Question about Refrigerators
Candy wine cooler error e2
Temperature sensor WRITE E2
chanddra2009
  • 615 Answers
SOURCE: E2 fault on Bosch kgu3201
Dear Sir,
It's a thermistor error, the internal evaporator one... but disconnect the fridge and freezer ones first in turn to see if the error changes. If it is the internal one, you should see an arrow impression on the paper covering the insulation which marks the spot to dig(at the back of the freezer.) Usually this error occur when water ingresses the push on tags, shorting out the thermistor.
Now the bonus... 9 times out of 10, you don't need to buy a spare, as there will probably be nothing wrong with the error giving thermistor. Remove and fit the fridge thermistor in the place of the internal one... clean and dry the internal one you removed and refit it inside the fridge.
You will need to repair the insulation with two pack brown foam insulation and foil tape. deffinately this solution solves your problem.If you have any problem regarding this issue post comment more information about the problem.we will glad to assist you
good luck.
good luck
Posted on Aug 26, 2009
Testimonial: "Thankyou - this does appear to be the answer to the problem and it is now working again"
aborcass
  • 2651 Answers
SOURCE: Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Posted on Mar 01, 2008
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
SOURCE: HOTPOINT MISTRAL plus 8596 fridge E2 code
Go to this site: http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewforum&f=35
Type "Mistral Thermistor" into the search and help will be availible. You have a very common problem which is an easy fix in most cases. Good luck.
Posted on Jul 21, 2010
SOURCE: Hello, I have BW40 wine
There are 2 sensors in this wine cooler. Malfunction of each leads to E1 or E2 fault codes. One is easily accessible inside the fridge (small white torpedo sensor with pair of wires attached). The second but identical sensor is buried within the foam on the rear of the cooler. Unplug from mains, take of the electrics from back of cooler, take off sheet metal back and the sensor will be deep in the foam and can be replaced easily after digging out some foam. When replaced make sure the sensor is in the same place it stops the cooler icing up. Use gap-fill foam to keep insulation good. Dr_Nicholas
Posted on Mar 06, 2011
BWE40 wine cooler. Is it safe to leave it switched on when code e2 is showing? Does code e2 distinguish which of the two sensors need replacing? Thanks.
Hi All,
I had this error on my wine cooler. I checked the sensors and got a reading Kohm from both, however i still decided to replace the rear sensor - buried in the foam. It is located in the foam about 20cm from the LHS and 20cm from the bottom of the foam.
I got the sensors from here https://www.inter-spares.co.uk/?subcats=Y&status=A&pshort=Y&pfull=Y&pname=Y&pkeywords=Y&search_performed=Y&q=49032008&dispatch=products.search
I left the front (internal sensor) and just swapped the two terminals in the 4 way plug. I used normal expanding foam to fill the areas where i had removed the foam looking for the sensor. All up and running now.
May 11, 2014 | Baumatic BWE40 Wine Cooler
Kelvinator beverage cooler E2 error code
Temperature sensor error code.
Login'Contact Us Appliance Appliance Repair Questions? Ask a Technician for Answers ASAP
Ask an Expert Home Improvement Questions Appliance Technician
How JustAnswer Works:
  • Ask an Expert
  • Get a Professional Answer
  • 100% Satisfaction Guarantee
Ask Daniel Your Own Question
Daniel, Home Appliance Technician
Category: Appliance
Satisfied Customers: 16124
Experience: 20+ yrs. experience in white goods repair. NVQ Level 2 electronics manufacturers training courses. Type Your Appliance Question Here... Daniel is online now Hi, I have a BWE40 Wine Cooler and an E2 Error Message.
Resolved Question:
Hi, I have a BWE40 Wine Cooler and an E2 Error Message. What does this mean please?
Submitted: 3 years ago.
Category: Appliance Share this conversation
Expert: Daniel replied 3 years ago.
Hi
E2 error code is a temperature sensor error code.
Remove the plastic black cover on the back and you will see the control board.
On the board you will see a wiring block with 4 thin wires going to it.
Test the 2 wires on the left and the 2 wires on the right with a multi meter. The reading in Kohms (kiloohms) should be the same.
If any are faulty then they will need to be replaced.
If the readings are the same, replace a faulty control board to be rid of the E2 error and your problem.
Feb 12, 2014 | Marvel 61AR Compact Refrigerator
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
Danby silhouette dwc276bls e2 error solution
Hi There,
The E2 error codes indicates there is an problem with one of the sensors.
Please contact our customer service department for information on repair.
1-800- 26- Danby
Thanks!
Jul 19, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
Avanti error code e2 wine chiller, what is the problem?
Display flashes Error message "E2" - Defrost sensor (Coil Sensor) failure.
Contact the Avanti Service Department - 1-800-220-5570
Hope helps.
Jun 03, 2011 | Avanti WC42 Wine Cooler
My Dome 40 bottle electric wine cooler keeps flashing E2. Does anybody know what is the problem?
Hi and welcome to FixYa, I am Kelly.
The defrost thermistor has failed. This E2 error code means that your appliance has experienced a defrost sensor fault. The bad thermistor will be near the top of the evaporator coils.
Thanks for choosing FixYa,
Kelly
Apr 25, 2011 | Refrigerators
Hello, I have BW40 wine cooler. On the display is blinking error message "E2". I have tried to switch off and switch on, but it doesn't helped. Thanks for you support in advance. br, Zoltan
Sep 28, 2010 | Baumatic BWE40 Wine Cooler
Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Jan 20, 2008 | Haier BC112G Wine Cooler
Code E2 showing in temparature display
I contacted the technical team at www.baumatic.co.uk and here is the reply I got.
-----Original Message-----
From: Samantha.Codd@baumatic.co.uk [mailto:Samantha.Codd@baumatic.co.uk] On Behalf Of Technical@baumatic.co.uk
Sent: 25 January 2008 13:02
To: Taline Bedrossian
Subject: Re: BWE40 wine cooler
Good Morning.
Thank you for your e-mail.
This error code means that your appliance has experienced a defrost sensor
fault. Please contact our service team on 01189 336 911 to arrange a
suitable time for an Engineer to visit you.
Kind Regards
Quality and Technical Department
Baumatic Ltd
www.baumatic.co.uk
Jan 19, 2008 | Baumatic BWE40 Wine Cooler
Refrigerators Logo
508 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
