Question about Canon Office Equipment & Supplies
Reset ink counter
Ix6500
5 Suggested Answers
suben
  • 214 Answers
SOURCE: Reset Compaq IJ650 ink counter
go to the printer properties and select maintenance then select reset ink counter
Posted on Jul 22, 2008
jell587
  • 447 Answers
SOURCE: reset canon iP 1600 waste ink counter
This link should help you with your problem.
Posted on Feb 21, 2009
jcoady
  • 79 Answers
SOURCE: reset waste ink counter
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
NOTE: There are a couple of things that might affect this. If the print head is clogged or needs replacing this will not work. Also, I've read elsewhere that it's a problem if the waste ink resevoir is full (shouldn't be the case, but who knows?), and replacing the resevoir is a 3 hour PITA that only few regular joes will find worth the time.
A great reference for the printer 'do-it-yourselfer': http://www.fixyourownprinter.com
Be sure to check their forums for other end user's solutions.
Posted on May 22, 2009
  • 21 Answers
SOURCE: ink absorber counter
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd28
Posted on Sep 06, 2009
Wat tank full mp 520
Hi Guy,
I believe that what you mean is 'Waste Ink Tank Is Full' error on Canon MP520.
To fix this problem, first you need to reset waste ink counter of the printer then you should replace the ink absorber with new one.
In order to reset waster ink counter properly, you can read complete procedure how to reset waste ink counter of the printer below:
How To Reset Waste Ink Counter Canon MP520 Multi Function Printer
May 07, 2014 | Canon MP520 All-In-One InkJet Photo...
I had the problem of the full ink absorber. I already washed and cleaned all the parts related. Now, I need to reset the counter; how I can do it??
<Ink absorber counter resetting>
Reset the ink absorber counter (to 0%) when the ink absorber is replaced, or after the logic board is
replaced.
1) In the service mode, press the Stop/Reset button 4 times to enter the ink absorber counter resetting
mode.
2) In the ink absorber counter resetting mode, press the Stop/Reset button the specified number of time(s)
according to the kind of ink absorber whose value should be reset to 0%.
(13/32)
Time(s) *1 Ink absorber
0 times Main ink absorber (0%)
1 time Platen ink absorber (0%)
2 times Both the main and platen ink absorbers (0%)
3 times or more Press the ON/OFF button to return to the ink amount resetting mode.
3) Press the ON/OFF button to specify the ink absorber whose value should be reset to 0%.
4) After the ink absorber counter is reset, the counter value is printed automatically.
("D=000.0 Ps=000.0" is printed at the top left of the paper.)
*1: According to the number of times the Stop/Reset button is pressed, the LED lights as follows:
- Odd number of times: Alarm LED lights
- Even number of times: ON/OFF LED lights
Nov 01, 2013 | Canon PIXMA MX310 All-In-One Printer
Ix6500 waste tank reset
gan.. postingkan dlu riset print canon iX6500 !!!
mohon konpirmasinya gan !!!!
Dec 09, 2012 | Canon Office Equipment & Supplies
I cannot print from canon ip2770 printer...the orange light flashes five times
  1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
  2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
  3. Run GeneralTool.exe
  4. Select the connected USB port number from USB PORT
  5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Jul 06, 2011 | Office Equipment & Supplies
.error 1700 says waste ink absorber nearly
(In waste ink absorber replacement, perform
the EEPROM information print to identify if the main and/or platen
waste ink absorber should be replaced. After replacement, reset
the applicable waste ink counter(s).)
Waste ink counter reset See “Service mode operation
procedures” below.
The following 3 methods are available:
- Resetting the main waste ink counter (0%)
- Re-setting the main waste ink counter
value to 50%
- Resetting the platen waste ink counter
(0%)
<Service mode operation procedures>
1) With the front cover closed, and the printer power turned off, while pressing the Resume/Cancel
button, press and hold the Power button. (DO NOT release the buttons. The LED lights in green
to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.) During initial operations,
the LED blinks in green.
4) When the LED light sin green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
pressed, the LED lights alternately in orange and green, starting with orange.)
Time(s) LED Function Remarks
0 times Green Power off When the print head is not installed, the
carriage returns and locks in the home
position.
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting Proceed to the step 5), and follow the
Waste ink counter reset procedures.
5 times Orange Destination settings Proceed to the step 5), and following the
Destination settings procedures.
6 times Green Print head deep cleaning
7 to 9 times Orange Not used in servicing
10 times Green Return to the menu selection
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu
selection mode automatically.)
<Waste ink counter reset procedures>
In the waste ink counter resetting mode, press the Resume/Cancel button the specified number of
time(s) according to the ink counter reset value listed in the table below, and press the Power button.
Time(s) LED Waste ink counter value
0 times Green Reset the main waste ink counter (0%).
1 time Orang
e
Reset the platen waste ink counter (0%)
2 times Green Re-set the main waste ink counter value to 50%.
<Destination settings procedures>
In the destination settings mode, press the Resume/Cancel button the specified number of time(s)
according to the destination listed in the table below, and press the Power button.
Time(s) LED Destination
0 times Green No change
1 time Orang
e
Japan
2 times Green Other than Japan (A4)
3 times Orang
e
Other than Japan ltr
Jun 24, 2010 | Canon Office Equipment & Supplies
New printer. Black cartridge doesn't work. No black on test sheet
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK.
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
New black cartridge installed. Won't print. HELP please.
Try
Important
Note
Canon Pixma MP150
Besides service tool, mptool is the popularness software to reset printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460. Excess of software that is the program measure of small and amenity of usage. Ability of the software that is to reset level black and color cartridge at canon pixma mp series. And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
Reset Ink Counter.
Reset ink counter that is resetting ink level (ink metrer) cartridge at printer.
  • Reset Black – reset level black ink cartridge.
  • Reset Color – reset level colour ink cartridge.
Reset waste ink counter
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
  • Reset Main (main).
  • Reset Platen (additional).
go to this website download this software after that install it follow by instruction that i give to you do reset....
http://www.mediafire.com/file/yan3ytvdumt/MPTool.zip
Sep 16, 2009 | Canon PIXMA iP1600 Printer
Waste ink absorber?
Hi. As you have not mentioned the make and model of the printer, I am giving here the procedure to reset waste ink counter applicable to most printers. Hope it helps.
Canon Pixma iP1200, iP1600, iP2200 Resetter
If you have a different printer model, then please tell me and I will research that for you. Thanks.
Jul 29, 2009 | Canon PIXMA iP1600 Printer
RX700 Ink drip reset counter?
which buttons do I press when turning on my RX 700 after changing the ink pads which will reset ink drip counter? Thanks
Jun 02, 2009 | Epson Stylus Photo RX700 All-In-One InkJet...
27 people viewed this question
old marine
old marine
