Question about MotoBatt 1997-2001 yamaha cw50 zuma ii 50 cc battery
2001 yamaha zuma carburetor settings - MotoBatt 1997-2001 yamaha cw50 zuma ii 50 cc battery
2008 Yamaha Zuma shuts off after high speed but starts right up
Hi, Troy and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
Archived Scooter Running Questions Runs Slow Bogs Down or Is Rough
ZUMAFORUMS NET View topic ENG Yamaha Zuma 08 Throttle Mod Tutorial
http://www.scooterunderground.ca/knowledge/manuals/documents/BWS_Zuma_Service_Manual.PDF
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/2008/zuma_lit-11626-21-15_1548.pdf
Jan 01, 2017 | 2008 Yamaha Zuma
Yamaha zuma wont start
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box.
17. A stuck bent or burnt valve.
18. Tip over sensor needs a reset.
19. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
ZUMAFORUMS NET View topic Help my zuma 50cc won start anymore
Scooter Troubleshooting Scooter won start All about Scooters
Yamaha Zuma YW125A Owner Manual
Yamaha YZ125T1 Owner Service Manual
Apr 24, 2014 | 2005 Yamaha Zuma
Yamaha Zuma 50/Cold Start Problem
Hi, James and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
ZUMAFORUMS NET View topic 2005 yamaha zuma yw50t cold start issues
My Scooter wont start if engine is cold scooters
https://www.manualslib.com/manual/781192/Yamaha-Cw50l.html#product
Yamaha ZUMA CW50N Owner Manual
Jan 22, 2014 | 2012 Yamaha Zuma 50F
2011 Yamaha Zuma 125 won't start. Fuel pump is not starting so no gas. What could cause the fuel pump to not start? Only has 160 miles, but out of warranty.
Hi, Stuartsual suspects are:
1. Fuel tank empty.
16. Faulty CDI box.
Zuma 125 Not Starting
ZUMAFORUMS NET View topic 2011 Zuma 125 will not start not fuel pump
http://z125data.weebly.com/uploads/7/1/2/2/7122816/zuma_125_service.pdf
Oct 03, 2013 | 2011 Yamaha Zuma 125
Yamaha Zuma 50 no oil light
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
ZUMAFORUMS NET View topic Oil light on at idle off at open throttle
Need Advice Yamaha Zuma 2005
Yamaha YW50P Service Manual
Yamaha ZUMA YW50T Owner Manual
Mar 14, 2013 | 2008 Yamaha Zuma
Removing the stator in a 2005 Yamaha Zuma
Remove the AC Magneto from Zuma Bws Cygnus 125 Scooter Motor
How To Fix Replace GY6 Flywheel Cdi Stator and Magneto
zuma manual pdf 1 Docs Engine com
Oct 05, 2012 | 2005 Yamaha Zuma
Yamaha Zuma 49cc spark plug gap
Hi, Patrick for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
https://groups.google.com/forum/#!topic/alt.scooter/WPzufPXwCds
yamaha zuma spark plug
http://www.49ccscoot.com/manuals/Yamaha_C3_Service_Manual.pdf
Aug 19, 2012 | 2005 Yamaha Zuma
My 2008 yamaha zuma 125 dies right after starting
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
ZUMAFORUMS NET View topic Zuma starts but dies with throttle
My chinese scooter wont idle or start Check the fuel petcock
http://www.49ccscoot.com/manuals/Yamaha_Vino_125_Service_Manual.pdf
Jul 19, 2012 | 2009 Yamaha Zuma 125
1997 Yamaha Zuma Super Scoot turn signal flasher not working
Hi, Retals57 I would buy the OEM part to be on the safe side for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha CW50L Service Manual
Yamaha Zuma 2004
Yamaha Zuma Wikipedia
Jun 17, 2017 | 2005 Yamaha Zuma
How do you take the governor off a 2005 50cc zuma?
Hi, Ktm0785 for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
How To Unrestrict Yamaha Zuma 50f and Yamaha C3
ZUMAFORUMS NET View topic What restrictors or governors are on 2013 Yamaha...
Oct 12, 2010 | 2005 Yamaha Zuma
MotoBatt 1997-2001 yamaha cw50 zuma ii 50 cc battery Logo
160 people viewed this question
Top MotoBatt Electronics - Others Experts
Robert McCall
Robert McCall
Are you a MotoBatt Electronics - Other Expert? Answer questions, earn points and help others
