Question about DeLonghi BAR 32 Espresso Machine
Not dripping, or dripping VERY slowly
I ran a vinegar solution thru my machine and got busy and forgot about it. It was running "dry" for probably 15-30 minutes. I tried to make a cup of espresso this morning and it barely dripped. The motor comes on, but doesn't seem to be making coffee. Is my machine a done deal or is it possibly repairable? Thanks!!
SOURCE: failing delonghi espresso machine ed140
check the filter holes. They might need to be cleaned with a needle.
Posted on Aug 31, 2007
SOURCE: Describe your DeLonghi BAR 32 Espresso
many of them having DeLonghi BAR 32 Espresso is suffering from the same problem it cannot be solved it is this model's drawback
Posted on May 15, 2008
  • 143 Answers
SOURCE: Describe your DeLonghi Caffe Nabucco BCO70
requires replacement group seal and or coffee ground too fine
Posted on Sep 14, 2009
  • 10 Answers
SOURCE: the machine is making a grinding noise and barely
Check the grind on the espresso... may be leaning too fine. also you may be overloading the portafilter...the model will only handle like 12-14 grams I believe.
Posted on Apr 08, 2010
  • 407 Answers
SOURCE: I have the DeLonghi BAR32
Try running white vinegar instead of water.Let me know if it does not work.
Posted on May 18, 2011
Keeps dripping after coffee is finished
There could be a small clog in the line where it slows the flow & then remaining water continues to slowly drip after brewing is done. Try running vinegar through it.
Nov 30, 2017 | Coffee Makers & Espresso Machines
Bialetti mini espresso coming out very slowly
Hi there... have had this problem. sounds like you have minerals deposit problem. Put vinegar in water tank, then start machine to let all vinegar come out , it should clean it well. then do over again with water so next coffee doesn't taste like vinegar .If by the time the vinegar pasted through and water doesn't come out faster , it must be another problem. Hope this helps.
Mar 10, 2015 | Bialetti Coffee Makers & Espresso Machines
Why does my machine brew coffee very slowly almost dripping instead of brewing at regular cycle?
it might need cleaning solution to use is vinegar pour vinegar in it and turn it on let it fill the pot up hope this works good luck
Feb 26, 2015 | Cuisinart SS-700 - Single Serve Brewing...
Barely drips and I dont have vinegar
check spray head as they get deposit build-up in holes (they unscrew) and while head is off run some water thru machine. never use vinegar or any chemical cleaner inside bunn coffee brewers
Feb 28, 2013 | Bunn Coffee Makers & Espresso Machines
I descaled my coffee maker with 1 1/2 gal vinegar after flushing all the vinegar through it, the descale sign went off but now the coffeemaker keeps shutting itself off. It is "toast?"
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 08, 2011 | Keurig Platinum B70 Coffee Maker
The water no longer shoots out. Now it slowly drips and does not brew the cup of coffee. Any ideas?
run white vinegar or CLR thru it, see if it is just clogged up, if not then the heating coils are bad, just toss it
Oct 29, 2010 | Keurig B70 Coffee Maker
Water dripping slowly
You can get urnex at most reputable kitchen shoppes or order it. it will do a great job or you can run vinegar through the machine... be aware that it will smell horrible and will nedd to have at least 2 or 3 cycles of water ran afterwards but brewing this cycle a couple of times will bust up the lime. Doing it every month or so afterwards will keep it from coming up again. That would be my first step... hope that helps!
Apr 11, 2010 | Bunn 10 Cup Home Coffee Brewer
No water through the head!!
I had the same problem - all water going down into the tray at the bottom - virtually none through the coffer basket. I couldn't find citric acid at the store to descale so I used white vinegar instead. I 3/4 filled the reservoir with warm water, and added about 1/2-2/3 cup of vinegar. I first ran water through the 'hot water' button (it comes out the steam spout). Then I ran the entire reservoir through the machine using the 2-cups option. It started running right away. I rinsed out the reservoir with fresh water, then ran a whole reservoir of fresh water through the machine to get rid of the vinegar smell. The first cup of espresso after this treatment was as good as ever. Phew! I thought we were up for a new machine!
Dec 12, 2007 | Krups XP 4050 Espresso Machine
DeLonghi BAR 32 Espresso Machine Logo
59 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
