Question about Cobra Radio Communications
Cobra 25 lx rf power output fail - Cobra Radio Communications
  • Mike Charette Mar 01, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Habit-Forming:
    New Friend:
  • 65 Answers
Need more info
Posted on Mar 05, 2015
SOURCE: Cobra 25 LTD
most cbs have the same power cod
Posted on Aug 14, 2008
Benimur
  • 6966 Answers
SOURCE: new power chip
To my knowledge on a Cobra 29 board, replacing TR14 (2SC2029) with a 2SC1969 is supposed to improve/increase the TX power output. Additionally however, L12, 13 & 14 must also be adjusted while the 29 is hooked up to a dummy load/watt meter. Should you wish to try for experimental purposes only:
  • Modulation improvement - adjust VR4 to desired level or cut D11or max talkpower remove TR18 .
  • replace TR14 with 2SC1307 (or 2SC1969).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 06, 2008
SOURCE: Older Cobra 25 ltd
did the gauge stop working or the radio. the gauges on older radios fail quite often . you can order replacements
Posted on Sep 15, 2008
Communicomm
  • 90 Answers
SOURCE: Cobra 200gtl High Power Transmit problem??
Depending on the type of power supply, radio frequency (RF) energy from the transmitter may be 'fooling" it into thinking that you're overloading it. Check to see if there's any discernible dimming of the meter lamp when this problem occurs, if so, the supply is the culprit.
Otherwise, its probable that the final amplifier transistors are overheating, either they are 'leaky' or not properly attached to the heat sink.
Posted on Sep 26, 2008
Bat1956
  • 585 Answers
SOURCE: af audio power amp
Just because the chip is warm doesn't mean it's bad, especially if it seems to work fine otherwise. Do however make sure that the device is properly heatsinked, and inspect the work done in the process of any modifications. If for some reason the device is self-oscillating it could do so at a frequency above hearing thereby going unnoticed. That will cause the device to overheat, and also make modulation weak and the RF to splatter out of band. You'll have lots of power on the RF wattmeter, but people can barely hear you if that's the case.
Posted on Jul 11, 2009
My cobra 29 lx is saying that my rf gain power failed why is that
you may have burnt the diode that a variable controls or you messed with it and burnt it out.
Jan 21, 2014 | Cobra 29 Lx Full-featured Cb Radio
Radiocheck shows rf output power failure
its an inside the radio fix mine is doing the same thing and I have had the time to get into it and fix it.
Jan 01, 2014 | Cobra 29 LX 40-Channel CB Radio with...
Cobra 29 lx chr le rf power output fail
no it didn't fail. the radio is designed not to except any mods without bypassing something . If you don't know what to bypass then leave it alone and turn it back to where it was.
Feb 26, 2013 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
Cobra 25 lx special edition rf power output fail
try it with a different antenna. make sure your swr is low
Jan 12, 2013 | Cobra Radio Communications
I just installed a new 25 lx in my rig, a Freightliner Cascadia. It's automatic test says that the battery voltage is good, but the RF out put is failing. The truck came standard with twin fibergl
It sounds like an antenna or coax problem. Twin antennas are a pain to balance and not worth the effort to install. All twin antennas do is make the antenna manufacturer richer. If the antennas use PL259s that screw into the bottom then they are nothing but water and corrosion traps. You must make sure all connections are clean and tight and waterproofed. I use an MFJ antenna analyzer to check the antennas for all my customers. It can tell you very fast if you have a problem. Any good CB shop will have one. I never trust the cheap SWR watt meters but actually the built in SWR meters on the Cobra radios are not bad indicators. I trust them much more than most external meters. Hope this help at least some. Just use your head and remember that your radio signal needs a good clean and clear unbroken path.
Jul 16, 2012 | Cobra 25 Lx Lx Platform Cb Radio With...
Added new antenna and now im failing rf output and antenna radio test?18ft coax and a 48in ant.
First thing is to be sure the mount is not shorted in any way--and also to make sure that where it is mounted it is actually connected to ground--many newer vehicles have insulators so a bumper even if metal has no ground to work off of.
No ground, open or short in coax, open or short in mounting bracket all can cause no swr or high swr.
May 01, 2012 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
Af audio power amp
May 29, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Older Cobra 25 ltd
Aug 11, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Radio Communications Logo
129 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
