Question about Health & Beauty
I need to find batteries and a charger.
We think that the batteries are not charging and the charger isn't working properly. It has been setting up for about 5 years. We need to know what would be the best way to check it out?
  • 1,263 Answers
Hi, the batteries will not charge correctly if the charger is faulty ? now what is the scooter model ?
regards
Posted on Jan 12, 2013
micromatikal
  • 2777 Answers
SOURCE: I have a Jet 3 Ultra electric wheel chair(scooter)
If you are only getting 1 volt at the charger then that explains your problem. The charger is failing or has failed. You probably did not need to replace the batteries, hopefully you still have the original batteries and can put them back in and return these ones you purchased. Then use that money to buy a new charger...
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 08, 2010
SOURCE: Mobil Line Battery Charger for Stairlift not working
check the sensor at the top of the track and make sure it is not loose.Just had this problem,can be fixed with a screwdriver for free.
Posted on Mar 28, 2011
  • 692 Answers
SOURCE: Batteries will not charge. No
The charger is the problem Replace the charger and you should be good to go
Posted on May 15, 2011
  • 405 Answers
SOURCE: new charger for 36 volt
HI.It should be connected in that way.The + sign of the charger connected to the +sign of the batt then connect the - batt next then finally connect the -sign of the batt and finalle the+ sign of the last batt must be connected to the -sign of the charger.This connection allows the voltage to flow within the 3 batteries.Thank you for choosing FIXYA.
Posted on Aug 03, 2011
Mustgo
  • 2359 Answers
SOURCE: My Pride Jazzy Jet 2
Are you comfortable working on the electronic cable / connector?
Check the temperature charger's by hand. It should be warm to the touch when power on.
Since you has the unit plug in for days,it should be warm to the touch.
You will need to has a volt meter to check the voltage output on PIN 1 and 2.
Remove the power cord from the outlet.
Inspect the 3 small pins on the XLR (ROUND connector) to the scooter.
Make sure the 3 pins are not damage.
Open the metal 3 pins connector by sliding it back on the cord.
Check for loose connection on the solder tabs.
There should be total of 3 solid solder connections these tabs.
Close up the connector.
Check the connect on the scooter end.
The 3 pins must be clean and able to make the connection.
Please post more information and result on reply.
Posted on Sep 05, 2011
Pride Jet 3 Ultra 4500 rpm, unit is completely dead, am I missing an auxiliary charger or is it built into the unit?
I suggest that you start with determining the condition of your batteries and work outwards from there. Dead batteries just don't want to take a charge. Test your batteries with a meter before you start part swapping. The internal charger is only about 4 amps so it will take many hours to charge a 24volt system.
May 06, 2013 | Jet 3 Ultra Power Chair
I am getting a flashing green light when I try to charge my batteries on the Pronto M51 what does this mean
why did you change the batteries, did you verify that it wasn't the charger in the first place, sometime the charger will appear to charge but actually isn't. put a meter on one battery then plug in charger if voltage goes up charger is good if not look for loose connections and or bad charger.
Sep 25, 2012 | Invacare Pronto M51 Power Wheelchair
Why isn't my phone charging its pluged in and it
You can try to try a different charger,if it doest charge the battery,try to use your charger to a compatible phone. If it charge the second phone,that means that your charger is fine,it might be a battery issue. For sure,either the battery or the charger needs replacing.
Dec 07, 2011 | LG Cell Phones
Powercord replacement
please explain further.. do you mean your laptops power adapter cord?
thanks for using fixya
Nov 10, 2011 | IBM ThinkPad 380ED
Engine is a re-build done less than 100 miles, was starting ok but now it wont turn just continuous clicking like starter wont engage!
Sounds like the battery isn't charged enough to power the starter.
Take the battery off and charge it properly with a proper battery charger.
Refit and it should be fine.
If not, it's new battery time.
Aug 05, 2011 | Harley Davidson XL 1200 C Sportster Custom...
The battery does not charge, its a new battery.what do i look for?
if its a new battery it could be as simple as it wasn't charged when you purchased it, If it was charged and your mower isn't charging it, the power source to the battery from the mowers motor isn't working properly,, not knowing if its a 12 or 6 volt system you need to check the battery ,, see which one it is,, using a multimetter ( if its 12v ) check the battery after you charge it with an outside source ( battery charger) you would have a reading of 12-12.5 volts on a normal check,, then start the mower, and check the battery as its running,, you should get a reading of 13-13.5 volts minimum, if your not, the alternator or magneto isn't working properly, if you do show the increased voltage at the battery connections, then you need to clean the contacts since the charge isn't reaching the actual battery
May 24, 2011 | Garden
Charger plugged in but battery isn't charging. laptop only comes on when plugged.
If you've been using that same laptop battery for a few years then it probably needs to be replaced. Batteries get old and stop working properly after a while. You'll have to go out and buy a new one.
May 10, 2011 | Computers & Internet
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
