Question about Husqvarna Partner K650, K700, K750, K950, And K1250 Gas Fuel Cap
Cuts out when cutting
K750
  • 784 Answers
Check idle settings.
Posted on Jan 13, 2013
On a k750 wen its running on idle its fine . Soon as you place spinning blade on brick to cut blade stops moveing k750 is 3 week old and been in use for 5 days in 3 weeks. Eny idea plz
Hello Keith, It sounds to me that the drive belt needs to be tightened. There are two bolts between the engine and the blade. Loosen those bolts, tighten the belt and tighten the bolts.
Oct 14, 2015 | Cars & Trucks
K750 cut off saw three new air filter,gas filter,spark plug saw loses power after 15 sec of hvy cutting
Piston rings are gaulded or stuck, easy to change and fairly inexpensive if you buy aftermarket parts on ebay. I believe piston, rings, and cylinder (if you need it) for less than $100.
Aug 25, 2011 | Husqvarna 965142201 K750 5HP 12" Gas Cut...
I have a husqvarna k750 sawing stone stawls under load whats wrong?
If the motor revs up ok it might be the type of disc you are using. I used a huge 2000 Sten one time from about 1961 going through rebar cemented inside cinder block wall to make some windows. It used the huge 18 inch discs and the older guy that was my boss said there is two types of discs - one is tar bonded abbrasives and the other is resin based which is three times better cutting and doesn't smoke up your lungs while you are breathing hard. They are usually dull red with no black in the grit if you look right up close. If the motor stalls or has a cutting out noise at high rev without load it may just be a dust covered gas filter which is deep inside the saw's gas tank on the end of a rubber tube.
Apr 10, 2011 | Husqvarna 965142201 K750 5HP 12" Gas Cut...
Husqvarna k750 runs for about 5 mins then shuts off. let it rest then restart 5 mins later same thing
Obevisley is over heating make sure all fins and vents are clear and blown out then the only other thing is to replace the ignition modual just trace the plug wire back to flywheel and ignition block
Oct 06, 2010 | Husqvarna Partner Gas Powered Cut Off Saw...
Oil ratio partner k750
40ml to 1 litre of fuel 150ml to to 1 gallon
May 19, 2010 | Husqvarna Partner Gas Powered Cut Off Saw...
Saw runs great then bogs down 20 sec. after i start cutting i let off it runs good then bogs again when cutting after a few sec
Check your air filter, if clean chances are your carburetor needs to be rebuilt. the carburetor has thin diapragms that get hard and won't meter the fuel in fast enough.
Jan 30, 2010 | Husqvarna 965142201 K750 5HP 12" Gas Cut...
Husqvarna Partner K650, K700, K750, K950, And K1250 Gas Fuel Cap Logo
181 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
