Not feeding paper through. - Office Equipment & Supplies
Try to clean rubber roller with glass cleaner..
Posted on Jan 12, 2013
My Pc745 has stopped pulling paper from the tray without crunching it up
try to run paper from the side bypass tray. if still no go, you may have something blocking the paper from feeding. if it feed from the side bypass but not the cassette, paper feed tire may not be feeding paper or the out of paper sensor maybe keeping paper from reaching paper feed tire
Apr 11, 2010 | Canon Office Equipment & Supplies
Paper doesn't feed from inside on XD 100 work center (10 years old, lightly used). Despite a full paper drawer, I get the "out of paper" error message.  I can copy by feeding through the back.
On this machine, the feed rollers might be worn down.
Not seeing the machine and by the description. there can also be other possible problem areas, deep in the machine itself.
Does the paper feed partially out?
If it does not, are there paper black scuff marks where the rollers were trying to feed the paper.
Can you hear the solenoids feed the paper?
If the paper does feed and seems crooked, it is possible the paper tray springs need to be stretched out just a little to push the paper tray plate more on the feed rollers.
Make sure the tray is completely up in the latched position so the feed wheels will touch the paper stack itself.
If you have a two paper tray, make sure you tell the machine what size paper you have for each tray.
Run paper in each tray.
Good luck.
Jan 15, 2010 | Xerox Office Equipment & Supplies
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Paper doesn't always feed, and when it does, the paper rolls through without printing
Get a Q-Tip and alcohol. Wet Q-tip with alcohol. Stand in front of the printer and look down where the paper feeds through. On the righthand side you will see a big roller that pulls the paper through and a little one right up under that. Clean both of them with the alcohol and Q-tip. Press the paper feed button and as it trys to act like it is feeding the paper, clean the roller with the Q-tip. Do this until the paper feeds through correctly.
May 16, 2009 | Epson Stylus Photo R1800 InkJet Printer
On a Canon MP 460 printer, the paper will not feed in straight causing constant paper jams.
If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit.Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the printer is powered on and remove any paper from the Auto Sheet Feeder (ASF).
  2. Press the <Menu> button.
  3. Use the right / left cursor button to select [Maintenance/settings], then press <OK>.
  4. Use the right / left cursor button to select [Maintenance], then press <OK>.
  5. Perform the paper feed roller cleaning three times.
    1. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    2. When prompted to start roller cleaning, use the up / down cursor button to select [Yes], then press <OK>. (The paper feed roller cleaning starts.)
  6. Check if the paper feed roller cleaning procedure resolved the issue.
    1. Load a sheet of letter-sized plain paper in the ASF and open the paper output tray.
    2. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    3. Use the up / down cursor button to select [Yes], then press the OK button. (Paper will be fed.)
  7. If paper is not fed properly, repeat step 6 up to three times.
Oct 21, 2008 | Office Equipment & Supplies
Canon PIXMA MP600 printer - paper feed
Issue: Paper feeds skewed
Solution: Clean The Paper Feed Rollers Using The Operation Panel - MP600
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
  3. Press the <HOME> (A) button.
  4. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the <OK> button.
  5. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press <OK>.
  6. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
  9. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
The above illustration shows a PIXMA MP500
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click here to return to step 2
May 31, 2008 | Canon PIXMA MP600 all-In-One InkJet...
PAPER FEED
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in.. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Jan 16, 2008 | Canon P1-DHV Calculator
Paper feed rolls is rolling over the paper...how to get access to those rolls
  1. Feed the paper manually into the printer:
    1. Place a sheet of plain A4 paper in the paper feed tray.
    2. Move the paper support on the left-hand side to the left end of the paper.
    3. Press the paper feed button.
    4. If the paper does not feed, continue with step 2.
  2. Check for any obstructions in the paper feed path:
    1. Disconnect the cables from the back of the printer.
    2. Open the front of the printer and check for anything that may be blocking the paper path.
    3. Close the front lid and remove any paper from the paper feed tray.
    4. Holding the printer in both hands, turn it upside down to see if anything falls out of the paper feed area. (Sometimes objects such as pens, paper clips and so on can fall into the paper feed area and cause blockages.)
You can clean with special cleaning paper which ca be used clean the rollers............
Dec 08, 2007 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x3350
Nov 20, 2007 | Lexmark P4350 All-In-One InkJet Printer
14 people viewed this question
jasbo
jasbo
