Question about Xerox CopyCentre C20 Black and White Copier
My copier moans. and will not work
This copier has been worked great for years. recently it stared to moans when copying. Now when I turn on the maching: it moans and then kepts trying to warm up. can you help me?
    President:
  • 2,072 Answers
2 Things I can think of off hand. Try removing your drum and then turn it by hand. The cleaning blade will tuck and sort of jam up in the drum cartridge, making a moaning sound.
With it trying to warm up though it may be a bad fuser bushing.
To remove that, open the right side door, on the upper portion of the transport you will see an item with a couple of yellow warning stickers on it, that is the fuser. Look on each side of it, you will see 2 silver phillips screws, remove those along with that plastic cover on tne back side, disconnect the one white plug and remove the fuser. Try to spin that, if that is really really tight you will have to replace that unit. Those are the most likely problems, could be the toner cart, tho less likely. If the main motor or laser motor were bad the machine would fault out.
Let me know, We will resolve this.
Posted on Jan 22, 2009
How do I troubleshoot a copy/print problem
try downloading a update driver for it from the net
if that doesn't work consider an updated version
Mar 19, 2015 | HP Officejet Pro 8500 A910A Multifunction...
Ny car feels stiff to turn and making a moaning groaning noise upon early morning start up. Seems like its low in poswer steering fluid. Where is the power steering fluid vessel located under the hood?
Depending on what year the vehicle is, the resevoir/pump should be located on the driver's side (left) and in the very front. If it is already moaning, you might be looking to replace the pump as with no lubrication it will wear down the bearing and the veins in which pump the fluid to create hydraulic pressure. You may add automatic trans fluis (Dexron/Mercon) which will work great (unless otherwise stated on the lid). Find out where the fluid is going so you don't do further damage and possibly end up in an unsafe situation. Let me know if you need further help. Love Mercedes!!
Oct 22, 2010 | Mercedes-Benz E320 Cars & Trucks
Printer won't work
You got a 12 month warranty, use it !!
Jun 27, 2009 | Samsung SCX-4500 Laser Printer
Cannon NP 6551 (Danka A50) Touch Screen Lost Brightness
SOMEONE TURNED THE CONTRAST BUTTON ON YOUR DISPLAY, YOU JUST NEED TO READJUST BY PRESSING AND TURNING TO DESIRED CONTRAST
Apr 03, 2009 | Canon NP 6551 Black and White Copier
OfficeJet G85 Makes Unreadable Copies
Usually, it's the print cartridge. I recently installed a new black cartridge on a 6110 printer and it, too, was very faint in printing. It turned out to be "dried up", even though it was a new cartridge in a sealed bag (but purchased in 2005).
Feb 07, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Xerox XC1020
1st you need to know what error code it is giving to know where the problem is coming from
Sep 23, 2008 | Xerox CopyCentre C20 Black and White...
Hello hope you can help me
You can download the driver here:
http://www.nodevice.com/driver/company/Lexmark.html
Just look for lexmark X5470.
Sep 13, 2008 | Lexmark X5470 All-In-One InkJet Printer
Al1540cs problem
check the toner and cartiga
Sep 05, 2008 | Sharp Office Equipment & Supplies
My copier won't print.
Are you sure that your scanner bulb is working. You may hear the scanner moving but the bulb may be burned out which will cause you to get blank pages.
Inkworks
May 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Xerox CopyCentre C20 Black and White Copier Logo
87 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
