Question about TV Ears Wireless Headset Replacement Bow Arm
TV Ears headset bow arm replacement instructions
Where can I find instructions to replace this broken arm? And where can I get a replacement part?
How do i replace the battery
if they are replacable then there should be a lid to the campartment that holds them if there is not then I would assume ,not replacable
Feb 08, 2015 | TV Ears Extra Headset ONLY for 3 0 System
Does not drown out background noise, only makes it louder
If you have just bought these, take them or send them back.
Feb 02, 2014 | Dual TV Ears - Headset System Headset
Lines are bowed on my Philips Magnavox TV Model #RS3 182 C 402.It is connected to a digital converter box and a Philips Rabbit Ears Antenna.I cannot detect any horizontal line moving up or down the...
Check its convergence adjustments. If convergence board have the fault, the vertical lines will be shown as bowed. Might need replacement. Just try to adjust the convergence first. If you wish to get more details about how to adjust this, check the site linked here. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 12, 2013 | Televison & Video
TV Ears -Light is green on base.Rest of lights are not on..Cannot hear sound emanating from earphones
When you have your head phone on your ears, there should be no Green light, unless you have another headset on the transmitter base in Front Slot.
Having Green or Orange light on the larger LED on the left side has nothing to do with the audio, that light is only for Charging indicator.
You should have ALL FIVE RED LED light on, if any one is out, you have a failed LED and would need to replace ALL small LED ( five of them on the right side) with LEDs from Radio Shack SKU# 276-143 High-Output Infrared LED or buy it from http://www.newark.com/optek-technology/op291a/ir-emitter-890nm-t-1-3-4-through/dp/08F2980.
Aug 24, 2011 | Dual TV Ears - Headset System Headset
Right ear arm broken on tv ears.
http://comfortabletvearsconversionservice.yolasite.com/
Mar 16, 2011 | Radio Communications
I have 2 sets of TV ears. One works intermittantly but with lots of static. You have to tap it to get it to work. The other one is newer but, of course the warranty is expired. This one doesn't work at...
I used Radio Shack part #276-143 High-Output Infrared LED.
I replaced only the one LED that was not glowing properly. On internal inspection, I could see the LED was discolored inside.
Works fine now.
Feb 12, 2011 | Dual TV Ears - Headset System Headset
I have a jabra bt125. The arm is broken. where can i get a replacement?
Might want to check with Jabra, they can probably send you one for cheap. My advice: don't ever purchase Jabra again, they are cheaply made and unreliable. I use plantronics only.
Mar 19, 2009 | Jabra BT125 Headset
Release Button?
program 39 on your programming manual.
Jun 20, 2008 | Toshiba DKT-2020 Corded Phone
Horizontal bow and shadow
Replace convergence IC's--then re-check convergence alignment in servicer mode,if necessary.
Sep 27, 2007 | Philips 9P5544C 55" Rear Projection...
TV Ears Wireless Headset Replacement Bow Arm Logo
158 people viewed this question
Top TV Ears Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a TV Ears Radio Communication Expert? Answer questions, earn points and help others
