I have a he eterna washer that makes loud noise on spin cycle. It sound almost like bearings grinding. Model # ewa4500d1ww
    Sergeant:
  • 291 Answers
Your bearings will need replaced. Usually, the transmission is near the end of it\'s life by the time this happens and since it\'s easier to change out the transmission than the bearings (the bearings are part of the transmission) it fixes your bearing problem. However fixing just the bearings is a lot cheaper. There are some things you can check to see if the transmission itself needs replaced.
First thing is to look at the inside of the front panel you removed. If there is a band of slung oil about a foot from the bottom the transmission is toast.
If no oil is present lift the lid and remove the agitator. It pulls straight up (no screws to remove) with a quick jerking motion. I just put my hands around the neck of it like i\'m choking it and give it a quick kind of hard jerk. If it gives you trouble let me know. Once it\'s removed you will see a large plastic coupler. Make sure it doesn\'t spin and wiggle it side to side. There should be no spin or wiggle. If there is wiggle there may be a sick sloshy sound as you wiggle it back and forth. That\'s oil and you will most likely see it on the underside of the coupler as well. Use the machine a few more times and you may see oil on your clothes. Obviously that transmission has gotta go. If you are handy with tools you can change it yourself. There is a large 1 11/16" hub nut that will need removed. Other than that no special tools are required. Still plan on using up the good part of a day replacing it if you\'ve never done it and completely dismantling the machine. When you are done though you will enjoy a machine that is practically new again. You can buy new transmissions on eBay for somewhere between $100 - $150 any day of the week. The $150 ones should come with a new hub nut, tub seal and turtle brake at the very least, if not you\'ll need to purchase them seperately. It\'s also possible you\'d need what they call a tub bearing, but usually those are okay. Let me know. I can walk you through the process or perhaps find you more info. Good luck.
Posted on Jan 12, 2013
    Genius:
  • Washing Mach... Master
  • 1,669 Answers
If it is a smooth continuous sound it is the bearings. If it is a bumping sound it is the mounts.
dididsaythat
  • 291 Answers
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
Posted on Sep 03, 2007
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Posted on Feb 11, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
Posted on Nov 21, 2008
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
milten1
  • 1304 Answers
SOURCE: WHIRPOOL WASHER LSQ9564MQ0 Started making loud
judging by the description i would say more likely the coupler
its a three peice part that sits between the mototr and transmission, kinda like a clutch,
anyway it is easily repaired
and available on appliancepartspro.com
type in your model number.....
look for motor coupler
Posted on Oct 13, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
How do i repair a lg washer that makes a grinding noise when slowing down from spin cycle
It sounds as if the tub bearing on your machine is faulty. To replace this bearing one needs to basically strip down the entire machine.
Not a job for a novice.
Sep 06, 2014 | LG WM2501HWA 4.2 cu. ft. Front Load Steam...
When my washer is on the spin cycle it is making a very loud humming/grinding sound. This just started and the washer is 5 years old. What could the problem be?
Thanks for choosing FixYa and welcome to the site. More then likely, it is your spin bearing or the drive motor. This is usually the case if the noises occur in spin cycle. The most likely cause is your bearings.
May 13, 2011 | Washing Machines
Loud noises during spin cycles
Hello, If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
Thanks
Jun 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer loud grinding noise spin stop
if its brand new it shouldnt be making a loud grinding noise id get it checked make sure they removed all shipping bolts
May 17, 2009 | Maytag Washing Machines
Loud noise during spin cycle and agitator won't rotate
the machine is nknown to have bad main seals, in turn leading to the corrosion of the spin bearing, in which case makes it sound as if a helicopter is landing in your laundry room
Jan 26, 2009 | Amana LWA40A
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Oct 26, 2008 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
