Question about Braun Flex Integral 6520 Electric Shaver
Manual Braun 6520 Flex Integral electric razor.
Where can I access to the Braun 6520 Flex Integral electric razor's manual so we can replace a used battery to fix a power supply problem? RP
SOURCE: Braun 6520 shaver stops working after one use on batteries
dear sir, i have one like yours,your shaver need to change the battery.
Posted on Aug 12, 2007
SOURCE: opening Braun 2540
Yeap! I just did it violently... :S But luckyly didn't break anything. Anyway, the right way: First screws of course. Then you can open it a little bit, and you can see a white part at the bottom. It moves sideways and releases the cover. Hope you can make it easier than me!
Posted on Oct 05, 2007
SOURCE: how do I open the case to change the battery?
There are 2 removable plastic plates on either side of the power entry connector> Pry these off with a knife and remove the 2 screws. Next slide the razor out of it's case. The batteries are soldered in.
Gary
Posted on May 25, 2009
VtToolMan
  • 704 Answers
SOURCE: My braun Flex 6520 does not turn on. When the cord
The cost to repair this isn't going to be nearly as much as a new Braun shaver as nice as this one.
The problem is that your rechargeable batteries have become degraded to the point that they won't take and hold a charge. Because the batteries have become so degraded, that even with the power cord plugged into an outlet, you still can't use the razor solely on AC power either.
If you want to have the shaver repaired for you, you can contact www.electricshaver.com or give them a call at 1-888-476-1785 to get an estimate of the repair costs. Typically it takes about a week or less once they receive your shaver. They also stock most parts for many brands of shavers, including your Braun. I've used them for getting parts for several of my shavers and found them to be a very good company.
If you're handy and have a soldering iron you can disassemble the shaver and remove (unsolder) the bad batteries and solder in a new set. There are two small caps on the bottom of the razor that cover the screws that hold the body havlves together. Remove these with a small pick or small flat bladed screwdriver and remove the screws and carefully remove the body halves and that will let you get to the main board and the batteries.
Simply heat up your soldering iron and melt the end tabs off the batteries and remove them. Then solder in the new ones and make sure they are properly secured and have adequate solder on the tabs for a good connection. Put the covers back on and install the screws and and the caps and your all set for recharging the shaver. Let it charge for at least 8 hours and you should be all set!
So whether you decide to have the repair done for you, or do it yourself, I hope you find this Very Helpful and best regards!
Posted on Oct 10, 2009
brector3
  • 1600 Answers
SOURCE: My Braun 5564 electric/rechargeable razor will no
You will need to replace the battery pack. Depending on when your shaver was made, it may have one of two different battery types. You will ned to look inside to see which you need before ordering.
To open, remove the two round screw covers on the bottom of the shaver. Remove screws to remove bottom of shaver. The outer case will then slide off the bottom. Push the trimmer up to be abl to take the circuit board out. BE CAREFUL not to detach trimmer oryou will not likely get it back on yourself.
Your battery(s) will be one of the two types below found at shaveroutlet.com
http://shaveroutlet.com/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Be sure to read the Note on the second link concerning instalation
If you are unable to do this yourself, shaveroutlet.com can do the repair for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Posted on Feb 06, 2010
I need instructions on how to replace the battery in my 7526 Braun razor I have a new battery ordered for my razor but can't see how to get inside the razor?
Here is a link to a short video on Youtube which demonstrates fairly well the procedure for disassembling a Braun 6520 model:
http://www.youtube.com/watch?v=K7U-A4MC2A8
The procedure outlined in the video will be similar to the one required for disassembling your model 7526 shaver. Here is a link to the user's manual for that model in case you do not have it already:
http://www.service.braun.com/line/SH/S5493/S5493_14_NA.pdf
To view the Youtube video or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 29, 2011 | Braun Syncro 7526 Electric Shaver
Where in Australia can I buy a foil
You can purchase a new foil for Braun model 5314 at shaveroutlet.com and have it delivered to your mailbox in Australia. See link below to webpage
http://shaveroutlet.com/shaver-replacement-parts/braun-5000-6000-series-flex-integral-flex-xp-foil-p-350.html
May 06, 2011 | Braun Flex Integral 5314 Electric Shaver
Battery is fine - but green light showing recharge is no longer lighting and no electricity is getting to battery. It has NEVER been dropped or mishandled. Shaves fine but only on minimal battery power...
Assuming that your cord is not damaged, the circuit board is bad. This most often happens when you continue to use the shaver well after the batteries have lost their ability to hold a charge well.
You will find a new circuit board for model 6520 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-106.html
Apr 01, 2010 | Braun Flex Integral 6520 Electric Shaver
Braun 6520 is not charging after changing the battery board.
there may not be anything wrong with the batteries and circuit board at all. you may have a bad motor
Dec 27, 2009 | Braun Flex Integral 6520 Electric Shaver
My braun Flex 6520 does not turn on. When the cord is plugged in no red or green lights come on. Is this a costly repair? Would it be better to buy new as this razor is approximatley 5-6 years old?
Oct 08, 2009 | Braun Flex Integral 6520 Electric Shaver
The on/off mechanism on my dads braun 6520 is stuck. It won't turn on.
Hello running girl, Have you looked to see if maybe the "lock-off" feature hasn't been engaged?
If you look at the razor, right above the on/off and sideburn trimmer selector, you should see a full bar that goes all the way across the shaver. Push this up toward the shaving head to unlock the razor and the shaver should work fine again.
This is a Braun design feature there to help prevent the shaver from accidently getting turned on when packed in your luggage, etc. and running down a fully charged shaver.
There is nothing like reaching for what you thought was a charged and ready to use shaver and discovering that it got switched on and ran the batteries down.
Other than having the lock off feature engaged, I can't think of anything that would cause the switch not to turn on, unless the shaver was dropped and damaged. If that's the case, you will want to have it looked at to make sure the printed circuit board hasn't been broken, etc.
Typically this isn't something that most folks can undertake a diagnois and repair, so I'd suggest you contact www.electricshaver.com or call them at 1-888-476-1785 to get an estimate for repairing it.
Hope you find this Very Helpful and best regards!
Oct 06, 2009 | Braun Flex Integral 6520 Electric Shaver
Braun 6512 shaver stop working
hi i would say that you have major problem with this did you drop it sounds like a problem with the circuit contact braun or shavers uk kevin.
Oct 30, 2007 | Braun Flex Integral 6520 Electric Shaver
Jun 10, 2007 | Braun Flex Integral 6520 Electric Shaver
No power
The motor brushes may be bad. Take the screen off and turn the shaver on. Manually move the blade back and forth a bit and see if it starts to engage. If it begins to run when you do this, the brushes are worn. Braun does not make replacement motors for your shaver
Jul 11, 2017 | Braun Flex Integral 6520 Electric Shaver
Braun Flex Integral 6520 Electric Shaver Logo
67 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
