Question about Home
Need repair for Dove Lamp (PAF Studios) in Philadelphia PA area
Dove Lamp (Barbara&Colombo) PAF studios swirch doesn't work. Bulb is OK.
  • Frank Chi
    Frank Chi Mar 23, 2014
    It may not be the switch. I thought mine was the switch. However, it turned out to be the socket that holds the bulb.
I have the same problem and I don't know how to open the base.
Posted on May 27, 2013
  • mary palmer
    mary palmer May 12, 2015
    1) Unscrew the two base screws and remove 2 base parts. 2) the ROP part of the lamp base 'pops' off. Then Gently grab and rock the top (where the space is) by pulling upward, a little more on one side and the rubber ring will let go and you can get inside then to replace switch or whatever.
  • mary palmer
    I would put in a new LED light to replace the halogen one.
The arrival time for a greyhound bus that left 8pm Friday night from Ardmore OK, to Philadelphia PA. All I know is that it's supposed to arrive sometime Saturday.
PHILADELPHIA GREYHOUND
1001 FILBERT ST
Philadelphia, PA 19107
Telephone Numbers
Main: (215) 931-4075
Baggage: (215) 931-4016
Greyhound Package Express: (215) 931-4016
Customer Service: (215) 931-4075
Aug 30, 2014 | Cars & Trucks
Tip
Eagle Dumpster Rental
At Eagle Dumpster Rental professionals in waste management are ready to help with any and all trash hauling, garbage collection and trash container needs. Eagle Dumpster Rental services the entire greater Philadelphia area with prompt and courteous service, including same day deliveries, to meet the demands of all customers. Waste containers for home clean-up projects, construction dumpsters, roll-off containers and junk removal services are all areas of expertise found from Philadelphia's top waste management and garbage collection provider, Eagle Dumpster Rental. Eagle Dumpster Rental In Philadelphia PA Wilmington DE Nearby Areas
on Oct 05, 2016 | Home
Pa
per fcc rules (laws)? you cannot put an amp on a cb. max output 4 amps. you should be able to put a pa speaker using the pa output jack. take your radio back for warranty.
May 19, 2013 | Cobra 19 DX IV CB Radio
I have a PAF DOVE halogen lamp. Only the lower wattage of the lamp works. How can I tell if it's the switch or the halogen bulb? If it's the switch, where/how can it be repaired? Thanks for y
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to Factory Installed Systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 31, 2012 | Cars & Trucks
How to garphics program in turbo c++ 4.5 ? Please give an elaborated example.
problem is not turbo c++ but your windowswindows only upto xp support bgi graphics vista and 7 doesn't.You can compile the program on any xp machine or try Linux.orTry using the visual studios to compile on windows.You can easily search on how to compile c/c++ in visual studios
Jul 04, 2011 | Borland Turbo C++ 4.5 Full Version for PC
Got projector out after several years of non use. Lamp would not light. We purchased a new bulb and installed it. Still doesn't work. Fan runs and all, but bulb will not light.
Check the internal power and lamp fuse. Sometimes, when a projector is stored, an area of corrosion develops around the lamp pins and lamp holder. If you carefully clean both the holder and the pins on the original lamp you may find it works OK!
May 21, 2011 | Kodak Ektagraphic III-E-Plus 35mm 140...
I have PRO-2033 Radio Shack scanner, where can I get police & fire codes for this in Philadelphia, PA area
For a comprehensive database of active frequencies (they're not codes) in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
The Philadelphia area has likely moved to trunked radio systems in the 800MHz band, and your scanner is not capable of receiving such signals, so you'll be limited in what you can tune in with your PRO-2033.
Bill B.
Listening in since the 60's
Jan 03, 2011 | Radio Communications
Broken screen need prayer repaired
You are in luck - Philadelphia is one city where you can actually get mp3 player repair. Call Nerds Next Door at 1-888-596-4321 - let me know how it goes.
Guest - if you know how to use a soldering iron, there is a YouTube video that will show you exactly how to repair your screen. If I were you, I would just call Sansa and claim your warranty, but maybe you are out of warranty.
-Tha Mp3 Doctor
Jan 08, 2009 | SanDisk Sansa E280 MP3 Player
Home Logo
675 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
