Owners manual Simplex 1603-9101
Need an owners manual
2350 manual simplex
If this is for a pa/ bell system for simplex grinnell I would contact them for service as that particular system is a proprietary system that only simplex authorized personnel can work on.
Sep 08, 2014 | Radio Communications
How can i remove a unican lock
You will find installation manuals on this page:
http://www.kaba-ilco.com/kaba-access-control/Documentation-Support/292720/simplex-mechanical-pushbutton-locks.html
You may need to install Adobe reader if you cannot view the documents. There is a "Get Adobe Reader" link found just above the chart if you can't.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Oct 04, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
How do I change the handles from right to left?
If you don't have the print instructions for your lock, go to this web page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
On the grid, go across from L1000 to the "Manuals" column & click on PDF, which will download the file of the manual for your lock.
If you cannot open the file to view it, you need to install Adobe Reader first. You can get the download (free) from here:
http://get.adobe.com/reader/
Now you should have the manual for reference.
Someone else who was wanting to change the handle sent me this information:
"I've got a Simplex L1000 series combination that needs the Outside Lever Assembly-Right Hand and Outside Sleeve Assembly changed on it. I have the parts needed but I can't figure out how to remove the Outside Lever from the Front Lock Housing.
I had the original question. For others viewing and needing the answer it's as follows: After looking and removing the internal parts I still couldn't find the solution, so I ended up sending it to a locksmith to replace the parts. They told me later that ALL internal parts from the Front Lock Housing needed to be removed, then rotate outside lever 180 degrees. Using spanner wrench depress the front knob retainer, then outside lever should slide off. Remove Drive Assemply and Front knob retainer from rear of front lock housing. *The key was rotating the lever 180 degrees. Nowhere in the directions was this mentioned nor was it mentioned in the email reply I received from Simplex.. So for all you out there, Good Luck! And make sure to add this key step to your directions."
As you will find in the manual, you need a special spanner wrench for this operation.
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Aug 11, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Need manual for a simplex symphony sf3003
You can find, download & print the Owners Manual at the Dimplex USA website.
Feb 06, 2011 | Dimplex DF3003 Electric MidSize Heater
I have forgotten the code for my code lock which is on my bedroom door.
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
aspx?id=13
You'll need Adobe Reader installed, as these are PDF files. The manuals show installation and reprogramming instructions.
You can also research other models of locks from this page.
Dec 09, 2010 | Simplex Kaba Ilco Unican 1011 keyless...
Is there a repair manual available for the Simplex 1000 series locks.
aspx?id=13
Good Luck!
Nov 17, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
How do I set teh scanner for simplex scanning rather than duplex?
Well, there is a 'one touch' button for simplex and one for duplex, which most of us would use. Other than that you might spend some time with your manual and review the setup configurations. There are a lot of options.
Nov 10, 2009 | Xerox DocuMate 152 Pass-Through Scanner
Hi, i have an older set of uniden radios that i no longer have the manual for. one of them is stuck on a setting where i can transmit, but can't receive. anybody know how to change this? i'm not sure how...
if i've ever had this prob its because one radio is on "duplex" mode and other is on "simplex", if you know what i'm talking about this info is prob useless, but on most hand held radios there's a button that says d/s, dup/sim or just dup or sim, press or hold to change from simplex to duplex , probably see it on display, but anyway have em both set on same setting either simplex or duplex
Aug 12, 2009 | Uniden 7 Mile two-way Radio
I have a Simplex Bell clock here at the school. I'm trying to program it and am unable to get it to set. Please help me with instructions on how to set the bell clock and how to set it differently for...
Hey, BAC systems are usually microprocessor controlled and normally can be set from the controller with the different times and days the bell would be used. My school ditched their old analogue Simplex controller and retrofitted it with an Entek TC2100 digital time clock controller. I would contact Simplex and ask them for the manual for the control system. Or do what I did, PLAY WITH IT!
Aug 19, 2008 | Office Equipment & Supplies
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
