Question about Ricoh Aficio 1035 Copier
My Ricoh Aficio 1035 is not seeing the network
I just changed router carries from at&t to comcast and for some reason i can print and not scan. Ca you please help?
  • Tim Babcock
    Tim Babcock May 11, 2010
    What is the IP address of your router?
  • Tim Babcock
    Has the gateway address been modified on the router when you switched providers?
You will need to assign a new appropriate IP address for the machine under "user tools" system settings", "Interface settings", "Ip address".
Then create a new tcp/ip port for the printer, and point the old driver to this. Scanning may require additional work -perhaps a tech, to reconfigure the scanner. Your probably using the "scanrouter" software?
Posted on Feb 13, 2009
Can not find ip address on richo 1035. I tried to connect my richo 1035 with computers through internet. I did all to change ports on printer properties section. I am putting ip address of my service...
Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
Jun 27, 2017 | Ricoh Aficio 1035 Copier
Ricoh aficio 1035 scanner problem,can scan but pc "hang " why?
1).Restart your computer. 2).reload printer driver on your computer.
Oct 31, 2009 | Ricoh Aficio 1035 Copier
How do I use my Ricoh Aficio 1035 for scanning and can it be sent to my computer?
Yes you can use it for scanning to your computer. You must have the scan option installed to do this. Does the left side of your operations panel have a button labeled scanner? If so and you push it, it should give you the scanner operation screen. If all this is true then all you need to do is have someone setup the machine on your netrwork for scanning.
If you do not have this button or if you do and you push it says this option not installed then you will need a network print/scan kit. You can find these on Ebay for less than $200. Installation and configuration will cost you another $100.00 to $150.00
Oct 22, 2009 | Ricoh Aficio 1035 Copier
Do i need any driver if i connect Aficio 1035 to my pc. n wat do i need for it to be connected to my pc. tq
Does your machine have the Printer Option installed? Or the Print / Scan Option installed? If so, there would be a NIC input on the left hand side of machine towards the back....and print and scan buttons on the left side on your control panel. Type 1045 Printer option is what needs to be installed for the machine to be able to print. Drivers can be downloaded from this link to Ricoh.
Just choose your operating system.
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Trying to get my Ricoh Aficio 1035 networkable
This is all you need to upgrade your copier to a network printer/scanner and fax.
Good Luck.
32MB Memory Unit Type B 400516
Postscript 3 kit type 1045 410713
64MB Memory Unit Type B 400517
Fax Function Upgrade Type 185 410284
Print Unit Type 1045 410706
Printer/Scanner Unit Type 1045 410699
Network Interface Board Type 1045 410714
Fax Option Type 1045 410680
Fax Stamp Marker Type 30 334049
Jul 08, 2009 | Ricoh Aficio 1035 Copier
I'm trying to print on a Ricoh 1035 from a Mac. Is this possible if it's on a network?
Its possable to print to a networked ricoh 1035 from a Mac... You need the Postscript option...
Jul 01, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Networking at Ricoh 1035
does your 1035 have either a printer or printer /scanner option. If it does just hook s line up to the network connector on the back of the controller. hit user tools, system settings, interface settings, network settings and then select auto obtain. now exit from the user tools to the regular screen. wait about ten seconds to let the settings take effect. Now hit user tools , printer features, lists and hit configuration page. Take this page to the computers with you. Go to start, add a printer add a local printer, deselect auto detect, hit next. Now hit add port select tcp/ip from drop down button. in location where is it says printer name or ip address enter the printer name located on the bottom right section of the configuration page you printed. now go to ricohs website, americas, then at the top you will see downloads. then a screen will apper that says drivers and manuals. select black and white, 1035 and windows vista. create a folder on your desktop called printer. once in the folder, open it double click and unzip it into the same back to page after you have typed in the printer name and hit next. go to have disc, browse to the folder on the desktop and follow the prompts form set up, drivers, vista, pcl 5, english and the select if this is your default printer, do not select sharing and ask it to print a test page. once this has printed go to the properties tab on the drive itself and select accessories. and add whatever options your copier has ie. sorter, duplex or extra paper drawers. Now do this to all your copiers on the network. doing this allows you to print from any computer regardless if any other computer goes down
Dec 11, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
453 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
