Question about HP Pavilion dv6000z Notebook
Can't connect 2nd laptop to wireless network
Recentlyreformatted the Acer laptop and when I tried to connect to wirelessrouter I SMC, Iwas unable to connect. I saw a similar problem on thissite and followed the instru instructions and was able to connect theAcer laptop to wireless. But when I went to the HP laptop that wasconnected to the wireless via router I keep getting the message''Thesettings saved on this computer for the network do not match therequirements of the network.'' any help would be appreciated Ed
    President:
  • 1,179 Answers
Did you run the setup wireless network wizard on both computers? If not try this first & see if it fixes the problem. You will find this wizard in the control panel of your windows o/s. Hope this helps.
Posted on Jan 22, 2009
Acer Aspire 5733 Wireless connection lost
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
How to connect the wifi to a acer aspire 5733z - 4851 laptop
Check the wireless router and high-speed modem. If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
  • 2 Activate the wireless Internet connection on the laptop computer. Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu. Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
  • 3 Select the appropriate network you wish to connect to. Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
  • 4 Restart the computer. The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
  • Oct 09, 2011 | Computers & Internet
    Hi I have an SMC baracade g wireless router and want to connect my samsung galaxy 580 phone to it wirelessly. My computer connection is working. The phone detects it fine and can see that it has WPA/WPA2...
    Hi
    Try to unplug the power cable of your router for a minute or 2 to re-establish its connection to server. Then try reconnecting to your home network.
    Hope this helps
    Dec 09, 2010 | SMC Barricade 7004VWBR Wireless Router
    At&t wireless router and magic jack setup
    It could be the router which is giving you issue. Press and hold the reset button for 30 second and this makes the configuration to go back to its previous settings. The reconfigure the router with a new SSID and security key. Try connecting to the wireless network, the computers will consider it as a new network and will connect without any issues
    Apr 09, 2010 | 2wire 1800HG Router (RG1800HG00)
    I have a acer aspire 5570Z, unable to connect online...
    Open network connections and disable your wireless connection (right click) then renable it and try to connect. What program are you using to manage your wireless connection?
    If you are using your manufaturers software then try using windows xp (or vice versa)
    Aug 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
    Cant connect my SMC to other home computer and have a netgear router, how do i connect my smc adapter
    Most hardware like an Network Adaptor you install the software CD 1st. Then plug in the hardware.
    Then if you configured wireless (wifi, 802.11) settings on your SMC - you should fine the network NAME when you try to connect. You will be asked for the security key for WEP or WPA or WPA2 that you used in the SMC.
    SMC should... then assign IP Settings automatically. If the SMC has Internet, you should have Internet.
    Jul 07, 2009 | SMC EZ Connect g SMC2862W-G 802.11g/b...
    Unable to get IP address on SMC2804WBRP-G
    You need to setup security on the laptop/access point. Apparently it has been setup in the router.
    Jan 25, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
    Cannot connect 2nd laptop to wireless internet.
    go to your acer and go to net work then net work again and in the tabs above choose add device to net work click on that and put a usb flash drive in and download to flash drive and put the drive in hp and it should automatically run the set up and start to work
    Jan 22, 2009 | HP Pavilion dv6000z Notebook
    SMC EZ Connect 2862W-G does not see Linksys network
    It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
    By the way, how far is your computer (using the SMC adapter) to your wireless router?
    Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
    PS3 and Laptop issues
    the new unit you have is the PS3 is not compatible to the SMC barricade router that you had,, you must find a compatible just only for the PS3 unit,, you can ask from authorization wer you bought it!!
    Dec 04, 2007 | SMC Barricade g SMC2804WBR Wireless Router
    HP Pavilion dv6000z Notebook Logo
    81 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
