Question about Paragon Hardware & Accessories
Paragon timer Model # 23001-0S
Need motor for # 23001-0S
  • 52 Answers
SOURCE: Paragon timer parts
electricalexpeditors.com
Posted on Oct 05, 2009
  • 52 Answers
SOURCE: Need tripper pins for AMF Paragon Timer Model 7218
Go to electricalexpeditors.com for replacements.
Posted on Dec 30, 2009
  • 52 Answers
SOURCE: My timer won't cycle the motor on and off.
you may need trippers
Posted on Feb 26, 2010
  • 52 Answers
SOURCE: I need to find Paragon timer model P101 parts ie.
call 1888 782 6086 www.electricalexpeditos.com
Posted on Jun 25, 2010
  • 16 Answers
SOURCE: I need a wiring diagram
Paragon 8145-20 is a 240VAC (2 phase) timer. I doubt you will be able to find a 3 phase type timer.
I would suggest you use this timer as a control and purchase either contactors or relays rated to handle the 3 phase load.
Posted on Dec 26, 2010
The clock on my paragon 4004-71m is not working
1) Clock motor has gone bad, but replacement clock motors are no longer made.
Copy following link for Paragon resources:
http://waterheatertimer.org/Paragon-timers-and-manuals.html
2) Paragon is not making parts or replacement motors.
4007-41 is 240Volt timer, replace timer with Intermatic T104
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
3) Crossover wiring from Paragon 4004-71 to Intermatic T104:
Paragon 1 to Intermatic 1
Paragon 2 to Intermatic 2
Paragon 3 to Intermatic 4
Paragon 4 to Intermatic 3
Intermatic terminal A is generally not used for 240Volt
4) Add a comment if needed
Jan 17, 2013 | Paragon Hardware & Accessories
Timer not working on 4000 series, think its 4014 single pole single switch for pool pump. pump turns on when manually turn switch on but timer does not move. I feel the normal resistance and can move the...
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 1 goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminals 3 goes to Intermatic terminal A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Is it possible to buy the timer motor for a Paragon electromechanical timer (Model 7008-20, 208-240 V, 60 Hz)? The timer motor part number is M3100, and the timer is 208-240 V, 3 watt 60 Hz.
1) Paragon is no longer making timers or parts except defrost timers.
7008-20 240V 24-hour mechanical timer is not a defrost timer.
Link below shows folks who might still have Paragon parts
http://portalgb.knowledgebase.net/display/1/index.aspx?c=15121&cpc=XobrEdQ5Lsnv624T2PBS4Exx6S5VyiL7gw3am4YYt6&cid=13013&cat=&catURL=&r=0.485034763813019
2) To see Paragon timers and manuals:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
3) If you want to buy new timer: Intermatic cross-reference guide shows T7802B is correct replacement timer
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
4) Electric supplies online shows T7802B 4 pole 2NO/2NC
http://www.electricsuppliesonline.com/int7tidp20t.html
5) Manual for T7802B
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t7802b%20-%20english.ashx
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 09, 2011 | Paragon Indoor Electromechanical Timer...
Hello I need to replace a paragon model 4003-0 can you tell me what is compatable to this model? thanks maury
As you probably know, Paragon is no longer making timers and parts except defrost timers.
4003-00 is not a defrost timer
4003-00 is DPST 120Volt timer 24-hour mechanical timer
Intermatic cross reference shows that T-103 is replacement for 4003-00
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
T-103 has 120Volt clock motor and can control 1 or 2 - 120V loads or 1 - 240Volt load
Dec 29, 2010 | Paragon GENERIC REPLACMENT MECHANISM 110V...
I need a three phase wiring diagram for 8145-20 model timer.
8145-20 240Volt Paragon timer is not 3-phase.
Clock motor is 240V.
You need a transformer to convert 3-phase to single phase 240V to operate timer.
Then timer outputs can control 3-phase power using 3-phase contactors
Contactor below is 3 phase with 240V coil
http://www.grainger.com/Grainger/DAYTON-Contactor-2UTP7?Pid=search
Defrost timer wiring diagrams show below:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Dec 21, 2010 | Paragon 8145-20 Defrost Timer
Lost instruction manual. How do I progam my Paragon Electric timer Model EC7004/120
Link below has Paragon EC7000 series timers and manuals
EC7004/120 is 7-day programmable timer.
Single channel 120Volt SPST NEMA1 indoor timer.
Program up to 16 events per week
EC7000 series programming manual shows wiring, explains keypad, has steps for setting current time, and shows 24 steps for programming timer. Plus troubleshooting.
It is impractical to write out those steps when they appear in manual.
http://waterheatertimer.org/pdf/Paragon-EC7000-04-05-manual.pdf
EC7000 series Sell sheet with model numbers
http://waterheatertimer.org/pdf/Paragon-EC7000-sell.pdf
Description of model numbers at Uni-line
http://www.uni-line.com/modules/catalog/SearchResults.aspx?catName=19030&pID=19029&mode=categorysearch
Dec 01, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
I have a model 7005 outdoor timer ,brand new but no instructions to proceed with settings .Can you help me?
72d1511.jpgParagon 7000
Paragon 7005 is a heavy duty 7-day mechanical timer that can handle 4 loads. It is DPST. One of two wiring diagrams applies to this timer:
1d6e8ec.jpgThe question is the the timer clock motor is 120V or 240V?
36b7dc9.jpgParagon EC 7000 is a 7-day digital timer with 16 set points per week
Manual for EC7000
http://waterheatertimer.org/pdf/Paragon-EC7000-wire.pdf
Please re-post your questions as you start sorting out which timer you have.
Paragon is improving their site so there is less confusion over model numbers and functions. but information about the 7000 are still sketchy.
Oct 15, 2010 | Paragon Hardware & Accessories
Hardware & Accessories Logo
77 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
