Application file not executing. Reason :program too big to fit in memory
  • 54 Answers
That used to happen on older machines if your C:\ is full.
If you are receiving this message while your attempting to install software, re-download the application and run setup again.
If this is happening for all applications, it could be virus/malware.
Posted on Jan 12, 2013
3 Suggested Answers
leethedeuce
  • 4472 Answers
SOURCE: Program too big to fit
First off how much memory do you have what is the exact error message. What programs does this happen on. Please give me as much information as you can so I can assist you further.
Thank you,
Lee
Posted on Aug 02, 2010
  • 44 Answers
SOURCE: the system tool program automatically
Here's a removal guide: How to remove System Tool (Uninstall Guide)
Also, a removal video:
Posted on Jan 15, 2011
The application failed to initialize properly (0xc0000005). click on ok to terminate the application
"An application error has occurred and an application error log is being generated. Exception: access violation (0xC0000005), Address"
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back Symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation (such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with SafeSEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offence, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
You can read more about DEP at:
http://www.updatexp.com/data-execution-prevention.html
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers and then "Google" to see if their are any other folks reporting this issue. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the tag, an access violation may occur.
Mar 03, 2011 | Computers & Internet
Program too big to fit in memory. I keep getting this message on windows 7 when i run .exe files or applications. I need to fix this.
Please let me know the name of the program. Also, it's important if you can let me know the programs installed on your system and the system configuration.
(this isn't a solution, this is only a clarification)
Awaiting.
Thank You.
Aug 02, 2010 | Computers & Internet
I forgot my memory card password,how can i solve this
  1. Check if your phone has the executable filename of "UnlockMMC.app located in the z:\system\app folder. Note that not all S60 phones have this file. And if it does have it:
- Run the executable file unlockMMC.app
- Enter new password you like (ex. "12345")
- Run app Memory (phone app memory standard)
- Choose to unlock memory card with that new password
2. There are cases wherein if you lock your memory card with a password, the phone creates a folder in c:\system to save your password with the file name mmcstore. And in order to see the file, you must set your file browser application to show hidden files.
- Send that file into your PC
- Change the file extension into .txt
- Open the file using Notepad
- You will see your password lock
OR:
- If your phone has a notepad application
- Copy that file into the folder
- Change its attribute, do not make it a system and a hidden file.
- Run the Notepad application in your phone
- Open that file
Jun 13, 2010 | Nokia 5310 Cellular Phone
HOW TO INSTALL APPLIATION IN SAMSUNG S3310 METRO
In Samsung s3310 mobile,installing games is itself a big task and you did that.
The reason is only games folder can run Java executable files(.jar) files.When we move Java executable files(.jar) to application folder,it cannot execute the .jar file.Therefore the applications like call tracer which runs in background mode could be installed but cannot run in s3310.
only games and applications like dictionary(which does not need background running mode) can run in Samsung s3310 in games folder.
May 12, 2010 | Samsung SGH-L700 Cell Phone
Xppro on startup box appears with ref to Twonkymedia startup application error
A program that contained Twonkymedia was probably deleted. Even though it was deleted a reference remains in the start up files and when start up files are executed it can not find the program to start it thus "start up application error". To get rid of the error message you can remove the reference to the program in the start up menu or reinstall the program and let it execute normally on start up.
Oct 12, 2009 | Microsoft Windows XP Professional
What is a computer virus?
a computer virus,, make your system files, to corrupt,, the system cannot boot some times,, your working files,, documents,, pictures,, all will not open. depending upon the type of virus.. ,, for that an antivirus ins installed to detect virus and clean computer,,
Sep 27, 2009 | Bell Computers & Internet
I am unable to open any Microsoft Office 2007 applications
do you have other applications running in the background? Close them down, also the Internet explorer. Check in the taskmanager that you have no other application running and try to start the application again.
Check the available space on your drive c:
Is Microsoft Office installed on a server then the server maybe running out of space and you should report this to the server administrator.
Aug 27, 2009 | Microsoft Office Professional 2007 Full...
Application error - the application failed to initialize properly (0xc0000005) when launch Import Media (HandyCam/Dics) application
..a while back symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
Some software/application behaviors are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation
(such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with Safe SEH must have their exception handlers located in executable memory regions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offense, contact the vendor for a resolution...
/NOEXECUTE
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers.
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur.
WHY are you using IE6 still??? Upgrade to IE 7 today!
...and that should have now resolved the 0xC0000005 error for you!
Please rate this fixya
Oct 11, 2008 | Sony DCR-DVD608E DVD Camcorder
Intellinav.exe application error
/NOEXECUTE
CAUSE:
Aug 30, 2008 | Nextar Q3 GPS Receiver
Computers & Internet Logo
David Payne
David Payne
