Question about Brother MFC-210C All-In-One Printer
I have got the error message " unable to clean , see troubleshooting and routine maintainance in user's guide" . I have tried all ways in the user's guide and also other suggestions. Please gi
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
If your your printer cannot clean automatically, your printer head is probably clogged so badly that you will have to do it manually.... your manual should tell you how to remove it...
Posted on Jan 12, 2013
SOURCE: Unable to clean
r434
Posted on May 06, 2008
faxman789
  • 297 Answers
SOURCE: Print unable error message
Try this link for your solution...is related to 3A...
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002500/000055/faq002555_001.html?reg=us&c=us&lang=en&prod=mfc9440cn_all&Cat=11
Posted on Jan 17, 2009
SOURCE: Printer not printing!
You need to reset the Purge Counter.
To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance
mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail
to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times
to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log
information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter.
The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Posted on Apr 08, 2009
the kowalski
  • 86 Answers
SOURCE: Error Message: Unable to Clean
Machine error 46 ("Unable to Clean") indicates the wasteink "sponge" as full, which disables the machine's ability to clean. To fix this, you could get the needed part from a Brother parts dealer and enter the servicemode to reset the counters. However, the more reasonable thing to do would be to just change to another machine. You could also have the machine sent to service, but that most likely would not be worth the trouble. The error is pretty common on old Brother inkjets, so it'll come back eventually even if you replace the part. Newer machines should not have this problem.
Posted on Jun 03, 2009
komguy
  • 2306 Answers
SOURCE: unable to clean see troubleshooting and routine
Unable to clean means the ink absorber box is full. You will need a shop to replace the waste ink absorber box and then reset the waste counter in service mode.
Posted on Jan 29, 2010
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
Unable to clean-see troubleshooting and routine maintenance chapter in user's guide. . .nothing happens when I do what the guide says
I have a MFC-420CN. If you have followed the guide and have no results, you can call Brother Customer Service : Canada 1-877-2768437 or USA 1-800-284-4329.
Apr 02, 2012 | Brother MFC 420CN All-In-One InkJet...
THE LCD SCREEN SAYS PRINT UNABLE 50 AND SEE TROUBLESHOOTING AND ROUTINE MAINTENANCE CHAPTER IN USERS GUIDE.
Read the users guide and do what they say in the Troubleshooting and Routine Maintence Chapter for the "Print Unable 50" error message.
Mar 29, 2011 | Office Equipment & Supplies
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Unable to clean See troubleshooting and routine
the porous pad in your printer need to be replaced and the ink counter need to be reset... you will need to go into the service mode to reset the waste ink counter
Feb 18, 2010 | Brother MFC-5440CN All-In-One InkJet...
Unable to print see troubleshooting and routine maintainance in users guide Have read through guide, followed all instructions,cleaned, replaced cartridges , turned off at main supply AND still same...
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then
restart the printer, hopefully without the annoying cannot clean message.
Oct 26, 2009 | Brother MFC-5440CN All-In-One InkJet...
Printing after being on same phone line as printer/fax
This link will open the Users Manual, but you will need a PDF viewer such as Adobe Reader or Foxit Reader in order to open it.
Go to page 12-4 in Chapter 12, Troubleshooting and routine maintenance. Follow the actions recommended for the Unable to clean error message (and the four other Unable to... error messages).
Jul 04, 2008 | Brother MFC-3240C All-In-One InkJet...
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-210C All-In-One Printer Logo
87 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
