easy enough!!here comes the fun!! the spring itself goes to the bottom of the rim.So hang the wire over the top of bellow and feed into the lip evenly as you go down both sides as soon as you get your hands to the 9oclock and 3 oclock positon I then change grip on the spring (use the tips of my fingers palms facing front assy and strech whole pushing down and in. I used to find small spring style clamps would work great for holding the wire in place till it would "pop" into place. a third hand is also very useful to hold in place .
Mar 12, 2008 | Washing Machines
How do I Replace the bellow on a Kenmore 4646
There is a spring that holds the gasket on .Pop that spring off and the gasket should come very easy.
Oct 29, 2007 | Kenmore 46462 Front Load Washer
GE Wsxh208a1ww Front Load Washer Washing Machine Motor Control Unit Wh12x10154 Logo
20 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
