Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
How to turn motorola bluetooth earpiece on/off
It has no boom microphone I don't know the model number I got it used it is red and has a silver phone emblem on the front and an arrow button on each side
Motorola H700 can't hear me talk on it?
Have you tried to use the device with a different phone? You can also try to reset the device: Close the headset's boom (microphone) and wait for the indicator light to turn off. Open the headset's boom and wait for the indicator light to display a purple light, a purple light signifies the headset is in pairing mode.
Best Regards
Suny
Motorola Support.
Mar 21, 2014 | Motorola Mobility Bluetooth H700
Motorola hs850 bluetooth headset won't pair with g five mobile
How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
  4. (Now you can let go of the call button.)
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
May 14, 2012 | Motorola Mobility HS850 Consumer Headset
How do i sync my phone with the h700
Hi, Motorola H700 Bluetooth headset is a basic Blutooth headset that can be synced, or paired, with any Bluetooth-capable cell phone. Something unique about this phone is its retractable microphone, otherwise known as the headset's "boom." You can send and receive phone calls hands-free and wirelessly with your contacts using your H700 headset, in one touch of a button.
instructions
Press and hold the "Call" button on the headset for four to five seconds until the LED light glows purple.
Flip open the headset "boom."
Set your phone into "discovery" or "pairing" mode. Open the Bluetooth settings or options on your phone and choose to add a new device.
Select the "H700" on the phone when it finishes searching for Bluetooth devices.
Enter the passkey for the headset, which is "0000," to finish syncing the headset with your phone.
And your done..
Hope it helped.
May 30, 2011 | Motorola Mobility H700 Wireless Headset
My h700 bluetooth will not go into pairing mode
hi sammieyoungj. i'm sorry to hear about your troubles with your headset. Maybe this will help your situation. Ensure the headset is fully charged. Then turn on the bluetooth feature (discoverable mode/set to look for bluetooth devices) on the phone you are planning to pair it with. Next, turn off the headset by closing the microphone boom. After about 8 to 10 seconds or you know the headset is off, press and hold the call button for about 4 to 5 seconds. The headset should activate and show a steady purplish colored light. When the light turns purple, unfold the microphone boom. If the lights stay a steady purple color, then the headset should be in pairing mode and you can revert to your phone to pair them together.
If the light does not stay steady, or turns a blue color, repeat the steps above, making sure no bluetooth devices are around that it may have paired with previously. Hope that helps. Best of luck.
Mar 05, 2011 | Motorola Mobility H700 Wireless Headset
My iPhone 3G does not discover my Motorola H500. I am tryig to connect a motorola earpiece to a netbook, but the blue light flashes then goes steady, but then flashes again, netbook cannot see it?
I eventually found the manual, and put it in discover mode correctly, and the Netbook paired with it no problem,
It is a Compaq 700 mini Netbook, and it picks up the earpiece straight away when it is switched on, and automatically connects it to Skype, which is what I was trying to achieve, the Bluetooth sw on the Netbook seems very good and easy to use.
May 23, 2009 | Motorola Earpiece with Boom Microphone...
Bluetooth
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select Explorer 220 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jan 30, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Motorola earpiece H700 how to setrup earpiece .
4.Select H700 once a connection is detected.
Tips:
Jan 21, 2009 | Motorola Mobility H700 Wireless Headset
Plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Nov 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
Motorola H700 Bluetooth connection problem
Tips:
Apr 01, 2008 | Motorola Mobility Bluetooth...
Purple light will not stay lit
I signed up JUST because this solution worked:
"Hmm this may sound like a stupid solution that doesnt work but what i did is...,
#1 I Held the button to make the violet light go on
#2 when the violet light is on dont just flip the boom mic, flip* the earpiece with it.
*note: when fliping the mic and earpiece, dont open slowly, flip it open fast and keep it there." I do want to note that my passcode was reset to nothing during my 3 months of troubleshooting.
Not going to mess with it.
Mar 26, 2008 | Motorola Mobility H700 Wireless Headset
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
206 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
