SOURCE: Old Saeco Vienna Superautomatico. Replaced
Try to replace the flow meter in the machine.
Best regards
/Mirran
SOURCE: My Saeco Incanto deluxe started dripping hot water
What color is the steam manifold? It is located under the black cover with the trough in back under the white tube. If its white or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand.
But its going to have to be replaced
the steam valve is plugged or stuck open it is inside near thr steam knob
SOURCE: Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
