Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Red Screen Hi, Some months ago my screen went all red then switched between blue and green. A few days later, it came back to normal. A few days ago, my screen went all red. I switched inputs and it came back to normal. Yesterday it went all red and will not come back to normal after trying switching inputs, perfect focus command, etc. Is this fixable? Thank you!
  • Anonymous Apr 30, 2008
    I was watching the tv today, and it went green and red. Then it shut off. I tried to turn the tv on again and nothing would come up, no picture, no nothing. We cant find the book on it. So can we download one on the internet?
    Scholar:
  • 170 Answers
Try tapping lightly on the tub that matches your color problem.
do you see it come and go? if so then you have bad tubes.
you can try to rejuvenate them but is not recomended.
Posted on Apr 10, 2008
Hisense LED HDTV
I am no expert, but I would be looking for a replacement or warranty on that unit.
Unfortunately there is very little an every day user can do to fix a problem like this on their own.
Jan 29, 2014 | Televison & Video
I had nothing but problems with my plazma since I bought it. But a couple months ago there was too much red on the screen so I adjusted the red to almost 0 and it was OK not great picture. Then the other...
your main digital and sub digital have failed. incredibly expensive.
there is one attempt that you can make to try (by chance) to save it temporarily.
The digital and sub digital are the two boards in the center of the TV where the input jacks are located.
Carefully disassemble and remove the top layer board (sub digital)- it is connected to the board beneath (digital) by a multi pin connector about 2" in from the left hand side. This is where you problem is. Reseat that connector by removing the board then replacing it.
Apr 15, 2011 | Hitachi 42HDS69 42 in. Plasma Television
RCA Projection TV Model HD61W66
convergence power supply not working , there is a mini fuse close to the flyback thansformer , 400miliamp at 250 v resolder the flyback and replace this fuse , there is 3 fuses it look like small squer brown color is the one on the middle , normal repair $200 - 300
May 07, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Red, bule, green lines do not line up together.
why is my projection tv screwed up on the left side with the color red only i tried to center it and it won't go any further.
Sep 05, 2008 | Televison & Video
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Jul 18, 2008 | Microsoft Xbox 360 Console
Screen all blue
Try looking into the blue CRT lens while its on and see if the coolant has congealed. You will be able to tell if it has bacteria growing as this can cause the blue to be unresposive and make your screen have a blue haze. The coolant will need changing if this is congealed with bacteria. This is a common problem in all projection tvs blue and green are more prone to this sympton red is not.
Mar 30, 2008 | Televison & Video
Having the same kind of problem, only mine occurs twenty or so minutes after start up and only on the left and right sides of the screen.
Jan 20, 2008 | Samsung HC-P4752W 47" Rear Projection...
Red screen
sounds like a picture tube problem its a problem that probably cant be fixed only by a professional
Nov 30, 2007 | Sony KP-51HW40 51" Rear Projection...
Convergence Problems
If you did not use heat sink compound then you probably have not hurt the new IC's yet but you should remove them and add the heat sink compound NOW. If the convergence IC's are bad then you will have access to the convergence menu but the adjustments will have no effect. The fact that you switched the IC's and got the same results shows that the IC's are good. If your red convergence is still way out when the new IC's are installed then the old IC probably burned out the low value resistor associated with the Red Vertical (RV) channel.
Jul 02, 2007 | JVC AV-48WP30 48" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
