Question about HP LaserJet M5035 MFP Printer
My printer name is HP M5035 MFP LASERJET serial number cncxbo4735.it can't scan or photo copy error code 30.1.19
  • 1 more comment
  • wina_maimbol Apr 29, 2009
    Yes it worked but brought anther error of a paper jam in the ADF for some time.
  • Anonymous Mar 12, 2014
    57.04 error
  • Anonymous Mar 22, 2014
    I turned it on and it comes up with a scanner failure error. It is in the unlock position and I have turned it on and off several times with no improvment
  • 1,800 Answers
Fixed the problem by removing the scanner cover and sprayed compress air on the scanner light bulb and cleaned it out.Put back together
Posted on Jan 22, 2009
  • Jalal Sordo
    Jalal Sordo Apr 30, 2009
    They have an adf maintenance kit which includes new pickup roller, separation pad and mylar strips. I have had success in removing the mylar clip underneath and cleaning up everything and having it work. If that does not work, then I would order the kit first. I assume you ran the test for the ADF motor also. If you did and ok and cleaning or the kit does not work, then you have to replace the whole ADF!!
HP Laserjet m5035 blue line when colour scanning to email
Try checking for debris or other on the ADF itself and below on the prism. The ADF cover glass could be spotless, but if there is a speck on the prism itself, this could cause the actual prism to send a line while scanning.
Dec 30, 2013 | HP LaserJet M5035 MFP Printer
Laserjet m5035 line when colour scanning
Check to see if not only the ADF is spotless, but the prism below it. If there is something stuck there you could see it.
Can i scan to email with m5035
You can, but you need to configure
Sep 05, 2011 | HP® LaserJet M5035 MFP Laser...
HP Color Laserjet M5035 get`s error 30.01.34
First, this model is not color laserjet, only black.
30.1.34 Cable error or loss of communication with the formatter.
1. Turn the device off and then turn the device on.
2. Make sure that the ribbon cable between the scanner control board and the formatter is not damaged and is correctly seated.
3. Make sure that the hard disk drive on the formatter is connected correctly and that the hard disk is functioning correctly.
4. If the message persists, replace the scanner control board or replace the formatter.
Aug 30, 2011 | HP LaserJet M5035 MFP Printer
Scan note working (Hp Laserjet M5035 MFP)
Lets check whether windows detects your scanner
Right click My Computer > Manage > Device Manager
Under Device Manager check Imaging Devices
If there Double click Imaging Devices and check the device under that. If you find your scanner there .Then the scanner is installed properly
Now Lets try a test scan
If Windows Xp do this .
Click start > Run > Type wiaacmgr.exe press enter key
Now take a test scan
If your windows is vista / win 7 then
click start > All programs > accessories > Run
on Run window > Type wiaacmgr.exe press enter key
Hope this would work
Please rate me if you are satisfied with my answer
Mar 20, 2011 | HP LaserJet M5035 MFP Printer
How do i Print individual usage report on Hp laserjet M5035 mfp multifunctional Printer.
Usage page
Shows a page count for each size of
paper printed, the number of one-sided
(simplexed) or two-sided (duplexed)
pages, and the average percentage of
coverage.
1. From the Home screen, touch Administration.
2. Touch Information.
3. Touch Configuration/Status Pages.
4. Touch Usage Page.
5. Touch Print
Feb 21, 2011 | HP LaserJet M5035 MFP Printer
Hp printer lj m5035 in 69.30 error
According to Hp official site,
A temporary printing error occurred.Turn the device off, and then turn the device on.
If this message persists, contact an HP-authorized service or support provider.
Goodluck
Dec 06, 2010 | HP LaserJet M5035 MFP Printer
SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Mar 19, 2009 | HP LaserJet M1005 All-In-One Printer
HP LaserJet M5035 MFP Printer Logo
689 people viewed this question
Ben Johnson
