CPU Celeron D331 2.66GHz 256K EM64T LGA775 I amusing this cpu on 945GZT Motherboard. In the program nero 7 there is a optionto give you system information about your computer. Every thing is match acceptbus speed which is 133MHz. Is there any place on my computer that I can read theactual bus speed beside cpu specification by manufacturer and motherboard too. I need to know does this is only a bag from nero 7 or it is theactual bus speed, and if is truth on what is that deepens on CPU or Motherboard.What can be the problem.
the front side buss is correct. most motherboards will read 100 or 133 or 200 etc on your FSB because thats the pre multiplier of FSB before it equates to 800/1033/1633/2000mt's etc like for example a amd athlon 64 3700 on a socket 939 has either 1600mt's or 2000 mt's for the FSB and it reads on the motherboard as 200 mhz and the multiplier is at X10 times the multiplier by the MHZ ratting and you get 2000 mt's now your cpu's FSB is 133 mhz and your multiplier is between 6.0 to 6.1 and it will be reading between 798 MHZ to 811.3 abut will not say its running at either on of those speeds because if it was at X6 then it will read at 800MHZ for your FSB so everything looks to be correct. there is nothing wrong with the cpu nor how the MOBO reads it
We have a model G20-101-001 MegatouchXL Touchscreen. When we turn it on it goes to a screen which...
(More)
We have a model G20-101-001 MegatouchXL Touchscreen. When we turn it on it goes to a screen which tells us that there IT SAYS Boot disk failure, Insert Disc and press enter. When we do this it goes to a screen where you can enable and disable but we are unable to get to a regular touch screen???? What is your advice
my optional components in my registry editor have no value and is causing a interruption on the...
(More)
my optional components in my registry editor have no value and is causing a interruption on the download of adobe reader.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
