Question about Magic Chef Built-In Dishwasher
Upper wash arm spinner keeps falling off during wash. It was replace with new one but continues to happen
Upper wash arm spin
Kenmore ultra wash III portable dishwasher. Model #1765991. Lower wash arm came off. How do I re-attach?
Hello. The lower spray arm screws down onto the center, round, plastic part (spinner) that has threads on the center portion. It's very loose and spins easily because it uses the water spray to drive it. At the top of the threads, there will be a flat piece of plastic. Set the spray arm down onto the threads. Hold the flat plastic area that sticks out above the arm with pliers. Spin the spray arm counter-clockwise while holding the spinner. It will thread itself down about a turn or so. Snug firmly--DON'T OVER-TIGHTEN the spray arm onto the spinner. Remember, it only uses water pressure to spin so it doesn't have to be "gorilla tight"! I hope this helps you!
Oct 14, 2015 | Kenmore Dishwashers
Tip
Replacing a Rear Tub Bearing
Rear Tub Bearing Replacement
(Part 1 of 3)
This advice is for replacing the rear wash tub shell of most Kenmore Elite HE model FRONT LOADERS, along with Whirlpool Duet, and some Frigidaire FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
(cont’d)
on Jul 07, 2008 | Kenmore Elite 45986 Front Load Washer
Tablet keeps coming out of the dispenser on my hotpoint fdl 570 dishwasher on all cycles and falls on to the floor, result is that the crockery isn't always clean on the top tray. Machine is still...
Hi Jeanette,
Maybe I misunderstood your question, but the tablet is supposed to come out of the dispenser and fall into the bottom of the dishwasher. It needs to fall into the hot water in the bottom of the washer to dissolve. The dispenser releases the tablet at different points in the cycle depending on which wash cycle is selected. On a shorter cycle it will be released soon after starting. On longer cycles, there is usually a rinse first, so the tablet will be released a little later. There would only be a problem if the tablet wasn't being released, or wasn't dissolving completely.
There are a number of reasons for poor cleaning on the top rack. The most common are the upper spray-arm not spinning, incorrect stacking or overloading. If the upper spray-arm isn't spinning, there may be caused by a blockage in the spray-arm or the water delivery system, but, as the dishwasher is new and it's not happening every time, it's possible that the dishwasher isn't levelled correctly. The spray-arms aren't motorised, they use water pressure to spin, but they wont spin if they aren't balanced, i.e. the dishwasher isn't level.
You can check whether the spray arm/s are spinning by pointing them front-to-back, or left-to-right (so you can remember the position) and allow the dishwasher to run for a few minutes. Then open the door and check the position of the spray arms. They should continue to rotate slowly for a short while after opening the door, but if they're in the same place and static, they're not spinning. I'd suggest repeating this a couple of times to eliminate the possibility of them having stopped in the exact same place you left them.
If the spray arms are spinning, test the dishwasher with only a small load in the top rack. If the top rack comes out clean with a small load, you may be overloading it or stacking it incorrectly some of the time. There should be a correct stacking guide in your user manual.
Hope this helps. If you need further assistance, check whether the arms are spinning then post back.
Regards,
BElectric
Jul 03, 2011 | Dishwashers
Dishes in top rack do not clean. both upper spinners do not appear to be spinning when running. They spin by hand but not spin on their own during cycle.
When my wife started complaining about her dishwasher not getting the top rackclean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 18, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
GE dishwasher arm keeps falling off. what is the
you should replace 3 parts in diagram,these are the upper spray are,the bearing,and the holding screw the #s are AP3191593/AP3794248/AP3425295 they coincide with the above parts and are all G.E. part numbers
Sep 10, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Upper rack spinning device fails to aquire water and does not spin
Jeff, When a dishwasher acts like this, the most common problem is a blockage in the sump area, underneath the lower spray arm. Removing any/all filter and covers down there (screws will need to be removed) and inspecting with a flashlight, remove all debris (watch out for broken glass!)  Also, inspect the "impeller" that is turned by the wash motor for damage or being loose while you are down there.  Reassemble and test out.
If problems remain, the next most common problem is a failed wash motor.  It is common over the years for it to weaken as it heads towards total failure.  These motors, when they fail, can not be repaired, rather they must be replaced.
Please post back with what you find, OK?
Apr 14, 2009 | Kenmore 24 in. 16152 Built-in Dishwasher
Wash Arms not spinning --Dishes not clean
Without the model number of your Maytag number, I can not determine if when you order a wash pump motor you also get the impeller.
Sounds like you are on the right path to getting your dishwasher to wash dishes again.
Oh, while you have the dishwasher open, check that the heating element has not failed using a Multimeter.
Good Luck!
Feb 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Top spinner arm of dishwasher keeps falling off
did you solve this. we have the same problem. the piece that the arm is connected to is slightly broken. I don't want to pay for a service call. let me know what you did.
Sep 07, 2008 | Dishwashers
Upper Spinner Falls off
rachir...I believe the manufacturer redesigned this spinner. You can find the part at this link http://www.repairclinic.com/0080.asp Catriver...post back.
Jan 11, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Magic Chef Built-In Dishwasher Logo
20 people viewed this question
Top Magic Chef Dishwashers Experts
240cpa
Are you a Magic Chef Dishwasher Expert? Answer questions, earn points and help others
