Question about GE Hotpoint 30" Self-Cleaning Freestanding Electric Range - White-on-White
GE Hotpoint electric stove
GE Hotpoint glass top self cleaning oven. After cleaning the oven the door will not open even after following all instructions
  • Mark Egan May 11, 2010
    When you say "cleaning the oven" do you mean running the oven through a self-cleaning cycle? If so, how long have you waited since the end of the cycle?
    Novelist:
  • 101 Answers
If you ran a self cleaning cycle and now the door won't open you may just need to wait a while. The door locks to avoid anyone from opening it as the over heats up to around 700 or more degrees to burn anything off. Sometimes what will happen however is that the heat will get to intense and cause the door lock mechanism to jamb. If the door doesn't open for you after a good few hours or so you can try unplugging the oven for a while to try and reset it. If not though you will have to go through the front panel and go down to manually unlock the door. Let me know if you have any other questions and let me know if this was helpful. Keep me updated on the outcome too if you wouldn't mind. Good luck and glad I could help.
Posted on Jan 22, 2009
Ge profile self-Cleaning oven: how do I clean between the glass door. Where do I take t apart?
Hello Patricia
Oven doors by their design are very difficult, almost impossible to open then re-assemble. Not advised.
However, for the brave-hearted, oven doors can be open, eg to change a broken spring etc.
This involves dressing in protective gear as glass fiber wool insulation inside stove and door casing is very hazardous.
Strip half the stove to get to the hinge/arm mountings, unbolt so that door & hinge-arms come free, lay face-down on newspaper.
Using brute strength, unscrew Philips screws which have stuck solid from years of baked fat and heat.
Lift carerfully and try to avoid itchy glass fibres.
Glass inspection hatch insert may have stuck to silicone seal so press until it falls free.
Clean glass & re-assemble all in reverse order.
Trying to get the hinge-arms to line up while holding the heavy door is the most difficult part.
Can lead to stress, premature ageing....
Hope this helps :)
Clive.
Oct 29, 2017 | GE Kitchen Ranges
How do i lock the self cleaning ge oven door when i put it on self clean
If you have a self cleaning oven, the door will lock automatically as the self cleaning begins. Give it some time ,it will happen. When cleaning is done it will take a while for the door to unlock. GOOD LUCK FRIEND.
Nov 08, 2014 | General Electric GE 24" Single...
My ge hotpoint self cleaning 30" convention stove
sonud likr the little switch in the door lock is stuck when you put it on self clean there is a switch that puts it in to clean and now its stuck try to give the top at front a light bang and see if that jars the switch if not that will ned to be located and eather replaced or buy passed
Nov 11, 2010 | GE Hotpoint 30" Self-Cleaning Freestanding...
I need to replace a cracked glass top (GE Profile Slide In... where do I find my oven model number and part number
If you dont see it around the door or inside the stove you'll have to raise the top and it should be there somewhere. The part number for the glass top I can get for you if I have the model number
Sep 08, 2009 | GE Profile 30" Self-Cleaning Slide-In...
Manual lever to lock self clean oven wil not lock
After sliding latch to its locking position did you press the self clean button on the control panel?
Mar 31, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
I cannot get the auto self clean cycle to end
It sounds like your oven control module is bad. It conrols all bake, broil, including self clean.
Mar 25, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
DO NOT KNOW HOW TO USE SELF CLEAN ON OVEN?
Hi April,
Without a model number, I'm shooting in the dark but I'll give you basic instructions that fit for most ovens, OK?
First off the door has to be locked PRIOR to cleaning. Look around the top of the oven door, there should be a handle (for mechanical models). Rotate this handle from the left to the right to lock it. If there's no handle, that means your oven locks the door by itself when "Clean Mode" is selected.
Now, at the control panel, select "Clean". At this point, you may have options on the length of time it should clean, select 3 hours and hit "Start".
There ya go! Hope this helps. If not, DON'T RATE THIS SOLUTION! Just write back and provide the model number, I'll give you exact instructions with that. Deal? Cool.
SG
Mar 23, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
OVEN DOOR WON'T OPEN
as a firefighter i know this lift open the top of your stove and there are 4 screws on a metal plate take those off and your latch release will be under there try that e mail back at firefighter00@fctvplus.net
Dec 07, 2008 | Hotpoint RB787 Electric Kitchen Range
GE Hotpoint 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
391 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
