Question about Samsung Computers & Internet
I have no sound on speaker from from system but it sounds when i speak on mic i have latest driver installed front and rear panel have the same problem
I have also interchanged jack
    Guru:
  • 433 Answers
Hi mukesh roulta :
I make this video for you wish i help
Posted on Jan 15, 2013
  • mukesh roulta Jan 17, 2013
    i have formatted my system the problem is as it is
  • mukesh roulta Jun 02, 2013
    i have also tried new sound card but the is still there
3 Suggested Answers
  • 3 Answers
SOURCE: Intel(R) Desktop Board D945GCL,Window 7
Please ensure that your bios setting is enabled for audio.
1. Have you installed the correct windows 7 driver or have you configured with the vista driver?
2. If you have installed with windows 7 driver, check it for 32 bit or 64 bit and you are installed perfectly!
3. Check the windows service. Go to "run", type "services.msc" and press enter. In that opened window, direct to "windows audio". Open it and check the service is started or not. Also ensure that the startup type is set to be "automatic".
Hoping you will be short out!
Posted on Aug 20, 2011
map9966
  • 2351 Answers
SOURCE: Front panel audio failure-DG33FB Intel mainboard
Your Intel DG33FB board by default was already setup for use. Your board has been configured for independent multi-streaming 5.1 audio (using the back panel audio connectors).
Your board should have come with a shielded front panel audio cable to connect front panel audio as shown on page 45, item B. The pin out for the front panel audio header is shown on page 46, table 5.
If you did not receive this cable you may need to contact Intel.
Check the Intel link included, which shows the cable needed for either AC'97 or HD cabling;
Audio standards: AC'97 and HD audio
Most motherboards will not play audio through the rear jacks when the board is connected to the front audio pins.
Intel like other manufactures do not mention this in their manuals.
Thanks for using Fixya!
Posted on Jun 03, 2009
Mic not working from front jack and speaker not working from rear jack of dell dimension e520 pc desktop. however drivers are installed. plz guide
verify your sound settings. make sure you have it set to the front audio jack in sound settings via control panel
Apr 12, 2012 | Dell Dimension E520 PC Desktop
I am unablem to use the mic for the internet chat!!!!
First of all find the latest version of the audio driver which is compatible to vista, as most of the drivers that are shipped with sound-card or motherboard cd contain drivers which have support for only until windows Xp.
So it is strongly recommended to download the latest audio driver from the internet for your sound-card or on board audio chipset. Install the vista compatible audio driver (sound driver) for your sound-card or motherboard audio. After this re-start your computer. Half of the work is done.
Now plug in the microphone in your sound-card / motherboard audio pin (generally pink in color for microphone).
After this go to control panel > sound and audio device settings. Check whether the microphone is detected by Vista or not. If not, check whether you have selected the frontal microphone or rear, as vista recognizes them separately unlike windows Xp. Correct the configuration of front/rear mic if needed.
Nov 16, 2010 | Computers & Internet
Terrible sound
You may need a headset if 'feedback' is a problem
Check your webcam mic is set as default.
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure your mic/ webcam to the chat program of your choice
May 24, 2010 | Logitech QuickCam Pro 9000 Web Cam
HP pavilion dv9005us. When using built in mic receivers say volume is very low. When I move the lid I get a crackling sound in the speakers like the mic wires a lose ..
To fix the low volume problem in mic receiver follow the steps below:
  1. Click Start , Control Panel .
  2. In the left panel, select Classic View .
  3. Select Sound , and then select the Recording tab.
  4. Right-click on Microphone and select Properties .
  5. On the Custom tab, select Microphone Boost .
  6. On the Levels tab, increase the microphone recording volume to the maximum level.
Then please check if it works fine otherwise you need to install the latest sound driver.
Windows VISTA 64bit and 32 bitsound driver:
ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35684.exe
Windows XP sound driver:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
Install the sound driver as per your operating system.
Apr 04, 2010 | HP Computers & Internet
I recently formatted my computer and am trying to reinstall the drivers, I have them all except now I notice that my sound device is missing from device manager. There is none listed, all the solutions I...
First off, yes, the D915 series of boards all have Audio on board, with Line In (Blue Conn.), Speaker Out (Green Conn.), and Mic (Red Conn.) on the back of the motherboard.
The product manual is available on the intel website:
http://www.intel.com/support/motherboards/desktop/d915gav/av_manual.htm
It states that it includes a 6-channel audio subsystem based on the Realtek AL860 audio codec. The manual will eventually take you to the Intel driver download page:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+915+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D915GAV
The key, I believe to your problem, is to make sure you have:
1. the latest BIOS
2. the latest INF installed
3. the driver set for the ALxxx chipset.
Make 100% sure that within your BIOS that the Audio portion of the board is enabled.
Also, on Page 45 of the manual it speaks of the Front Panel Header (10 pin header between PCI slot and PCIe 1x), and notes the following:
To restore back panel audio, follow these steps:
1. Turn off all peripheral devices connected to the computer. Turn off the computer and
disconnect the AC power cord.
2. Remove the cover.
3. Remove the front panel audio cable.
4. Install a jumper on pins 5-6 (rear R channel).
5. Install a jumper on pins 9-10 (rear L channel).
6. Replace the cover.
Hope this helps.
Jan 06, 2010 | Intel D915GAV Motherboard
I lost sound on messenger, any remedies? Will a uninstall and reinstall work?
cheak the sound driver in your pc if its works then its problem of your messenger then u can remove your messenger and reinstall it if u have lost your sound from pc then put motherboard driver cd install your sound driver
Nov 16, 2009 | Yahoo Messenger
Mic not detecting
The Board have three sound port one for rear one for front and one for mic plug in the mic pin into the mic port red colored.
Then go to the realtek control panel located in the taskbar like a red speaker open it and go to the I/O
options and the mic options turn on front mic.
Jan 31, 2009 | Intel D101GGC Motherboard
MSI 915o comboAudio front panel
Some cases come with a Mic & speaker jack/ cable. These jacks sit within the case. Rather than using the rear Mic which is (colored pink) & speaker (colored green). These 2 colored cables run from the front of the case & out through an emty hole in the back of the case. Which you connect them to the rear of the boards Mic in (pink) & sound (green). Now you can use your front audio jacks for both mic & sound. This may sound strange but I have come across many cases just like this. Its not uncommon to have 2 front usbs & a 1394 connect on to the board as well. Without your manual I'm sorry I can not help you fauther.
Jan 02, 2008 | MSI 915P Combo-FR Motherboard
Microphone
dear mil20, this could be because of multiple reasons:
a) You've muted your mic from the speaker icon in task bar.
b) Maybe your sound driver is not installed correctly, can you play music in your system ?
c) You can check your microphone settings in control panel to ensure you've actually enabled microphone options. Also see if you've set default voice instrument speakers or headphone. Finally see if you've plugged the mic right.
d) If none of that helps you might like to take your mic and system to nearest hardware store to ensure nothings wrong with your hardware.
If that was helpful please press 'fixya'
Oct 22, 2007 | Oracle 10g Database Standard (ODBSEONUPP0)
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
Computers & Internet Logo
26 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
