Question about Soyo SY-P4I 845PE Motherboard
Who is the mother board manufature for sy -p41 845pe? what type of cpu does sy -p41 845pe suport and speed range? the type of module, max support capacity and speed ranges? the type of chipsets? the type of bios version? the motherboard form factor? the motherboard dimensions?
  • smll2000 Jan 22, 2009
    THANK YOU VERY MUCH, YOUR SOLUTION WAS VERY VERY HELPFUL.
  • 1,800 Answers
Processors
  • Supports all Socket 478 CPUs (400FSB & 533FSB)
Chipset
  • North bridge: Intel I845PE MCH
  • South bridge: Intel ICH4
System Memory
  • 3 x 184-pin DDR SDRAM
  • DDR200 / DDR266 / DDR333 support @ 2.5v
  • 3GB maximum system RAM
Slots
  • AGP slot, 4x AGP compliant (1.5v support only)
  • 6 x 32-bit PCI 33MHz slots
On-board peripherals - I/O
  • 1 floppy port supports 2 FDD
  • 3 Audio Jacks for the CMI9738 sound chipset
  • CMI9738 6-channel sound
  • Davicom 10/100 LAN (10/100 Mbit/s)
  • 2 USB2.0 ports and a further 4 available via headers
  • PS/2 ports
On-board IDE
  • An IDE controller on the ICH4 chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA/100/66/ operation modes
  • Highpoint HPT371 RAID single-channel ATA133 RAID controller
  • Ultra DMA/ATA133, 100, 66, 33 operation modes
  • Supports up to 2 hard drives
  • Serial ATA support via the Marvell 88I8030 single-ATA bridge
  • Supports 1 S-ATA drive
BIOS & Voltages
  • FSB speeds of 100Mhz - 255Mhz (quad-pumped)
  • 1.1 - 1.85v Vcore adjustable in 0.025v increments
  • 2.5v - 2.8v Vmem adjustable in 0.1v increments
  • 1.5v - 1.8v VAGP adjustment
  • Fix AGP/PCI speeds and variable settings
Posted on Jan 22, 2009
  • Jalal Sordo
    Jalal Sordo Jan 25, 2009
    at least rate my solution sir
    President:
  • 1,179 Answers
Soyo is the manufacturer. Here is their specs & cpu support page for this board: http://www.soyo.com/content/FAQ/47/?n_id=19
Hope this helps & please remember to rate my answer. Thanks.
My mother board had all the jumpers pulled off. need to no where they go. mother board is ''sy-k7vta pro'' can u help me rn7615@yahoo.com thanks
here is the pdf file I dont know the speed nor the cpu speed FSB (front side buss) hope this will help you out
www.motherboards.org/files/manuals/107/qk7vtapro11.pdf
Feb 10, 2010 | ASUS Computers & Internet
Which graphics card ican use in ASUS M2N68-AM SE2 mother bord amd athlon 64 5200+
unfortunately, this board does not appear to have slots for upgrading its graphic card.
Model Brand ASUS Model M2N68-AM SE2 Supported CPU CPU Socket Type AM2+/AM2 CPU Type Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2 Chipsets North Bridge NV Geforce 7025 / nForce 630a chipset Memory Number of Memory Slots 2×240pin Memory Standard DDR2 1066 Maximum Memory Supported 4GB Storage Devices SATA 3Gb/s 2 SATA RAID 0/1/JBOD Onboard Audio Audio Chipset Realtek ALC662 Audio Channels 6 Channels Onboard LAN LAN Chipset RTL8201CP Max LAN Speed 10/100Mbps
You are stuck with the integrated card.
Jun 28, 2009 | Computers & Internet
What is the max Memory Modules I can use with and Intel Mother Board described as follows: Bus Clock: 100 megahertz BIOS: I;ntel Corp. 4W4SBOXO.15A.0012.PO7
Your answer is 384MB however I would not go more than 2X128MB ...You will not gain any overall system speed by adding ram faster than the bus, in fact your system MAY not run. What ram does, it increases the data transfer between the CPU and hard drive.
May 14, 2009 | Computers & Internet
RAM SUPPORT FOR D 845 GVSR MOTHER BOARD OF 2004
Greetings
Memory support for your d845gvsr board is as follows:
Memory speed - 333MHZ, 266MHZ and 200MHz.
Memory type - DDR SDRAM
Max Memory - Capacity of up to 2 GB
Memory Slots - 2
Memory module size is 1GB (1024MB) for slot.
Thank you,
Let me know if you need anything else.
Ekse
Mar 02, 2009 | Intel Motherboard
I want sound driver and vga driver of my laptop z755110 if u have zenith drivers so plz call me.9250327275 MY NAME:RAHUL LUTHRA PLACE:DELHI,LAXMI NAGAR
WHAT TYPE OF CPU SY-61WM/L SUPORT AND SPEED RANGE?
THE TYPE OF CHIPSET?
THE TYPE OF BIOS VERSION?
MOTHERBOARD FORMFACTOR?
MOTHERBOARD DIMENSION?
Jan 28, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
Max ram for SY-K7VEM PRO
Two SDRAM DIMM sockets support up to 512MB
168-pin PC133/PC100 non-ECC, unbufferred SDRAM memory
This is what your M/board can use in memory
Aug 20, 2008 | Soyo Sy-K7Vem-Pro Motherboard
Max CPU for abit BL7-RAID
As number of cpus it supports maximum one cpu.
As cpu type it has a socket 478 supports any pentium 4 (not duo) up to Pentium 4 2.8G (p.n:RK80532PC072512)
You may need to upgrade bios to latest version to support the CPU.
Apr 09, 2008 | Abit BL7-RAID Motherboard
Sy-7vem soyo cpu upgrade
Most of the new boards will automatically detect the cpu speed. If possible set the bios to auto detect. Otherwise go to Soyo website and check the manual
Dec 21, 2007 | Soyo SY-7VEM Motherboard
Soyo SY-P4I 845PE Motherboard Logo
308 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
