Question about Sony PlayStation 2 (PS2) Console
PS2 broken When I turn on my PS2 and insert the disk the blue light flashes for about 3 seconds and the disk comes out. I had this before but I just left it overnight and it started working again. No matter what no matter how many times is try if I put the disk in it will come out. How do I fix it?
    Problem Solver:
  • 8 Answers
The sensor for the tray is messed up try taking the top cover off and checking the white plastic slider to see if it's off track.
Posted on Jul 06, 2007
5 Suggested Answers
Noggin
  • 944 Answers
SOURCE: PS2 not working
Try the auto diagnosis if it will let you; To start the auto diagnosis feature: Press the standby/RESET button on the front of your PlayStation®2 computer entertainment system to turn on the system. Make sure the indicator light turns green. The Main Menu screen will appear. NOTE: It might take some time for the main menu screen to appear. Using the directional buttons, highlight Browser and press x Highlight System and press x Highlight Diagnosis and press x Highlight On and press x Insert a disc. Auto diagnosis will start automatically. The system will make adjustments that might allow previously unplayable discs to be played. To start the disc after auto diagnosis is complete: Press o twice to return to the browser screen. Using the directional buttons, highlight Browser and press x Press x to play the disc. NOTE: The diagnosis setting automatically returns to its default state of Off when you press the standby/RESET button or start playing a PlayStation®2 disc. (any confusion check this link); http://www.us.playstation.com/support/ps2/hardwaresystem/default.html If that doesn't help then; "Owners of early PS2 models purchased from launch until spring 2003 often reported faulty optical drives in their consoles. The earliest drives suffered from a constantly misaligning laser lens, but later defects were the result of a shift in voltage to the laser. The first problem was easily remedied by opening the console's casing and tweaking a cog that controlled the lens' distance from the disc. However, this action voided the console's warranty. The second problem could be fixed by using an oscillator. After many consoles had broken down, a class action lawsuit was filed against Sony. Sony agreed to provide free repair or replacement for the faulty consoles and continued to do so until February 2005. Another problem that could cause a disc read error is wear on the coupling in the head assembly to the worm gear that moves the laser. A symptom of this is a loud repetitive clicking sound. However, this problem rarely occurs on newer consoles." Some of these units can be easily fixed by just cleaning the lens - check this link for instructions on how to open the ps2 up and how to clean the lens; http://www.neoseeker.com/Articles/Hardware/Guides/ps2diy/ They suggest isopropyl alcohol to clean with, without specifying a strength - gin works fine and is weak enough to be safe. Check this link for a very clear description of the whole process, including the voltage adjustment, only without pictures; http://faqs.ign.com/articles/390/390535p1.html Hope this helps, please ask again if these don't solve the problem :)
Posted on Jul 04, 2007
  • 13 Answers
SOURCE: PS2 disk tray keeps opening
try holding the disk drive after it closes for a few seconds and see if it stays closed or one of the drives gears could be stuck,loose,or broken.you might need to open it up.
Posted on Jul 17, 2007
  • 6 Answers
SOURCE: PS2 stoped working
Send it into sony for repair (if it's past the warranty,my Suggestion is to ask for a Exchange Unit for $75.) :) I did that with mine and it came back a "new unit" (a refurbished v1)
Posted on Jul 31, 2007
SOURCE: PS2 disk tray problem
When the disc tray pops out, reset the ps2 and wait for the tray to close and turn of the ps2 at the back. Then turn it on, press the reset button and it should work.
Posted on Jun 19, 2008
Blue risk game wont work
There a two lasers in a PS2 one reads DVDs and white game discs and the other reads CDs and blue game disc. Sounds like your blue one is broken I'm afraid
Jun 30, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 wont read normal disks
you might have something turned off in your settings ps2 settings.
Nov 25, 2008 | Sony PlayStation 2 (PS2) Console
Disc Tray
The rubber band inside your PS2 might be broken, the rubber band supports the disc tray and it ejects and inserts the tray.
Sometimes if play too much long, some of the PS2 parts will be damaged by excessive heat, so my advice is that your minimum gameplay time must be 3-4 hours only.
Please den't even try forcing the tray to open, it will be more damaged.
Try resting your PS2 for about 1-2 days, after that try to open the tray, if the problem still persist bring to a PS2 fixer near you.
Jul 29, 2008 | Sony PlayStation 2 (PS2) Console
Ps3 not reading any disks
Normally ps1-ps2-ps3 has Red laser beam lens system. So it cannot read Blue ray disks. its not possible until you change it lens system. there are some commericially available Blue laser lens system. Buy one and fix it with authorised service personnel. all the best
Dec 22, 2007 | Sony PlayStation® 3 (60 GB) Console
Disk tray won't stay in
Your PS2 is definitely broken. Either send it in to Sony to be repaired or buy a new PS3. Bummer. Sorry to hear about this.
Dec 08, 2007 | Sony PlayStation 2 (PS2) Console
Jul 05, 2007 | Sony Playstation 3 (PS3) Console
PS2 stoped working
Jul 05, 2007 | Sony PlayStation 2 (PS2) Console
This has happened to me before. You will have to open the PS2 and clean the laser which is under the tray(or on top i forgot).
Use a cotton bud to clean it but be extreamaly careful cause if you put to much pressure on the laser your PS2 is gone for good!
Sony PlayStation 2 (PS2) Console Logo
128 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
