I have a zanussi fl828 it has dirty water coming in and the drum wont turn when in cycle
  • 15,935 Answers
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
I have a Zanussi fj1254 w. It was making a high pitched squeel when it was spinning. No when I turn it on water goes in but the drum does not turn. It turns freely when rotated by hand. i have checked the...
Possible that the drive output to the drum is not there and so there is no voltage when the cycle come to the spin mode.
Check for fault in the drive, capacitor to the motor.
Jan 21, 2013 | Zanussi FJ1254W Front Load Washer
FL828 LIGHT ON BUT NO WATER DRAWING INTO MACHINE.
Most of the time water wont go into the machine is because calciem or rust build up shut off water unplug , Then take off each hot an cold water lines in back of washer using a small pliers or a screwdriver pull the screens from both outlets replace with new ones or a simple cleaning with C L R This should take of the problem. Good luck
Apr 13, 2011 | Zanussi Washing Machines
Zanussi ZJD1219 Washer/Dryer - noisy spin and dirty spots
Sounds like the main drum bearings have failed, and the marks on clothes are probably grease spots from the main bearings.
It is quite an involved repair, and not one that I would recommend you tackle yourself unless you are competent to do so,as it really is involved.
Please rate my solution.
Thanks.
Nov 15, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Need instruction manual for FL828 Zanussi
Dear Friend,
ngfam1 at your service
I am happy to assist you!!!
At this site you may find where to go to get it!
http://www.user-service-manuals.com/zanussi/FL.shtml
OR
GO ONLINE TO THE MANUFACTURES WEB SITE AND DOWNLOAD OR ORDER THE MANUAL
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
You will be fine now!
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 28, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
May 29, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Heating element Zanussi washing machine
remove the back, the element is at the bottom of the drum tis maybe a split cabinet, where the lid comes off the it splits down the middle like cracking an egg, loads of screws, hard to describe, also 2 at bottom at the side in the middle, behind 2 plastic lugs, when removed the back half of the cabinet comes away, not an easy job until you have seen it done if you really are stuck try and send me an e mail address and i will send you a drawing, then you will see its easy, i am an engineer of 20 years and done loads, its easy job to do once you know how to split the cabinet
Oct 05, 2007 | Washing Machines
Washing Machines Logo
109 people viewed this question
Top Washing Machines Experts
