Question about Motobecane 700DS
Change back wheel on motobecane cafe express 8
Model cafe express 8 (internal hub)
Chain derailleur adjust
1 screw stops it from going in too far (into the wheel) 1 stops it from going out too far (and falling off) and the third is to adjust the tension of the chain
May 13, 2013 | Motobecane Cafe Noir
2006 chevy express 2500. While changing the brakes on my van, a rivet and clip pulled through the rear wheel dust plate, I'm unsure on how to fix this as now one half of the shoe is rubbing agains
get a washer welded in its place but if you dont want to go that way you will need to pull the brake shoes the drive axle just to get to the backing plate so you can remove the old one and install a new one
Jan 16, 2013 | 2006 Chevrolet Express
Removal of rear wheel with internal geared 3-speed and coaster brake hub
Find the joiner link on the chain, remove the retainer clip followed by the link. Remove the chain. Remove the bolt holding the brake arm to the frame. Loosen the axle bolts on the wheel enough to be able to slide the rear wheel out of its slots on the frame.
Feb 24, 2012 | Cycling
It appears that the handlebars rotate, how do you rotate them?
Take your allen wrench keys to the handlebars, near the stem, and once loosened the handlebars will rotate for you.
Oct 03, 2011 | Motobecane Cafe Noir
I need to get a manual for the Motobecane 700 DS? Where and how?
Hi kferic30...
Each bicycle ships with a generic manual which covers some of the basics of ones bicycle.
Go to the following website/websites to access your manual and other information about your bike.
Please take time to rate me
Manual...http://www.motobecane.com/motomanualpage.html
Motobecane Contact site: http://motobecane.com/contact/
Motobecane Home Webpage: http://motobecane.com/index.html
Sep 06, 2011 | Motobecane 700DS
IJust bought a 2009 Motobecane Cafe Latte Hybrid bike used. The previous owner hardly used the bike and it looks new. He stated the bike probably need a tune up and the front derailleur was skipping the...
The derailleur has to be properly aligned to the chainwheels, then adjusted properly. A new cable must be installed correctly so that there is not excess friction, and then given the right tension. If that is done then the problem may be the shifter. If when you shift from the large chainwheel a single click sends it to the smallest then the shifter is possibly broken. You can try squirting wd-40 or similar into it to see if it's gummed up.
Mar 18, 2017 | Motobecane Cafe Latte
Is there a Restaurant Pro Express technical expert in Chicago? I would like personal help regarding the proper setup of RPE for my cafe. Thanks!
I can setup floor plans, employees, & configure menus including modifiers (eg. how would you like that cooked?). I charge $12/hr to setup menus approx 8 hrs for a 2 page menu. Gina 773-807-2000
Apr 06, 2010 | Pc America Restaurant Pro Express
How to replace lug nut studs 2002 chevrolet cavalier
take a hammer and a punch and pound it in, it will pop out the back of the hub assembly, then you get your new bolt, slide it through the back, same way the old one came out, throw a few washers on it and use the lug nut to draw it out till it catches, take the lug nut and washers back off, put the tire back on and use a little extra torque on that stud to insure it is all the way in place.
Good Luck!!
Mar 21, 2010 | Chevrolet Cavalier Cars & Trucks
Motobecane 700DS Logo
80 people viewed this question
Top Motobecane Cycling Experts
Jerry Kramer
Jerry Kramer
Tom Chichester
Donald Ayers-Marsh
Are you a Motobecane Cycling Expert? Answer questions, earn points and help others
